JR RS
Everything posted by JR RS
  1. @Mo97 - have u changed ur infotainment unit too? MY16 uses MIB2. MY21 uses MIB3. The Climatronic panels need to communicate with the infotainment unit, hence u need to make sure they're compatible and u have done the appropriate coding and/or parameterization. MIB3 is very different to MIB2, communication and modules wise.
  2. Thanks @travs I've decided to go with Option #2 - IE downpipe and switch to Galano ECU tune with TCU tune. Spoke to my tuner guys at length and we felt this would b the best way forward for Gandalf. The work will b carried out towards the end of Oct - I'm really looking forward to it.
  3. The grille for a facelift Superb is completely different to the pre-facelift Superb.....so the answer is no.
  4. The 220 Superb FWD uses 312mm ventilated front discs and 300mm solid rear discs. The 280 Superb AWD uses 340mm ventilated front discs and 310mm vented rear discs.
  5. Spring has arrived, so it was a good reason to wash Gandalf, after a long overdue 5 month draught, and take some updated pics afterwards. Some rolling shots...
  6. The DRLs r not designed to b replaced...at least not easily. To get to it, u must remove the headlight front clear plastic which involves extreme heat using a heat gun or baking the headlights. Then u have to pry the plastic off. Once the cover is off, u can access the DRL elements themselves as well as the DRL light circuit board itself. Putting it back is a mess as well because u have to not only glue it back, it has to b sealed 100%. A lot of effort. And good luck finding the DRL elements specific for the Superb. U can find the DRL boards though. I haven't done it myself, but below r some pics from someone that has, showing the headlight with the front plastic cover off.....
  7. My previous ones were Continental Conti MaxContact6. Did 50k+ kms on it. Now I'm running MaxContact7. Fitted about 2 months ago. I've used 2 sets of tyres in my 8+ yrs of ownership thus far - on my 3rd set now.
  8. +1 There is known service campaign recall on the facelift Superb wagons for weak/faulty boot strut hinges. Recall No. 55N3
  9. Module 6D is the Deck Lid control module. Did u run scan for any errors?
  10. +1 8 plus yrs with mine - no flaking or peeling anywhere. Still in mint condition.
  11. Why r u so hung up on something showing up when u change the temp or airflow?
  12. no, nothing shows up or changes on the infotainment screen.
  13. I haven't replaced or updated the Climatronic on mine - it came like that from factory. Doesn't matter wat screen it's in, if I press the seat button, a small pop-up will show, not the full Climatronic menu. I can then adjust it on screen or continue to adjust via that small pop-up. MIB2.5 Home screen.... Android Auto screen.....
  14. These r my seats - leather seats, powered, heated, ventilated. My 08 Air Conditioning module is:- Software number: 3V0907044DT Software version: 4101 Hardware number: 3V0907044DT Hardware version: H34 My car is MY17.
  15. It's the same MIB2.5 9.2" Columbus Unit, just dressed up in a different surround - Superb vs Kodiaq. The Climatronic will b the same too, just different trim surround again.
  16. I have MIB2.5 High and heated/ventilated leather seats on my Superb, and when I press the Seats button on the Climatronic panel, I get the popup on the Infotainment screen to adjust the heating/ventilation levels. Pic below is after I pressed both driver and passenger seat buttons.
  17. Previously, I had tried to enable Easy Entry Seats on my MY17 Superb - no luck. However, after doing a MIB2 to MIB2.5 conversion recently - Easy Entry is enabled and working!! I wasn't expecting that as part of the conversion. I didn't do any code changes, nor changed my seat module (36). It is 5Q0959760C (both HW and SW)
  18. +1 There is a reason why many of us have either fitted the start-stop memory module or permanently coded it out. I have the memory module myself so I can still choose to use it, when I need it.
  19. Sorry, but I have to disagree with that. If aimed correctly, the bi-xenon headlights have a good spread and throw. Have a look at the vids below, from my MY17 Superb. The factory Osram D3S xenon bulbs r good. Upgraded Phillips xTremeVision Gen2 D3S xenon bulbs r much better. Upgraded J.W.Speaker D3S LED bulbs r really great!! Vid of factory xenons.... Vid of Phillips xenons..... Vid of J.W.Speaker LEDs.....
  20. U can stop it from doing that permanently by disabling "Overtaking Right Prevention" using OBDEleven or VCDS.
  21. It most definitely will NOT brake!! Trust me, I know, whilst doing 80 km/h towards a car already stopped at the lights!! ACC relies on a moving reference target (in the same direction and lane as u r travelling in) to determine if it needs to slow down. A stationary object (car stopped at the traffic lights) will NOT tell the ACC on ur car to slow down gracefully. Instead it will scream "BRAKE!" at u, and then hit the stationary car/object that was stopped at the lights....if u don't react on time jumping on ur brakes!! Manoeuvre Assist (available from MY18 onwards) will actually stop u from hitting something, but only works at below a certain speed, i.e. parking speeds. It won't stop u when travelling at normal speeds on the roads.
  22. any pics of the said place? i strongly believe my brakes need this treatment.....
  23. I used to have VCDS at first. Used it for a couple of years, but sold it as I only had 3 car user license and wanted to help others with coding, but couldn't. 5 yrs ago I switched to OBDEleven Pro, with lifetime warranty. No yearly subscription. Being using it since then. I only do long coding or adaptations, no one touch apps. I can do the same things using OBDEleven that I could with VCDS. Very happy with it and no regrets. The one thing I miss from VCDS is that the CSV extracts of the admaps and blockmaps are much much better and easier to deal with. The OBDEleven extracts r hard to work with.
  24. Mk4 Superb is MQB EVO. Hence 5D is not applicable to mk3 Superb. Mk3 Superb (pre-facelift or facelift) is MQB (1st Gen). No point trying to fit a VC from a Mk4 Superb into a Mk3 Superb!
  25. 5C is the latest anti-theft system. 5A is the old anti-theft system. 2015 to 2019 use the 5A anti-theft cockpit. 2015 to 2017 r MIB2 units, but can't connect to VC. 2018 to 2019 r MIB2.5 units. These can connect to VC with fiber optic. Superb produced after 2020 is classified 5C anti-theft. 5C is Ethernet based. Facelift uses MIB3 units. If the anti-theft system and the cockpit do not match - it won't work.
