Everything posted by Cairus
- radio replacement
- radio replacement
- radio replacement
- radio replacement
- Activating SmartLink on Swing 3
OBD 11 is ok
Dont use Carly, i have buy it with all inklusive and it's the worst tool of all that I've ever used.
Columbus update stuck
Yes, or Take Off the Batterie
Wiring Connector Depinning?
Airbag? I have own Tools and need them
And Always jewellers screwdrivers was enough?
Then you hadn't had many types of plugs yet.
MY17 Superb SLA Headlights Upgrade - Help
Facelift have Xenon? Only LED Low and Matrix or Not?
Driver door replacement
Your door control unit is located in the door itself. Therefore, make sure you choose a door with the same or more features. Pay attention to pre-facelift and facelift models, as well as sedan and station wagon versions. The control unit still needs to be coded to the vehicle.
G-meter issue (obd 11)
I never have done this, when i Code the Option it was Automatic on or Not
Hatchback struts
Stabilus is OEM seller for 80% der OEM
DAB aerial replacement
I use This DAB Antenne in 1x Octavia 3 Facelift, 1x Kodiaq 1 Pre Facelift and in 2x Seat Leon 5F. IT Works perfect...
EPB servo replacement
First, perform abrake pads change sequence. That is, open and then close. Unfortunately, OBD11 isn't always reliable with default settings.
And you have No ESC/Abs/ESP Error? Fuse Number 1 in the Engine-Room is OK?
- Wiper Position when Running & When Off
- Skoda Octavia Mk III VCDS help
Not at all. Not every vehicle or control unit supports this function.
Octavia 2 2010 vrs petrol instrument cluster failure
Why drop down? Vcds original?
You To Always Autoscan What say vcds when you Connect directly
What is supposedly broken on your current engines?
