travs
Everything posted by travs
  1. Any links to mibsolution will be broken as that site seems to be down. That's where everyone was getting them from up until now I think. I've created and uploaded 308 and 330 now so download at your leisure. Trav's Mega site
  2. Firstly, I'm talking rubbish - 332 is the one out a few months ago and that's fine. Literally no difference to 330. But I can't find that in my downloads, I must have deleted it. Anyway, you only need 308 as the springboard to all the rest; and then you can skip 324 (the only other one I can remember between 308 and 330). So I have got 308 but I'm trying to find the link to Vegarz FTP site (rather than just the files) as he has a load in there...ok he doesn't. I'll see if I can setup a mega.nz site and then I'll share it
  3. Actually, you're in luck. A chap on here, @vegarz host some and has this link to v330 from his ftp site. MOI3_EU_SKMQB_P33000P_0330 .zip From this post @Dave77 https://www.briskoda.net/forums/topic/523535-mib-3-from-0270-to-0330/#comment-5851709
  4. The link is probably to mibsolution but have just found that its down at the moment, which is not good. Best bet is to trawl through the audio electrics and security forum to see if there is anything there to link to perhaps...
  5. I've got a downloaded zip of 308 and 330 I've just found. I've been running 330 for a few months and its fine; no obvious differences between 306, 308, 324 and 330 from my experience. Not sure what's the best way to send it though
  6. If its 2023 then its not a new vehicle. In which case it looks like its "standard rate of VED" which is £195 from the following article: Autotrader article Quoted as: Tax bands for cars registered on or after 1 April 2017If your car was registered on or after 1 April 2017, you’ll have to pay the first 12 months of tax when your vehicle is first registered. After this, you’ll pay the standard rate of tax every year. Standard rate VED for cars (applicable from second tax year onwards): For the financial year 2025-26, the standard rate applicable to all cars is £195. Drivers of a fully electric or hybrid car will also pay £195 standard tax now as compared to last year when they got a discount. The first year VED is graded on emissions so it would depend on the engine as follows: First-year VED in 2025-26: If this is the first time you’re paying tax on your car, the first-year VED rates will be as follows: • Band A: Cars that produce 0g/km of CO2 will pay £10 in VED • Band B: Cars that produce 1-50g/km of CO2 pay £100 • Band C: Cars that produce 51-75g/km of CO2 pay £130 • Band D: Cars that produce 76-90g/km of CO2 pay £270 • Band E: Cars that produce 91-100g/km of CO2 pay £350 • Band F: Cars that produce 101-110g/km of CO2 pay £390 • Band G: Cars that produce 111-130g/km of CO2 pay £440 • Band H: Cars that produce 131-150g/km of CO2 pay £540 • Band I: Cars that produce 151-170g/km of CO2 pay £1,360 • Band J: Cars that produce 171-190g/km of CO2 pay £2,190 • Band K: Cars that produce 191-225g/km of CO2 pay £3,300 • Band L: Cars that produce 226-255g/km of CO2 pay £4,680 • Band M: Cars that produce anything above 255g/km of CO2 pay £5,490 as the first-year rate
  7. Oh and yes longer bolts for spacers (sorry for missing that earlier). The existing bolts for mine were 38mm long thread so added the 11mm to get 49mm. The ones that I think came with the spacers were 50mm. You definitely don’t want to skimp on that!
  8. Could do - although if the car doesn’t feel down on power when you’re on the move then the rolling road won’t give you much info I don’t think. Have you tried any type of scan to see if there are any fault codes logged?
