CJJE
Everything posted by CJJE
  1. CJJE replied to yosser65's topic in Skoda Karoq
    No it doesn't have the retractable parcel shelf - it has a rigid shelf which hinges up with the tailgate - or can be removed. The rear seat folds down, but does not slide, so the boot space can't be expanded like Karoqs with the VarioFlex seats. The front seats are very comfortable I find, but may not be to everyone's preference. It also has 19 inch Vega wheels, which some say they find uncomfortable, but as I opted for the DCC option mine are fine. I am a bit wary of kerbing them though as diamond-cut wheels are easily damaged. I much prefer the fully painted bumpers over the grey ones fitted to other Karoqs, but check out the full spec here: ŠKODA KAROQ SportLine | New 2020 Model | ŠKODA UK (skoda.co.uk) Chris
  2. CJJE replied to paco's topic in Skoda Karoq
    Yeh, well I'm down south and not allowed to come to play in the North yet! Normally I'd be planning a visit to The Trossachs this Spring, but who knows when I'll be let through the border!! Chris
  3. CJJE replied to paco's topic in Skoda Karoq
    Mine has on occasion, but only when the weather was very cold (around freezing). Chris
  4. I see that according to Autocar: "Skoda Sales & Marketing boss, Alain Favey, will move to fellow Volkswagen Group brand Bentley later this year to replace Chris Craft. Favey, whose career with the VW group stretches back to 2009, and includes stints at Volkswagen, Porsche and Skoda, will oversee product launches with the |British luxury brand from June as it progresses with its 'Beyond 100' electrification strategy. I'd hope he'll listen to Bentley customers better than he has to us, or he won't last long there! No news yet on who his replacement will be. Chris
  5. CJJE replied to 1stkaroc's topic in Skoda Karoq
    MIB3 systems are 'supposed' to get 'local' updates online as soon as they are available, but my car is still showing version 19:11 so it is not obvious if I've had any. If you set up a route to a different country, then it is 'supposed' to update maps used on the way. But again I have no evidence this is actually happening. The MIB3 system is a disaster in all VAG cars, and it is about time the motoring press started reporting it instead of regurgitating their old tests on MiB2 cars! And if you have a look at the German Karoq forum (Skoda Karoq Forum – Die deutschsprachige Karoq Community) you'll see they are equally incensed over there!! Chris
  6. CJJE replied to 1stkaroc's topic in Skoda Karoq
    I suspect it was designed for European postcodes, not the UK ones which for domestic locations can cover quite a wide area - which is why if you enter a postcode it locates to the central off-road position rather than an address. Due to a lack of long-distance travelling I haven't yet had to try it out, but if you enter a full address will it take you to that house? Chris
  7. CJJE replied to 1stkaroc's topic in Skoda Karoq
    Yep, you've discovered the design bug in the new MIB3 satnav systems fitted to all VAG cars now. Keep complaining and perhaps someone will realise it's stupid and issue a software update. (You'll see similar complaints in several sections of Briskoda, and also other SEAT and VW owner forums! I'm told that if you store the destination with your own name, it'll remember that. But I can't comment on how well it navigates there due to covid lockdowns! Chris
  8. When I fitted mine, the first went straight on and stayed there... but the second one worked it's way off as I tightened the bolt. Pushing it right up and not over-tightening the bolt seemed to work. But I haven't driven any distance since to see if it stays there! The U bracket has two 'bumps' on the inside that I suppose are intended to penetrate the plastic tongues to keep it on, but I also made sure the sliding part of the U bolt was turned so its edges would also 'cut' into the plastic tongues. Chris
  9. I believe the Skoda Connect icon is in the main menu rather than the nav system, but I've also seen a statement on the Skoda Connect Portal website saying this function isn't available yet. Chris
  10. I would have expected your dealer to have set this up during the Pre-Delivery Inspection (PDI) as it would be very dangerous to have the speedo reading in km/h instead of mph! But having set it correctly, I can't see any reason for it to change unless you have the personalisation option and have somehow set it up so that one of the keys resets it to Km. If it persists, I think a call to your dealer is called for! Chris
  11. And you can open them later without needing a current licence?? I've read that they are locked documents that check with base that you are still allowed to open them... and that 'Print to PDF' is disabled? Chris
  12. CJJE posted a topic in Skoda Karoq
    All VAG cars used to have a sticker detailing the build of the car in the service handbook, and also in the boot. This included a list of PR option codes, as well as the paint code etc. Now obviously we no longer have a service handbook with it, nut I can't find it under the spare wheel or the plastic wheel surrounds in the boot of my car either. Anyone know where it might be nowadays? Chris
  13. I wrote this late last night, but I'd like to correct a typo in the third para! I put the steering on full right-hand lock of course - not fight-hand! Chris
