the truth about electric cars
Guys, the "complex bits" is the electronnicy control systems, and a Scalextric car has just as many of those as an ICE engine one does.
EV real world range and cost to charge
Really? How many does the Qayne sleep? Can you cook a meal in one?
Rainwater retention - 2023 facelift
Check the drains for the sunroof if fitted, front wing and doors on the LHS.
Start Stop Issues after new battery
Yes he is, and entirely correctly AIUI.
COOLANT TANK
I'd interpret that as "life of the anti-corrosive and additive packs in the coolant", about 5 years.
EPC light 1.2 Skoda Fabia 2003 model
No. The EPC light can indicate any of a vast range of issues, from about £50 to £4_000, and we'd need the associated fault code(s) to know which.
- Losing acceleration - please help!
Washer and wiper issues
Yes, and it's the same pump front and rear. Most likely you've blown a fuse or burnt out the motor.
Citigo aircon direction knob is not working. Always blowing in the face
In principle yes, but the wheel nut spanner in the boot should be sized to give you an acceptable approximation to the required torque.
Loss of power
Literally turning the ignition off and on again with the car still moving but declutched.
VW Jetta
Nothing "new" here, except that it was running full-on H*11aflush. Sorry, but I couldn't get positioned for a picture.
Loss of power
Agreed with JR. Look for "Mr Muscle fix" in the Octavia guides forum.
Cannot refuel!!
Yes and no. Yes it will allow air to enter the fuel tank, but no it will not re-expand a collapsed tank.
Clutch pedal
No, you're looking at an unspecified fluid on your clutch pedal. Rub it off and see if it comes back. If it does, try and identify whether it's hydraulic fluid, water (possibly with antifreeze mix), engine oil or fuel. Oh and check whether or not the fluid levels in the brake/clutch reservoir and PAS reservoirs remain constant.
Reversing camera not working after software update
Critical point marked up in bold-face I think. You appear to be expecting VAG to deliver software that will just plug and play with non-VAG hardware.
Tyres very unevenly worn... can anyone help identifying this?
This would be a one off to have happened, but the only time I saw this sort of wear on a front tyre the car had a failed front lower ball joint. So I'd suggest checking both front lower ball joints.
Red flashing EML light plus beeps
Based on @Breezy_Pete posting, I'm fairly sure that was low oil pressure.
Locking Wheel Nut Cap
56mm looks more like a size for a centre boss than for a wheel nut.
Kodiak towbar without prep
OK. Does the type approval plate for your car have a non-zero train weight?
Wheels from the breakers yard
The wheel size rather than the tyre size. This will be cast or stamped into the wheels.
Wet carpet
Yes. Buy a new membrane instead of trying to bodge it with mastic.
2010 mk2 fabia 1.2 htp suddenly burning oil and oily smell in cabin
It could, but it could be other things too, like a porous flexible section in the downpipe. Put your hand over the exhaust exit(s) and see if the engine keeps running. It it does, a porous flexi is more likely than a blocked PCV.
Very difficult to get out of gear
@Tojodrew - Ok, a lot to answer here, in the order you list stuff in:- 1) My first thought was that the gear linkage may need adjusting (aka re-aligning). 2) Your mate is correct; (balk ring) synchronisation is there primarily to make shifting into gear(s) easier. 3) I'm not sure how to explain the collets. 4) Clutch drag is also very much a thing. This tends to happen with the clutch cable stretching, the hydraulics needing bleeding or the hydraulic slave cylinder (at the gearbox end) needs replacing. Getting this diagnosed needs someone competent and with access to your car.
Fabia 3 diesel any way to stop it adding accelerator revs when taking off
No idea beyond that it would bug the H*11 out of me too.
Hi, i have a Skoda Octavia MK lll 2019 TDI. Coil light flashing.
Do the brake lights work? If "no", the replace the brake light switch. If "yes, then, as @daftbugga you need fault codes reading.
