Breezy_Pete
Sponsor
  1. Sorry, I don't have any such capability. @Carlston may be the man to help with this.
  2. Washer pump for front and rear screen is the same motor fed by opposite polarity current down the same pair of wires from the BCM. So the fault seems very likely to be on the input side.
  3. Confirming 1K0 413 031 BL (dropped in Oct 2023) superseded by 1K0 413 031 EJ.
  4. Need VIN to look up properly, if you won't look for the sticker. I'll message you so you can tell me the VIN privately.
  5. Look for another sticker, lower down on original shocks. This isn't the part number you're looking for, there will be a sticker with a number ending 413 031 xx which will give you the correct suffix.
  6. If it were mine, a VCDS scan would be the first thing I'd do. There may be fault codes in the engine ECU that would give clues. A CHPA-code engine, from the VIN, I see. Wonder if the cam adjusters are causing trouble?
  7. I can't see it being wise to spend a load more cash on a walnut shell blast on a hunch from a garage who appear to apply a 'just change everything we can think of' approach to diagnostics. Does the coolant temperature gauge sit at 90 after a few minutes running?
  8. I don't know much at all about 1.4 tsi engines, but I'd be pretty surprised if carbon build-up in the intake was causing that. Do you have any fault scans?
  9. Which measurement of the emissions test was it borderline on? There may well be other factors unrelated to carbon build-up that could be responsible. I'm curious to know why this tester is sure that carbon accumulation is the problem.
  10. I can probably help if you get no response. I messaged you a day or two back. Have VCDS.
  11. I believe the answer is G 060726A2 (part number is for 1 litre, RRP is £14.11 + VAT at Skoda). I think 2 litres will be enough.
  12. Can generally be found molded into the plastic of the bulb holder, for example:
  13. No VW group cars in UK are given a 5 year cambelt change recommendation any more, as far as I know. Approx July 2023 this (UK only) stipulation was withdrawn. Don't think it matters when built. Mileage only, varying with engine type, quite high mileages now, I believe. Do a bit of a searcharoo, there's an abundance of discussions about it.
  14. Probably not. 5 year interval is no longer used.
  15. I have no idea how they can judge that the drums need cleaning, without removing them to look inside. They will not have done this, unless you specifically asked them to, I would think. If they had looked, it's only 5 minutes more work to clean them out while they're in there! So I would recommend ignoring this dubious suggestion and letting the MOT decide if it's really required.
  16. Has it had the MOT yet?
  17. VW group in UK previously recommended every 5 years, but that was dropped in mid 2023. Not sure if there is any time interval at all now, but mileage recommendation varies with engine code, big distances though.
  18. No, not according to current recommendations.
  19. If cambelt and tensioner was only done 40k and 5 years ago I reckon there's very little chance that is involved in this rumble or likely to cause any other problems for a good while.
  20. Will message you both shortly, thanks for posting. 🙂
  21. Time to scan to see which corner the ABS ECU is complaining about. VCDS Lite (freeware from ross-tech.com) plus a cheap generic KKL cable will work on an 06 Roomy, if you have a laptop and a little patience to get it all talking to ABS module.
  22. Have you driven it since refitting the fuses? Warning light won't go away until driven a short way, if there was a power problem.
  23. Shouldn't add any errors as long as ignition is off when removing fuses.
