Everything posted by Cairus
Octavia 2 2010 vrs petrol instrument cluster failure
He didn't clone anything. He read the immobilizer data from the old speedometer and one key, and wrote that data to the new speedometer. The second key is not stored in the new speedometer.
😂 Sorry, Bad Work from JCars
If the EEPROM in the original chip were defective, they would have cloned the error along with it. Was the original dump saved by the new chip? Was it really the same EEPROM? I think no
- Infotainment Upgrades
- Bolero MIB1 Update Help Please!
Clock spring replacement
This spare parts should be buy only OEM
Which valeo Part Number?
Engine / Ignition Switch-Off Irritations
Your vehicle doesn't offer the function you'd like. The "2" means you have two notifications, like on a phone: swipe down and drag the status bar.
adjust full-LED headlights elevation/distance?
OBD 11 can To Basic Setting, you have the Equipment for set Basic Setting for the LED Light?
Is there an update to Infotainment System (5Q0035842A / H24) newer than 0241?
SD Card
The adjustment should/must be done using a diagnostic tester. The headlights are still adjusted directly via adjusting screws on the headlights, but the automatic leveling system is given a new basic setting for the headlights.
You start the Update in the Service Mode with SD Card?
Engage the electric parking brake, open the driver's door, and unlock the hood. Ignition only.
Security Login done? S12345 = Code
When you have rhd Car, Set Bit aktiv
a small project
MIB2/Apple CarPlay upgrade
It makes no difference whether it's an OEM wireless system or an aftermarket one. Imagine a 3-8 hour road trip where your smartphone might be in the Qi charging pad. The phone will definitely overheat. Even an iPhone can't handle it. Plus, you have to find a place for the extra module so it's not visually obtrusive. If you buy the MIB2 standard navigation system cheaply, you're looking at between €180 and €250. Even someone with two left hands can activate it. Of course, the OEM solution requires a diagnostic tool. Usually, you also need a new USB port, which, complete with wiring harness, costs less than €30 on AliExpress. My customers have always opted for the OEM solution. But it's good that there are alternatives.
- MIB2/Apple CarPlay upgrade
a small project
How-to Guide to Upgrade MIB2 to MIB2.5
Lucky Man 👍
- Known compatible USB port&cable with the (old) SWING radio - MIB2 Entry 5E0 035 871 A ?
- Amundsen MIB1 Firmware update finally completed - MSTD_EU_SK_P6230 MU0490