  9. Sounds plausible - shows how old my understanding is! Good research 👍
  10. Googled and known issues with waterpump or thermostat housing leaks but if the level is correct, it doesn’t sound like you’re losing water. In which case. I’d thinking about thermostat sticking? It should open and close with the temp of the water but if it’s stuck and not opening fully then the water doesn’t get to run through the radiator sufficiently? Just a massive guess though
  11. I have no idea how the pedal box affects the 1.4 compared to the 2.0 280 - I can believe they’re different naturally but if there is one for the engine, then there must be some sort of market for it. If the car is manual, then there’s probably less of an issue - as @leolito said, some of this is down to the DSG box and how the throttle interacts with that. As for the spacers, it’s far more about aesthetics than handling; it’s an argument that a wider stance could equal more lateral grip but (a) it’s largely setup specific and (b) I have no idea if there is reduced grip in other ways. As others have said there are better more directly relevant ways to improve handling such as rear arb, or stiffer springs 👍
  12. Not if it’s 2016 and that wasn’t a typo. Mk3 only came out in 2015 so it’ll be a fairly early one. Easiest way to tell is whether it has the roundel on the boot or SKODA in spaced out lettering. The front and rear lights have also been changed but that’s more subtle. Let us know how you get on 👍🏼
  13. This one (still pinned to the top of the Mk3 thread
  14. FL is facelift - and there were differences between the MIB and things that could be adapted. So you’ve linked to the VCDS page for the facelifted Mk3. There is one for the non-FL too which might help. Pre-FL was to May 2019ish then FL from there. You def have pre-FL version.
  15. Mine was advised (automated email sent out by Skoda) at the 2 year mark - has been done twice now at about 12k miles between both. Had pictures from the first one and that was bad enough.
  16. I think the problem in this thread is that there is a lack of communal info to answer. There are a few specialists who’ll know but if they’re not on here then you may have to wait a bit.
  17. Will be a shame for the Superb forum to see you move to another model. Good to be staying in the fold though 👍
  18. Have you spoken to TVS about this? Could be something they'd look at; in fact you might find a TCU remap would leave the Sport shift points alone. They're looking for optimum shift points, which may already be the case for the car in Sport and not need to be messed with...
  19. I’m in a WhatsApp chat and someone posted the other day about a grey estate tuned one in Gainsborough for sale on FB if you want to add that to the options list. I can look into it if you’re interested. I don’t know anything about about it and the seller but you can do your digging on that if you wanted?
  20. No probs. The pedal box is very noticeable. It has Eco, Sport and Race (with a +variant for each). I put it in Race+ and enjoy the relative hairline trigger throttle. Spacers - this is a bit of a bigger topic, depending on what you want. The obvious point is to push the wheels out closer to the wheel arch body line; so you want to be sure that you don’t foul the inner wheel arch. You also want hubcentric spacers as these are machined to sit on the hub so they’re absolutely true. Non-hubcentric spacers have a small risk of not sitting quite central and causing vibrations but not sure of the reality of this. the other point about spacers is their impact on performance - whether they improve lateral grip by a wider stance, or mess it up by impacting the scrub radius. But these are probably more relevant to tracking than driving on the road. I went with 11mm because running 8” by 19” and 245 tyres which are a little wider than standard. Others have experienced a little rubbing on 15mm at the rear so I just stayed with 11mm all round.
  21. Depends which aspect of performance you wanted. Better go usually means better stopping is advisable so you could get some better discs and pads; not necessarily bigger but drilled/grooved will stop heat fade so much; ceramic pads are lower dust as well as better performing over original. And braided brake hoses will stop any loss of brake fluid pressure albeit under relatively heavier/more sustained braking. Rear anti-roll bar is useful to keep the rear from rolling if you’re going round some bends enthusiastically. Otherwise, depends on budget and what you want - drop in a v8 lump? 😬
  22. Dimming or dipping? My passenger-side should auto-dip and it’s stopped doing it. Needs a reset or something but can’t remember what I need to do
  23. Ouch - but that’s the point of sleepers I suppose. Diesel remaps can achieve mountains of torque and you don’t need to change down to press on.
  24. Lots of things changed with the facelift. Main cosmetic ones to quickly identify I’d say would be Front lights/bumper changed, rear lights updated with chrome strip across the boot lid. Changed from emblem to SKODA letters across the rear. As for digital dash, it went from option to standard in some models - pretty sure it’s standard in facelift L&K but seems to have been an option pre-facelift. Same with 280 sportline plus - was sure I’d seen some with and without but not sure on whether it changed as part of the facelift.
  25. @Itsrelfy I second this. Have had it since Nov 22 and absolutely no problems whatsoever.
