Front consul bush which way do they fit Mk1 1.2htp
If your Febi bushes have this lump like the OEM ones, the lump should be on the side nearest the midline of the car. Do you have any tooling to help press them into place without damage? Are you aware that on the (UK) driver's side ,with the HTP engines, you have to lift the engine a fair bit to give clearance to get the front bolt out and (preferably new replacement one) back in again? PITA job which I did recently for the second, and last, time.
Rare parts ? That you got/ what can you get ?
Do you know the part number you're seeking? I can look up via VIN for you if not. May be possible to repair, by either cutting off split/cracked bits and re-fitting with heat to soften (if it's a hard plastic section), or simply using self-amalgamating tape to form a robust, airtight covering.
- No crank no start
Engine mount - good or bad
I expect the lower mount will make a much bigger difference.
- No crank no start
Driver's Door Electrics
Broken wires in driver's door bellows. Super common.
P25AB00 Piston Cooling Oil Control Circuit High - Superb
Ah, OK. Glad it's finally sorted.
Boom
superb 2014 timing chain
Hell no!
- Need help to identify Correct steering rack part number
The 3q2...051h part number is probably just for the rack, minus the track rods and ends. The 5q2...055L probably includes all the bits. You may not be able to buy 'just the rack' as a new part from Skoda, so have been given the part number of what you can buy. Have you seen the 3q2 part number on a physical label on the rack?
The Games Manufacturers Play
@Evolution13 that's a spammer, see link inserted into quoted text. Reported.
Ash load in DPF
I predict that you will find that the DFGA needs topping up with oil between services.
Ash load in DPF
Does the DFGA engine use/burn more oil than the CXXB?
the truth about electric cars
^ Looks very elegant and aerodynamic. 😆
- Engine cover
Engine cover
Top Cowling 1.2HTP Škoda 03E103929A ? Need VIN to check properly, but that's what comes up for 2012 CGPA engine. Maybe it had something non-original on it before, if that doesn't look like what you expect. I will message you to ask for VIN. Dirt on the outside of the engine doesn't matter, clean oil inside is much more important
Engine mount bolts?
That's the technical term for causing a screw or bolt to stretch to the point that it doesn't return to original length when undone (elastic region is everything before that). It's actually fairly easy to feel when (if ever) this happens. You continue to turn the head but without any increase in effort like there normally is. Weird feeling. Rare on cars, even on headgasket bolts.
Timing Kit Fitted by Garage, car now stumbles under power at lower revs.
Seems likely, given recent work, yes. Please check for typos in the timing kit number you wrote, google struggling...
CBZB doesn't have variable valve timing, if that's what you mean by VVT. Garage need to check timing correlation with correct locking tools. You probably can see fault codes in engine ECU if cam timing is far enough wrong relative to crank. Whereabouts are you? What year is the car?
Engine mount bolts?
Angle tightening is essential for fasteners that are taken into the plastic region, but far more often it is simply a far more accurate way of tensioning a(ny) bolt compared to torque alone. The impact and variability of friction when tightening only by torque creates wide uncertainty in the achieved pre-tension. Angle tightening is independent of friction because the bolt extension is directly related to thread pitch and the angle used. Smaller torque plus angle gives a far more predictable outcome. So it's just a better way of tightening important fasteners, not a guarantee that the bolt in question is permanently lengthened in each usage.
Air Quality Sensor testing
You might consider linking Febi to this thread as helpful feedback for them?
- 1.0 Tsi misfire on cyl 3, p303
SkodaParts.com review: Our Crystal winter rims have arrived!
No problem. I've used them a few times recently and am starting to view them as my favourite supplier for genuine or 'safe bet' pattern parts. Delivery surprisingly swift from Czech too.
