EML dealer not resolved - code reader recommendations?
VCDS or OBD II, the same as for anything else from a CitiGo up to an Audi R8 V10.
Power loss accelerating up a long incline
Either it's getting so hot it's going into an engine protection mode, or it's suffering from fuel starvation I think. Either way it want the codes read.
Diesel metering unit
I don't know the Weymouth area, but suggest looking for a Bosch Diesel or TurnerTune outfit.
- Buying a MK1 VRs, issues?
Interior light
I've never known courtesy lights come on until you open doors.
Problem with starting the diesel engine the day after a long journey.
Find out what the problem actually is instead of wasting bandwidth describing normal function of the vehicle.
Excess fuel is returned to the tank during and after short journeys too.
Air compressors
Halfords do a reliable and cheap 12v electric compressor that will certainly do car and light van tyres, and possibly cycle tyres up to about 70PSI.
Air compressors
I recommend you post a clearer use case if you want meaningful answers.
Drain on battery! On my 2010 diesel estate any ideas, l have fitted a sat nav aftermarket in place of the radio. Battery flat after 7 days help
Your prat nav doesn't have the same engine off -> electronics off facility as the radio does?
Modification in my 14" wheels, is it safe?
NO!! Here's a picture of a dissembled BBS split rim
Slick 50 oil additive
I remember the original version being tested in a Sierra XR4i (original Cologne V6 2.8l version with the opera windows and biplane spoiler) by Gerard Sauer and him reporting that he wasn't getting measurably different mpg but he was getting an idle 200rpm higher than normal.
Fans don't work with AC on
Yes. The LP fan doesn't start because you don't have a refrigerant under pressure in the air conditioning pipework. Anyone who is telling you otherwise is more interested in getting the contents of your wallet than in repairing your car.
As I'm reading this, like everyone else I'm thinking that your a/c has leaked some or all of the working fluid so will never operate.
the truth about electric cars
@wyx087 And it's taken you a whole 20 hours to get blocked on my new account.
- VW Scirocco R (6 speed manual) - Project - Race/Track car build
2023 F1
2 Para 2 - Why now, after Laurence bought his wee boy an entire F1 team?
Trevorb33’s Fabia vrs mk1 307bhp/400ftlbs - now sold
Too soon Trev, too soon...
vRS19TD/SE20TD - Fabia vRS SE #532
I'm wondering if it's glazed rather than warped discs... Check the runout with a dial gauge rather than putting more discs and pads in the parts cannon.
Flashing glow plug light but recently had all glow plugs changed?
Before spending out money, check if the brake lights work. If none of them do, you need a new brake light switch.
High idle mk1 1.9tdi
Adjust the engine idle speed.
Water in the inside climate radiator
Normal function. As per @Breezy_Pete above, you may need to find and clear a drain hole. It's normally left of centre with the usual convention of left and right being when facing in the sirection of travel.
Competition clutch?
I'd say so, but I doubt there's a competition clutch for this model.
