john999boy
Honorary
Everything posted by john999boy
  1. Auto high-low is different. It was a £100 option when I got my car.
  2. Do they selectively obscure other cars when you have 'adaptive' full beam on?
  3. They only light up if you have the adaptive headlights.
  4. Don't you use spigot rings?
  5. When you press reset there's a new baseline to work from so everything should work fine.
  6. I think the polish would be more of a problem as you'd need to ensure it was all removed before it was painted.
  7. Your car should have the paint details either inside the Service Book (I think) as well as on the boot floor.
  8. Firstly you don't use a screwdriver. If you heat it up and use something similar to dental floss then you can 'saw' it off easily.
  9. I didn't know about the McLaren wheel fitment either but as you know, Bentley are VAG so that's not a problem.
  10. My concerns were around the PCD (which would appear correct) but I can't recollect anyone else using BMW wheels. As for their size, I'm eager to see how well they suit.
  11. I'm not saying that it doesn't happen but I've never heard of it before. My first thoughts were that your car choice or age had a bearing but maybe not?
  12. As a non Freedom member you have 60 minutes available to edit your posts. As a Freedom member you get an unlimited amount of time (amongst other things) to be able to edit your posts. I can't believe you were hoodwinking your fellow Briskodians with the supercar tale!
  13. You'll also find that the Karoq won't get as many punctures as your Bugatti either.
  14. I made a heavy duty 'box' that allowed a lower jack to work effectively at an raised height. This gives me the best of both worlds. As for one specifically for the Karoq my suggestion would be to search for the high lift variants but I can't offer any particular model as a choice.
  15. Actually a 2007 model isn't a FL so............ Anyway, I had a non FL & a FL and it was only possible to activate on one of them.
  16. There was a problem with the FL IIRC.
  17. Can you please make an Ad in the Wanted section of the Classifieds.
  18. Have you taken the plunge yet @gadgetman?
  19. I think it's looks quite appealing.
  20. Can I clarify if that's with ACC or PCC? It's a genuine question as I thought the technologies were different.
  21. I'll merge these replies into the OP's new thread later. Any replies will be in time order.
  22. This may or may not be related but thought I'd add it as it may be relevant in the very near future. Google is amending their photo storage (15Gb) capacity again which will limit the amount of photos able to be stored with a free account. This will also depend if users have a Google phone or not (and it's age) plus in what resolution the backup is being made.
  23. Can you post here please as it might open up to a wider audience.
