Everything posted by CJJE
Karoq front badge
I went for the Superskoda one too. It looks great matching the paint colour.
Breakdown cover
You can download the policy details from the Skoda website. Because it includes European cover I found it cheaper to go elsewhere (for a UK only policy) after 3 years rather than renew the Skoda cover. Chris
Digital Service and Warranty Info
If you log onto the Skoda Connect website you can generate a 'Digital Certificate' for your car. This will detail its mileage records, service records, and warranty details. It also claims to list the standard and optional equipment fitted, but mine is not completely accurate. Chris
More Kessy madness
I guess the metallic lining can deteriorate, but it shows the wisdom of testing it now and then. However, remember you can turn off the KESSY system when you lock the car ( such as overnight or in dodgy areas) by locking it with the key fob and then touching the dimple within a second. The indicators will flash twice, and you have to open the car with the key fob next time. It's all belt and braces anyway as the key fob will stop sending a signal if it is left stationary for a few minutes (for recent cars). Chris
MIB3 and USB sticks. Forgetting what it is playing
Thanks for the update. I'll have to look after mine!! Chris
I'd recommend one of these: Integral 128GB Fusion Dual USB-C & USB 3.1 Flash Drive - 200MB/s £19.99 - Free Delivery | MyMemory as it avoids any problems with adaptors and sits under the sliding lid. Chris
Some Facelift SportLine Questions
The original Sportline had the 10.25" digital instruments as an option, and the big benefits of the facelift (in my opinion) is that it has Matrix LED headlights and dynamic rear indicators (as standard I think). (The basic digital instrument panel seems to have far less customisation options from comments on this forum.) However... many individual options on the original are either bundled together, or not available. For instance I was able to add a heated windscreen as a single option without buying heated rear seats for my non-existing passengers. The dashcam charging USB-C socket by the mirror was also available on its own. And the 360 degree camera which I love is no longer offered at all! I've had sunroofs on my cars for 40 odd years, and panoramic ones on my last two. The only problem I've had was on my Golf Mk4, where the sunroof motor failed after 7 years. Chris
Karoq Edition Baulking gear change
Posted in the Octavia forum, and should get more replies in the Karoq forum. Mine's a DSG so no relevant experience of this myself Chris
MMI and estetic issues
This thread seems to have got combined with some others... Varaderoguy and I were replacing the pollen filter and broke the little U-shaped 'hooks' on the pollen filter container that the bottom of the pollen filter cover fits into. With mine, the top clips still (kind of) engage in the housing, but the bottom edge is hanging free. I'm expecting it to fall away at some time, although the closed glovebox may be holding it in place while I'm driving. Chris
- MMI and estetic issues
- Been a numpty - Cabin Air Filter box - broken cover/surround
- Radio stations Logos database updates
Thanks MartiniB. The MIB3 (Superb etc) file loaded successfully into my Karoq's MIB3 Amundsen, and seems to have created some of the missing radio logos. (Pity I still haven't got any for Smooth or Classic FM though.) This is the first time I've been able to get it to update software via the USB-C socket, so well done! Chris
internet radio
Internet radio is arguably a case of mis-selling! I struggled for ages to get my Karoq to load internet radio stations, and even tried parking under a mobile phone mast to improve reception. But eventually I discovered the eSim in the car was not licensed to receive the data needed to listen to internet radio. Instead Skoda want you to sign up to an expensive monthly or yearly data pack to get this to work. (However I did find that it would work by using my phone as a data hot point, and setting the car to use that as a data source instead, and thought that might be useful when I travelled abroad on holiday.) Chris
Asking for Skoda Karoq 1.6 TDI 2019 All weather recommendation
Hi Josif I don't speak German either, but find the auto-translate function in my browser (Edge) works very well, with only minor mistranslations of technical jargon or idioms. Chris
Just cancelled
I used it regularly for many months, but turned it off again a few months back as I found it disconcerting when it disengaged under 40 mph. And even before that I made a point of turning it off in icy weather as I preferred the unadulterated feel of the tyres on tarmac. Chris
Just cancelled
On my Pre-facelift Karoq I can choose whether to use the Lane Guidance feature or not, and it remembers my choice (ie doesn't default to having it on each time you start the car.) But mine also only works over 40 mph so doesn't do anything in towns. Chris
Updating the infotainment system
