JR RS
Everything posted by JR RS
  1. The Superb doesn't have adjustable suspension, instead it has Adaptive Dampers (shocks), if optioned. The springs r ur normal coils of steel. Springs come in different flavours, based on engine size, sedan/wagon, and AWD/FWD. Make sure u get the right one for ur setup.
  2. U can get the mk3 puddle lights from plenty of places such as AliExpress or eBay, however watch out for their quality. I would recommend from Kopacek. http://www.kopacek.com/Skoda/SUPERB-III/Superb-III-MEGA-POWER-LED-mirror-downlight-KI-R As for the puddle lights - mine r already bright. It's the factory LED ones. If u do end up needing to change ur puddle lights, b careful not to break ur wing mirror glass in the process!!!
  3. Finally Google decided that today was the day for my Pixel 5 and my MIB2 (Superb MY17) to get the Coolwalk update!! Initial experience is positive. Mine is running through AAWireless and I can change the DPI setting which influences the layout. Mine is currently set to 128 DPI.
  4. I "enabled" Air Care on my Superb, however it won't "activate" despite meeting the required conditions to operate. Anyone have any ideas why it's not working? I wonder if it's because of the cabin filter currently in the car. There r 3 types - Normal, Coal, and anti-allergenic versions. Any help would b appreciated. Coding done..."Filtering of interior compartment air" changed to installed. Air Care now shows on Climatronic.. Unfortunately ticking the Active option does nothing....
  5. Likely the previous owner was constantly towing heavy loads, that the springs have literally lost their ”spring in their step”!!!
  6. The sensors (2nd pic) r two long strips that r placed inside the rear diffuser, as shown in the 1st pic.
  7. I put Auxito T10 W5W LED bulbs in the glovebox about 4 yrs ago. It is still going good, no issues with it - open or closed, moving or stationary. I put Kopacek (Superskoda) units in the boot and door warning lights - they too r still going great. https://www.ebay.com.au/itm/372661798890?mkcid=16&mkevt=1&mkrid=705-154756-20017-0&ssspo=Z15-RgX2SWu&sssrc=2349624&ssuid=lD_jGR-4Tj6&var=&widget_ver=artemis&media=COPY
  8. Thanks for clarifying @fencer 👍
  9. Most new Skoda vehicles being delivered here don't have engine covers anymore. It's not just Skoda - VW cars too. The latest crappy hard/soft foam engine cover is a fire hazard - hence why they're been dumped, literally. I'm glad I don't have the latest EA888 Gen3 engine in my Superb cause I like my covers.
  10. I don't believe so. He said he's got metal clips in the headlights - it means he's got version A headlights, hence he has non-SLA headlights. He can activate the auto high beams, aka High Beam Assist (HBA). If it had the round green clip holder, instead of the metal springs, then it would b the version B headlights, hence it could do the fancy auto high beams, aka Smart Light Assist (SLA).
  11. Never use the same original bolts if ur using spacers!!!! U MUST get longer bolts that match the thickness of the spacer being used.
  12. U can activate it using the instructions below, provided u have the correct A5 camera.....
  13. I put Phillips XtremeVision Gen2 D3S xenon bulbs in mine almost 4 yrs ago. They're brilliant. https://youtu.be/h4MRMKYGTTY
  14. there is a setting "Light Sensor sensitivity" in the infotainment, under Light Settings, to select Early, Medium or Late for the auto headlights. have u tried that?
  15. In my case, I didn't have to physically change the Gateway (3Q0907530C) or DCC (5Q0907376A) module. The guy who did this for me used VCP to update the software versions and upload the parameters. I don't know the VCP procedure/steps involved. I'm not sure wat tools he used to source the software and datasets. It's a cost service he's offering - so he'll b keeping it a "closely guarded secret".
  16. No, it's not unintentional - it makes total sense now that I've read the SSP on DCC. The algorithm influences the shocks behavior and the power steering responsiveness. The parameter dataset is not "generic". It is the same dataset used by the Arteon and Passat B8. They come from factory with the DCC parameter dataset. Pretty sure "other things" won't b changed, or have unintentional behaviors.
  17. A few days after getting the DCC Slider mod done, i was wondering why the Steering felt "different", e.g. in Normal mode, the steering weight was slightly heavier/firmer. In Comfort mode, it felt less disconnected and more like Normal. Thanks to @varooom sharing a link about the technical workings of the DCC system - it shows the power steering module is part of this system too, as it interacts with the DCC module. Hence it seems the new DCC parameters/algorithm better mapping has also improved the steering weight/feel. An added bonus I wasn't expecting with this mod.
  18. so ur passenger seat has the memory seat buttons, like the driver's side? maybe it is a new thing on the facelift Superb. i'd b very surprised though. like this.....
  19. 500+ horses!!! Have u got a TCU (DSG) tune? If not, getting it might allow u to unleash more Torque.
  20. It doesn't matter wat MIB version u have as it also works with MIB2 units. Provided u have the right Gateway and DCC HW modules, which mine already had. Just needed updated SW version. I have an MY17 and I got the DCC Slider mod last Friday - everything works. The new DCC parameters r simply brilliant. The car has transformed. It feels more composed. It has completely eliminated the remaining bounce effect. Suppa duppa pleased with it 👍🏽 Forget getting aftermarket dampers - get this mod! I had already done the DCC recalibration a while ago so there was no need to re-do that again.
  21. I'm not aware of any Superbs that came with a Passenger's "memory" seat. Driver's memory seat - yes. Most cars do not have memory for passenger seats. Passenger Electric seat - yes Passenger Electric memory seat - no, at least not that I'm aware of.
  22. Thanks for that - exactly wat I was looking for cause I remember it having some diagrams that might help - I just couldn't find it. It shows the location of the accelerometers on pg 24 - G341, G342 and G343.
  23. hmmm.....unfortunately i have no idea about the DCC accelerometer locations. i didn't realise that was a thing. i'm only aware of the suspension level sensors that DCC module uses, as well as the headlights for levelling. there is two up front (one on each suspension control arm), and one at the rear, on the left suspension control arm.
  24. i have not heard of any Skoda dealers, anywhere, doing retrofits like this - so good luck. but if u did manage to find one that will do it for u, it will basically involve:- - removing existing USB port in the front to access USB data wiring to the infotainment. - removing centre console attached to the armrest storage so u can route the wiring and put the additional USB port in the blank space. - spicing into a 5V power source, for the USB hub module. - coding in the infotainment to enable the additional usb port.
  25. Tis a bit of a hassle, but doable. If u want to retrofit it, u basically need the following:- - 5G003595D - USB HUB to 3 ports - 3G0035643- holder of the HUB - 5G0035222E - Volkswagen MIB2 Carplay USB/AUX Port Audio Input Socket Harness Plenty of kits can b found on AliExpress or eBay.
