Everything posted by CJJE
First aid kit
That must be part of the 'premium brand' marketing then, as VW and Skoda have never supplied first aid kits, warning triangles or hi-viz jackets in the UK in my experience. But at least we can have heated windscreens and umbrellas! With Brexit we're unlikely to join the EU safety requirements any time soon, so it's up to us to buy our own and transfer them from car to car with us. Chris
Current software versions for karoq infotainment
Skoda UK know all about the 48S5 Service Campaign, and dealers will follow its 'instructions' if owners report problems with false Travel Assist warnings. (They used to replace steering wheels as a cure but this procedure has now been superceded.) But it is not a 'Recall' and so will probably only be invoked when you report the fault (or perhaps when you have an annual service?) Chris
I'm assuming your car is a MY21 Karoq like mine, which gets minor software updates via its online data connection. (This means it will not have a SD card slot in the glovebox, and has 2 USB-C ports in the phonebox.) First of all, the main software is only updated by a dealer when he needs to cure a fault in the car, but if yours is version 0306, then you have more up to date software than me as my car is running version 0276! And this despite it having been in recently to have the Travel Assist bug cured. (Incidentally there is a current 'Service Campaign' 48S5 running to cute this problem, and you can find out if your car is affected by entering its VIN in this website - even though it is Australian! - VIN Checker | ŠKODA Australia (skoda.com.au) The map software in my car is currently on version 23.6 and tends to update itself automatically every few months. If your car has been sitting in a dealers for a while, then presumably it has not been updating itself, but it should update the maps by itself as you drive around (as long as you have a current Skoda Connect licence). Chris
- Alarm going off 30 seconds after locking...
Software Update
I had one of these on Wednesday too. The over-air updates are pretty minor, and can only be installed when the car is stationary with the ignition switched on. But in practice, whenever you stop at a junction of traffic light etc it will install a bit more by itself. Mine had installed after a few miles, but I haven't noticed any changes. Chris
How do you set the "Speed Limit warning" ?
I tried this early in my ownership of my Karoq, but quickly found it was a bad idea. (Sorry it was so long ago that I cannot remember where I found the settings in the menu system.) Unfortunately the dynamic speed limit display is not accurate enough and so you get countless false alarms. Road signs can be covered by overgrown bushes etc and not seen by the car. Or it will see signs applying to joining roads and junctions and think they apply to you. And it cannot read signs saying "20 when lights flashing" or "40 for HGVs over xx tonnes" etc correctly. Instead I use the speed limiter control and set the limits myself by flicking the stalk up or down when I see the speed limit signs. Chris
Protecting User Profile
I also get these messages but just ignore them. I seem to remember when I first got my car that there was a setting in the profile screen that let you use the S-PIN to lock your profile, but that you then had to enter the S-PIN every time you started the car. (But it was over two years ago so I might be misremembering this.) Anyway I decided it was too much of a faff as I'm the only driver so I just left it displaying its warning message instead. Chris
Which Karoq DSG?
The varioflex seats seem to leave less legroom in the back, which was one of the factors leading me to buy a Sportline with the standard seats. However these will also be fitted to the SE Drive as standard. Although the SEAT Ateca is closely related, its suspension is set up for a more sporty ride, and so will be less comfortable. And as threads here will tell you, the bigger the wheels on your Karoq, the less comfortable the ride is. I've driven a 1.0 TSI DSG Kamiq as a courtesy car when my 2.0TSI DSG Karoq was being serviced. It was acceptable from a performance point of view, but I wasn't convinced about any fuel savings as I found myself using full throttle far more! Chris
Electric Tailgate
No problems myself after 2 1/2 years, but a thread here reporting a problem with wires breaking at the same place. Electric tailgate stopped working - Skoda Karoq Forums Chris
Trip Odometer
Nor me 😞 Did you have the car from new, and so is it out of warranty? Or do you have a used car warranty on it? It sounds like a dealer job to me. Chris
Trip Odometer
Hi Tigerfeet, Mine has the virtual cockpit, and resetting the trip odometer (when I fill the petrol tank)is a bit of a pain as you have to dive into menu settings to do it. If you have the analogue cockpit with a button to reset the trip odometer, then a connection problem there could well be the reason. But with the virtual cockpit, a bad connection that only affects the stored mileage seems fairly unlikely unless other settings are also being affected. Chris
Karoq Fuel Flap won’t open
It's easy to check that the latch is moving freely when the fuel flap is open. Mine seems OK, but I gave it a squirt of graphite to lubricate it just in case.
Trip Odometer
Mine has done the same a couple of times, and when I reported it to my dealer they said they would update the software to prevent it happening again. As it only happened twice over several months it's too early to say if they have cured it. The main reason my car was booked in was to cure the false travel assist warnings, which is now the subject of 'service campaign' 48S5. As that seemed to be temperature related to me, and had already stopped happening in June, again it's to early to say how successful it's been.
Karoq Panoramic Sunroof Seal
The seals are not completely water tight anyway, and there are drain 'pipes' at each corner to let rain water out. So I'd say it is mostly a cosmetic problem (unless it gets attacked again?) Chris
Dealers exclusive invitation - anyone else?
OK, I've had a phone call from my friendly Skoda salesman, enquiring whether I'm thinking of P/Xing my 2 1/2 year old Karoq yet. I presume they're looking for people whose lease deals are close to ending, but in my case his records should tell him that I specced the car as a factory order, and bought it for cash with a 5 year warranty! (My practice is to keep my cars for at least 5 years, and usually more.) And if he checked with his service department he'd know I'd driven less than 10,000 miles last November. He was very eager to tell me about the special deals he could arrange, so they must be having a sales push. But even if my wife would let me change cars so soon, he can't replicate the extras on my car such as the 360 degree Area View, or the Race Blue paintwork! Chris
General tyre query
I'd be wary about mixing all-season and summer tyres, and always prefer to change all 4 tyres at the same time to have the same make and type.
Online infotainment renewal
Interesting. The Skoda Connect portal is still offering me updates at £36 and £44 for each of the two services, while I thought the 'official' price was £55 and £65. But I can't find the higher prices quoted anywhere now so perhaps it is always £36 and £44. I prefer to use the car's satnav rather than my phone, but in your case (and if like me you ignore the voice control gimmick) then I agree you probably don't need the online info licence. Chris
Travel assist unavailable alarm
My car is booked in to get this fault rectified again, after having had one new steering wheel fitted 18 months ago. But I have just discovered this Skoda Australia website VIN Checker | ŠKODA Australia (skoda.com.au) that will tell you if your car has any recalls or service campaign request due. To my surprise when I entered my UK car's VIN it told me there was a service campaign / recall number 48S5 overdue! This was issued on 05/04/2023 (not clear whether this was the 5th of April or 4th of May) and concerns the S-Assistance Systems camera control unit. (I will be mentioning this to my dealer when I take my car in to make sure they are aware of it.) As this is one of the sensors that can trigger the Travel Assist fault, perhaps they are now patching the software rather than replacing steering wheels? Chris
My understanding is based on a MIB3 Karoq, and is that: - the eCall emergency service is provided for the life of the car. - the Proactive services are provided for the first 10 years (with no indication of how they can be renewed after that). These include Breakdown calls, Info calls, vehicle health reports, service scheduling, online personalisation and online system updates. - the Care Connect (remote access) service is renewably annually after the first year, with no indication that a break in renewals stops you buying it again later. This sends data to the Skoda Connect portal and phone app such as driving data, your last parking position, whether your car is locked and windows and doors closed, if your car has been driven outside a specified area, or over a specified speed, or if the car alarm is triggered. You can also send a signal to the car to lock the doors (if you have validated your online account a a dealer) or honk the horn and flash the lights, and generate a digital certificate confirming your car's identity, specification, mileage and service history. Note: I find it very useful to get a signal on my phone when the alarm is triggered as otherwise I don't know the car's lights are flashing outside. This happens seems to happen occasionally when a moth sets off the internal movement alarm overnight! But if you just want the driving data on your phone, you can get this by plugging a dataplug into the car and using the free Connect Lite app. - the Connect (infotainment online) service is also renewed annually after the first year, independently of the remote access service, and provides the voice control service, online traffic updates and online map updates as well as the details of parking places and petrol stations. It also uses online traffic data when calculating your best route, and lets you send a destination from your PC or phone to your car. Both Connect services seem to be offered at a discounted price in the summer, and extend your current licence by a year. Last year I renewed my licences for £36 and £44 respectively rather than the standard £55 and £65 I would have had to pay when they expired in November. Chris
Digital Music Files - Plays as Indiviudal Tracks, not Albums
Sorry can't help you then. Presumably the software is seeing individual music files, but I don't know of any setting that will let it jump instantly to the next track. Chris
Did they play continuously from the same SD card before, or were you playing them from the CD previously? I know that iTunes will insert a gap when it saves music files to a card, to denote the end of one track and the start of the next. Chris
Travel assist steering wheel sensor faulty
I think you misunderstood my message. Driver Assistance systems are not an NCAP requirement as such, but are needed to get 5 star ratings. So consumers have the choice - they can buy Dacias etc which don't fit any, but get 1 star ratings or go for cars which have higher safety ratings. Most manufacturers want to see their cars getting higher ratings as this generates more sales, so market forces encourage them to provide the assistance systems. Insurance companies also increase their premiums for cars with lower NCAP ratings, which is another driver as customers want cars with cheaper insurance. My car has traffic sign recognition built in, which works when signs have the required design and are clearly visible. But they will not be recognised when they just show numbers or are hidden by overgrown trees etc. Clearly no manufacturer can accept responsibility for councils not maintaining their signs, or using signs saying "20 when light is flashing".
Travel Assist in my car seems to be no more than the Adaptive Cruise Control linked to Lane Assist - perhaps with a stronger pull on the steering wheel from the Lane Assist. But I rarely use either anyway. Yes there is a general move towards more driver assistance, driven by the NCAP safety star system and insurance companies, so I doubt that manufacturers will produce a special software for the UK without these features regardless of Brexit. Even British manufacturers will met EU standards because that is the biggest market, and one they can't ignore without losing sales. But I also dread cars thinking they know what the speed limit is and driving at it because my car's traffic sign detection rate is so poor. Unless councils are forced to ensure speed limit signs are not overgrown by trees, not pointing the wrong way, etc cars will not see the signs. And mine often detects speed limits applying at to a joining road at a junction as the one it should follow. They of course cannot read signs saying '20 when the light is flashing' or overhead gantry signs where just a number is displayed. I let my car show me what it thinks the last speed limit is on the instrument panel, but the warning beep when I drove at the correct speed was so infuriating that I've turned it off.
Here's hoping then! Your comments agree with my suspicions about the cause, and perhaps warmer weather will dry my steering wheel out. If not I'll try a hair dryer 😀 Chris
Vario floor for 2022 facelift karoq Sportline
I don't have one in mine, but think they need shaped supports in the side panels of the boot to work? A friendly dealer might let you try one from a showroom car before you order one to confirm its possible. Otherwise, there have been various threads showing how to make up a support frame around the boot to hold the floor higher up.