@sussamb. If your Karoq is 5 years old, it will pre-date the latest MIB3 systems which download updates online. And if you have the Bolero infotainment system I'm assuming it doesn't have a satnav so there are no maps to update. The radio will be able to find new radio stations for you to save as presets, but you may well not have the pretty icons to identify them. But this is also true for the latest MIB3 radios as the file supplied by Skoda misses many common stations due to commercial restrictions I believe. Other than that, the dealer should check for any system updates that are required when your car is serviced, although sometimes they will only install the update if you have reported a fault which it will cure. Chris
Skoda Connect expiry
The Skoda Connect system has the following functions: 1) The eCall emergency call system, which will work for the life of the car at no cost to yourself. 2) The Proactive Service (Breakdown calls and Info calls using the buttons above the interior mirror) which will work for the first 10 years at no cost to yourself. This also includes obtaining a health report for your car via the app, Service Scheduling via the app, Online Personalisation to store your personal settings, and online system updates for the infotainment system - but the last is only for the app and shop settings, not map updates! 3) The Remote Access service is only free for the first year, and then has to be renewed annually. This lets you lock your car and receive messages from it via the app such as driving data, last parking position, vehicle status (doors & windows closed and locked and whether the lights are off) and anti-theft alarms. You can also sound the horn and flash the lights via the app to help you find your car in a big car park, as well as receiving area and speed notifications if you want to monitor someone else who is driving your car. You can also generate digital certificates recording your car's service history and mileage. 4) The Infotainment Online service is only free for the first year, and then has to be renewed annually. This provides regular map updates whenever you drive into a region that has been updated (typically I receive these every few months), online traffic information, nearby parking spaces and costs, nearby petrol stations and fuel costs, online route navigation avoiding traffic delays, online voice control if you want to talk to Laura, and sending a destination from the app to the car. I find the latter 2 worth the £80 or so each year, but others who prefer to use their phones instead will disagree. Chris
Yes, I had read that was true in Germany, and from what you say in France too. But I had wrongly assumed that Josif was in the UK where we don't have homologation certificates (as far as I am aware) so we need to fir the same size as that supplied by the manufacturer to avoid our insurance companies increasing our premiums for modifying the car. We also very rarely need to fit winter tyres, and when we do then we need to tell our insurance companies to avoid them voiding our policies. Chris
Hi Josif, I missed that you are in Germany where many drivers switch between summer and winter tyres on different wheels. The 16 inch wheels with a deeper profile will certainly be more comfortable than the 18 inch, and as long as the circumference of both tyres is similar you should be fine. the website Tire Size Converter will let you compare the two tyres. I think that there are also German websites that list the approved wheels and tyres for cars, and that you need to comply with these requirements to be legal. Apart from that, the use of bigger diameter wheels with lower profile tyres is largely a fashion-led drive to 'improve' their appearance and disregard their comfort. Auto Bild have excellent tests on all-season tyres, and the ones I listed before seem to come out top with them. You may also find the German Karoq forum of interest - Skoda Karoq Forum – The German-speaking Karoq Community Chris
I would stick to the same size (215/50 R18) to avoid any problems with your insurance company. The best all-season tyres in that size according to Tyrereviews.com would be the Goodyear Vector 4Season Gen 3 and Michelin's CrossClimate 2 or CrossClimate 2 SUV. Continental's AllSeasonContact 2 and Bridgestone's Turenza 6 All Season also have good reports but aren't available in that size yet. Chris
Weird event yesterday
Not really related, but when I went to open my frosty car yesterday morning only one door mirror folded out, and the powered tailgate was very reluctant to lift. The door mirror folded out when I used the manual control. I put it down to the frosty conditions, and reset the door mirrors to only fold and open manually. Chris
New Karoq Sportline
Emden is used for cars coming to the Midlands and north, but Sheerness is the one used for the south I believe. Chris
Travel assist unavailable alarm
Check your VIN on this Skoda Australia website: VIN Checker | ŠKODA Australia (skoda.com.au) This has been a common problem for VAG cars for years, but the Service Campaign 48S5 seems to have cured it for me with a software update. Previous attempts by replacing steering wheels were not a long-term solution. Chris
