Cairus
Everything posted by Cairus
  1. Maybe Problem with Control unit 19, "Gateway" or broken fuse You have a Error Log from Diagnostic Tool?
  2. 1) yes 2) You need the diagnostic tool to unlock the Green Menu so that you can then use the ToolBox.
  3. You can try setting the Bluetooth AVRCP version to version 1.3 in the developer menu of your Pixel smartphone.
  4. Long Coding: 6414 Try this
  5. Clear Error Log With Diagnostic Tool
  6. There is No solution. By virtual Cockpit from Skoda it is Not more in the Firmware
  7. Disconnect the battery. Hold the positive and negative terminals together. Wait 10 minutes and reconnect them. Start the vehicle, turn the steering wheel fully to the left, then to the right, then to the center. Drive around the block once. Then clear all fault codes in the BCM, but first change the diagnostic session to developer mode.
  8. Why you need the ToolBox? Smart Link? You have Hardware Version H20, this is a old unit. Buy H40 Amundsen unit.
  9. Please forget about AI when it comes to ToolBox. AI only provides rubbish there. Bolero can't be installed via SD card; you have to install it directly onto the eMMC using the "needles."
  10. When you have Firmware P0245T is it TechnikSat/Preh... I personally have never seen a Delphi unit in a Skoda. How did you come to the conclusion that yours is a Delphi unit?
  11. A small project for my own vehicle in between other things... 😁
  12. Never use one click Apps... I will Share a OEM Backup... You have Pro Account by OBD11?
  13. You have This Wire? The Button for PDC ist No Coding
  14. Missing wire To PDC unit Retrofitl
  15. You need step Update. JUMP is to big
  16. Of course, if you know what you're doing.
  17. https://mega.nz/file/9rU0hJYT#gJlv4gzNiNDBvdV7W8C7MtuHMBXLwijIG6EK81s6FoY
  18. The data set for driving profile selection in the gateway also includes the method used for switching between profiles. Simply modifying it isn't possible. I myself converted from a button in the center console to a rotary knob.
