Cairus
Everything posted by Cairus
  1. The multifunctional steering wheel is managed by the gateway via LIN. Then there's the question of whether it's the 5Q0 or 5Q1 control unit of the steering column. There's a significant difference.
  2. No warrenty Byte 11 Bit 02 Karoq Model 2025 have This Option
  3. Yes, mib2 and Dashboard same time
  4. The middle seat is not heated. Furthermore, the central connection is not for the seat heating.
  5. The Controller is damage. Replace IT, all Other is waste time
  6. https://mega.nz/#P!AgDyKQPZIFP5eBHREurx_1e70g7-nGkJn4ov-kvj7bSRTfMCnJZLEzYVKlUag9iAgfD3aTlTJP9IMJ7H-X7xDBlpE_KzMqPVp_E8iGNRujgKqAvBDWXdUQ
  7. I never had to configure my extension. I simply tapped into the existing lighting's power and LIN signal, and it worked immediately. MQB Classic Seat
  8. Buy facelift taillights, run cables, change connectors, replace BCM and gateway, code control units
  9. Does that mean you can dim everything normally, but the AliExpress LEDs always stay at the same brightness?
  10. Just because the open-circuit voltage is 12.2V doesn't mean that the LIN bus is sending 100% of the alternator's power request; it doesn't mean that it's charging the battery at 14.XV.
  11. provided it is requested via the LIN
  12. If the vehicle's BMS (Battery Management System) indicates a low charge level, the battery can be replaced in 90% of cases.
  13. The display must work for both at the same time.
  14. https://www.briskoda.net/forums/topic/535341-dcc-slider-mode/
  15. Why activate? System detected self
  16. You have To Take the Option AFS, FLA, Fernlicht ueber AFS
  17. The part number is differentiated as follows: up to production date 07/07/2019, it is 3V0827566X. X is the index depending on the vehicle's equipment. From production date 08/07/2019 onwards, it is 566827566X.
  18. What does the file have to do with the fact that the colleague is looking for someone who can do it for him? And Odis, vcp are Not the only Tools which can write Dateset
  19. MEGAMEGA provides free cloud storage with convenient and powerful always-on privacy. Claim your free 20GB nowPassword write PM
