Griding and screeching noises.
This shows five different gearbox codes used with AWY or BMD (1.2 40kW) engines through mk1 production years. Any of them should be suited to your car, I believe. Searching ebay (or asking a scrappie) for e.g. "GSH gearbox" should provide hits, though I haven't tried that specific search as yet.
Skoda fabia MK2 estate 2010
As mentioned in PM, car built in sept 2010, with CGPA, 12-valve version of the HTP engine. Cam sensor wiring looks like this: G40 being cam sensor, J623 being the engine ECU. The rectangle with 70 inside it shows (on another page) that this earth joins a few others, and terminates at ECU pin 54. You should be able to measure a solid 5V between pins 1 and 3 of the connector when ignition is on. Looking for any wiring damage, anywhere between 3-pin connector at cam sensor on top of valve cover, and ECU on firewall, would be my approach, though easier said than done for most of the wiring run.
2013 Fabia brake fluid leak at rear
Probably/almost certainly the wheel cylinder has developed a leak at one of its piston seals, and the leaked fluid has come through to there as well as leaking inside drum. Drum removal needed for inspection and rectification. Near zero chance that the brake pipe has mysteriously loosened itself.
If the build sticker is still present and readable near/in the spare wheel well, it will have transmission code on the same line as engine code, I think. Post a photo if you find it but aren't sure what you're looking at.
1.2 TSI CBZB O-ring broken
33 x 4mm Part number WHT 003 865 from Skoda, recommended to retail at £10.25 + VAT in UK.
OK, if the scan screenshot above is showing the correct engine code at the top (BBM), then you have the 6-valve single cam engine, which surprises me slightly in an estate version, I thought in the mk1 at least they got the slightly more powerful variant. I'll start a PM conversation with you so that you can share the VIN with me securely. Then I can confirm engine coide/type and also the build date. Both of these are really necessary to get the most accurate wiring info.
- Another electric window issue - all but the driver's door!
Will try to look up what those other wires do tomorrow some time. The wires break because that section of the door loom has to bend back and forth each time the door opens. Mk1 Fabia had a much better design where the bellows has a vertical dogleg, meaning that there's a combination of movements including twisting, which is less harsh on the wires. Almost everything Skoda have made since then seems to just take the shortest route straight across, and they all seem to suffer from premature loom failure as a result.
Wheel bolt keeps turning - most likely the thread is damaged
Right answer. 🙂
Were the bolts dry or lubed?
How can I confirm my Skoda Fabia car battery type and spec which has no labels.
You say with engine running it's charging at 14.62V, are you able to check that while on the move? If you really do have a start/stop battery in, and tge car coded correctly for it, that voltage should fluctuate, a lot, while driving.
I'm not convinced that is the original battery. I'll start a private chat with you to request VIN. Cheers.
- Skoda fabia MK2 estate 2010
Always try to leave it in a gear that means if the handbrake does slip a little, it turns the engine the normal way, not backwards. So if you're nose down the slope, leave it in 1st. If the engine is turned tge wrong way, it tends to squeeze residual oil out of the hydraulic chain tensioner, making a chain jump more likely when next started.
Electric Windows Not Working
Message sent.
Fabia Mk2 Vcds Abs
By the way, you say It does, throughout most of the modules. It's the primary communication system. Pretty much everything "intelligent" except the window motors use CAN to talk to one another. But diagnostics is via K-line, even though CAN wiring is present at the diagnostic socket. Someone with better VCDS knowledge like @PetrolDave may be able to explain that to us.
Fabia Mk2 Vcds Abs
I'll message you, you'll be able to reply. What you're seeing may exclude a fuse issue, but there's no harm in checking them.
- Genuine or fake filters?
Where to get hardened bolts from
@Msmaciejo what made you think that a thread about hardened bolts was a sensible place for your question?
Alarm Siren Battery Replacement
AAA but that's just my eye for detail. It makes the appeal of a secondhand one of that part number quite a bit more... I was thinking of trying to look at the one in our 2012 Roomster, part number 1K8 951 605 B according to partslink24, but superseded by the part number shown above, 1K0951605F. It went off without obvious cause quite recently at home, though it was very windy at the time. Just bought one from Silverlake via ebay for £28 that appears to have a 2024 date code on it. 🙂
1.2tdi injectors
Has it ever been mis-fuelled with petrol, to your knowledge? How many miles done to date?