  14. Having just fitted mine yesterday, I'll summarise how it went. The rears were fiddly with the wheels on, due to the lack of space between the tyre and the wheel lining. However, removing the existing Torx screws was easy with an L-shaped Torx driver, and the same screws were then used to hold the mudflap in place. The expanding rivet was a pain to fit in at first because I was trying to put it in the hole nearest the outer edge, but went in a lot easier when I put it in the inside hole. The pin was very reluctant to push in even after lubricating it, but tapping with a small hammer (carefully!) finally got it in. The push-in plug went in under the bumper easily. The front ones had better access once I put the steering wheel on full lock. Working on the near-side, I put it to full left-hand lock, and removed the lower Torx screw from the lining, replacing it with the mudflap. Then mark the position of the new top hole. Remove mudflap, and the next Torx screw above it. This gives you enough flexibility to pull the lining forward and protect the car body with a strip of wood. I then drilled the required hole for the expanding rivet, and replaced the two Torx screws with the mudflap. Putting the steering to full fight-hand lock gave me room to drill the inside hole. The expanding rivets were again a pain to get into place and secured with the pins. The front wheels are now in the right position to start on the off-side mudflap. The official instructions tell you to put the car on a garage lift and remove all wheels. But for the owner doing the job at home on the drive, it's easier to do it as we've described above. Chris
  15. The Machine Mart website at Trolley Jacks & Car Jacks - Machine Mart give you a choice of weight limits and lift heights. To be sure you're getting one that lifts a Karoq high enough, you could lift it with the normal jack and measure the gap between the car and the ground, or even just wind the scissor jack out on its own and see how high it will go? And having found the instructions with my jack I see it's overdue for its annual oil and grease! Must see where I can find an ice hockey puck too! Chris
  16. I bought a Clarke CTJ2Q from Machine Mart 8 years ago or so (when I was swapping summer/winter wheels on my Golf Plus, and then Golf SV.) It has a 2 tonne capacity, a minimum height of 135mm and a max of 380mm. The current equivalent seems to be the Clarke CTJ2000LPB 2 Tonne Low Profile Trolley Jack at £41. It works well, and has had no problems (but I haven't had any need to use it with my Karoq yet. Chris
  17. The basic icon is the one for the Front Assist system, with the egg timer showing that it is activating. So if it goes out, everything is fine. But if it turns red, or stays on check the manual, which suggests there may be a fault in the front sensor, or you need to clean the front grill. Chris
  18. Very odd. It could be just checking for updates (of traffic conditions perhaps) for some reason, but I'd assumed that would only happen when the ignition was turned on. Chris
  19. The advantage of the Connect Lite app is that it is free once you've bought the dataplug, while the My Skoda app required you to subscribe to the Remote Access service after the first year. If you don't need all the functions this provides then the Connect Lite app is a cheaper alternative! I already have the dataplug from my old Golf, so will probably switch to Connect Lite when my first year's licence for Remote Access expires (I hadn't tried using them both ) Chris
  20. CJJE replied to Karman's topic in Skoda Karoq
    That's the problem with LED headlights. A few years ago, everyone was raving about their LED headlights, and I was thinking my Bi-Xenons had been superceded. But having now changed cars and got LEDs instead I can see that they don't generate the heat like my Bi-Xenons did... so the condensation doesn't evaporate, and the snow/ice on the glass doesn't melt off! They may now be cheaper, and more fuel efficient, but the older technology still wins for me!
  21. People who have problems rightly tell us about them. But people without problems don't! I've always had sunroofs on my Golf 4, Octavia, Golf Plus, Golf SV, and now my Karoq. I've never had the water leaks described above, and wouldn't be without a sunroof! Chris
  22. MY21 Karoqs have USB-C ports, and my Android phone uses Android Play via Bluetooth. I'm pretty sure that Apples will as well. But perhaps you'd find it worthwhile downloading the owner's manual to check there?? It's at: ŠKODA Owner's Manuals (skoda-auto.com) Chris
  23. The slim spacesaver wheel is around 12.5 cm deep instead of the standard wheel's 22.6 cm, but to reclaim all this depth you'll need to change the polystyrene packing pieces and central support.
  24. My letter to the Head of Customer Services last December has also been ignored. So I emailed the Karoq Product Manager, Charlotte Moss ([email protected]) feeling she should be aware of the MIB3 problems. She didn't reply directly, but at least I got an email in reply from a Dean Goodwin, Customer Relations Manager ([email protected]) so at least I've got an email address for Customer Services now. His reply was basically telling me that the MIB3 design would not let us update maps locally, or add radio logos. But the really poor part was when he was telling me how to get web radio to work. All he did was paste the paragraphs from the owners manual (losing the formatting and pictures/graphics in the process so that it became unintelligible). And since I'd already read and followed this it didn't help. I emailed him back pics of the infotainment screen as I tried to access web radio stations, but haven't had a reply again. (I've since discovered that it won't work unless you buy a dataplan or use your's phone's data allowance - which seems to be more than he knows!! One of us wrote to the Head of Skoda UK, which also produced a response, but it's really bad if you need to do that to get attention! Chris
  25. Yep, it's a common problem across all VAG MIB3 systems. The 'edit' function for radio logos only seems to let you choose the one you want to use when there are several to choose from. Interestingly, Greater Hits took over Signal Radio in Stoke last summer, and rebranded Signal 2 as Greater Hits Staffs. But it still uses the Signal 2 logo!
