Everything posted by sepulchrave
Starting problem
The injectors are controlled by the ECU switching them to earth so I would look for an earth connection fault from the ECU itself.
- New purchase likes drinking oil…………. Cthe vrs
What's seeing off all the Fabias?
I recall when there were a lot of VERY silly townie boys with VRS's on here...
Intercool Pipe
As long as it's not leaking then it's fixed.
Front caliper nut rubber covers
I don't know.
Skoda Fabia 1.2 07 petrol engine 120k burning oil fast likely valve seal or piston rings - no sign of leak.
Start with the diagnosis, you need a compression test done to determine whether the piston rings are sealing properly or not. Then you need to make sure the PCV system is working properly.
Skoda Fabia MK2 exhaust manifold red glow....??? is that normal
The only thing to check is that the exhaust valves are sealing properly for which a leak down test is needed.
- 69 replies
- 1.2mpi
- 3 cylinder
- fabia2
- skoda fabia
Tagged with:
I wouldn't worry too much about spark plugs right now, they have no bearing on the oil consumption issue we're discussing. Some people will post what they know rather than what you want to know whether it helps or not. Get the test done then post back with results, my sense is that you have bore glaze.
- Standard OEM Owners
Fabia VRS LE Register Part Trois
Instead of being maintained and repaired, low mileage cars age badly due to lack of use.
History and condition are far more important than mileage, you'll always pay a silly premium for low mileage cars and they're always more trouble than high mileage cars which have been well maintained.
Fabia 1 vRs drivers floor mat and clip
You're out of luck, those mats went out of stock anywhere a long time ago and are now deleted and cannot even be ordered.
Side Mirrors, Electrical folding or not
Big, wide cars have electrically folding wing mirrors, the little Fabia doesn't really qualify!
VCDS doesn't have a clue, there's no thermocouple fitted to that petrol engine.
- 69 replies
- 1.2mpi
- 3 cylinder
- fabia2
- skoda fabia
Tagged with:
That's not 900 degrees because you're looking at it in the dark, look in daylight!
- 69 replies
- 1.2mpi
- 3 cylinder
- fabia2
- skoda fabia
Tagged with:
- What is the problem in sudden drops of RPM with EPC randomly going off and on and the engine icon flashing?
- 69 replies
- 1.2mpi
- 3 cylinder
- fabia2
- skoda fabia
Tagged with:
- Skoda Fabia MK2 exhaust manifold red glow....??? is that normal
Stop looking at it! The cat will be working perfectly.- 69 replies
- 1.2mpi
- 3 cylinder
- fabia2
- skoda fabia
Tagged with:
