Suspension feeling tired, what to change?
Nope
Or PM me the VIN and I can look it up for you.
Find a different sticker, that's not a recognised part number. Expect the correct part number to start 5Q0 413
the truth about electric cars
If only you could understand that the fuel pump sucks fuel from the bottom of the tank ALL THE TIME, because that's where it takes the fuel from. Where else would it be? Fuel level makes no difference. It's sprung downwards against the bottom. I'm sure I've explained this to you before.
WHEEL HUB NUT
Looks like a Gen2 bearing/hub in parts diagrams. Needs special tooling, not a press.
- Intermittent power steering failure + ABS light linked to 12V socket?
Just found myself wondering if this is an electrical noise thing, rather than a marginal power/voltage thing. The dirty connection might be causing a kind of arcing situation which may be upsetting some of the circuitry in other things. Pull the fuse (#42) for the lighter socket (to prevent shorting while you work on it), and give it a clean up to improve the reliability of the contact.
Good new pics. I can't see anything suspicious at all there, unfortunately, unless during replacement of those cleaner three fuses something wasn't tightened down well. I'll have a quick look at wiring diagrams to see if the ignition switched feed to the PAS module is shared with anything else, but I think not on either of the 1.2 HTP variants in 2007. No harm in trying that spare strip fuse though, since it's right there looking neglected. 🙂
MOT failure on rear fog light
Are you certain it doesn't come on at reduced intensity as a second tail light?
Looking (more carefully) at wiring diagram, it seems like it might be a single-filament bulb that does both tail light and fog light functions, presumably at different PWM drive levels. So that makes me think it may be on the input (switch) side that the problem is, assuming that it is working normally as a tail light. EDIT: (And after even more scrutiny...) Brake light also appears to do the same, so there should be two distinct sources of tail light illumination, if I'm reading it right. Pin 4 of right rear cluster connector (white/blue wire) goes to brake/tail bulb, pin 2 (blue/white wire, confusingly) is the tail/fog bulb. So we may be back to a failed bulb filament, with it passing tail light test because brake light one is intact.
No-one has checked the bulb yet? Definitely the starting point that makes most sense to me. Looks to be powered directly off BCM, so there may not be any obvious dedicated fuse, nor direct, hard-wired link to telltale.
Good effort but not quite sharply focussed enough for good scrutiny. Can you try for a closer shot of this subset of your previous image. Looks a bit like there are three newer fuses in there, for L-R; Fan full speed 40A red/black thinner, ABS 40A red/green, and PAS, 50A red/black thicker Also looks like there's a spare 50A fuse in position 6. If the PAS wire will reach there, try moving wire onto that one. If it won't, try substituting that fuse into position 5 (with a gentle clean up of surfaces with something like a bit of wire wool).
Inherited a 2014 Superb Mk2 - looking for advice on preventive maintenance
I see. I know nothing about these engines, but if it runs nicely just keep the oil changes regular and don't ignore warning lights or strange noises. Sounds like you got a good one. 👍
Manufacture date of engine, I expect. Neither good nor bad. 😀
- Weird coolant loss in a Mk1 Fabia 1.4MPI
1.2tsi Oil Pressure Warning
The worry with seeking a replacement engine is to imagine how few of them have never had this oil filter 'gotcha' happen to them over the last 12-16 years or whatever. I'm in the market for one myself, though not urgently. Feels like a gamble, more so than with other engine types.
1.5 TSI MPG: Octane vs additives (>4,000 miles longitudinal road test)
Evidence of the stuff doing anything at all. Too much history of similar 'revolutionary' shizzle to take claims at face value. By the way, I have no problem with your dismissal of higher RON benefits on mpg, not actually surprised by that one. RON isn't a measure of energy content.
I looked at your github stuff, didn't notice any links. The oilsin brochure doesn't have any references, just mentions. I won't bother any more, unless you can supply some real evidence.
So, different behaviour from the driver, as suggested. Which University? Link?
Sure does. Changing the effective energy available in the fuel that much stretches credence well beyond breaking point. Something else going on here, probably driver behaviour, since the testing wasn't blind.
1.4 16V BKY ignition issue
I'd be tempted to grab a set of scrapyard coilpacks to try. (Or a friend with a similar engine who would let you test yours one by one in their car, as a free test?) I read some time ago that it's quite easy to kill these things by trying to see if you have a spark with the plugs not mounted in the engine. Not sure I understand the mechanism, but a quick and easy thing to try (with everything fully mounted!).
