Rear 12V socket removal
Same fuse as front one, fuse 40.
OEM electric windows + mirrors retrofit on a 2001 Fabia Mk1 Classic – wiring / Comfort module questions
Pins 3 and 4 of black 6-pin connector at A-pillars is where I'm seeing A146, A147 in circuit diagrams. Other thing you may have to add is power wiring for windows, pins 1 and 2 of the black 4-way connectors at A-pillars, from fuses and earth points. Can't you just chop it in for a Fabia that already has all this? They're not exactly scarce.
I know there won't be any CAN wiring in your door loom, but it may get as far as the car half of the A-pillar connections, if you're lucky. That's what I'm suggesting you look for. If it's there, there will be pins in the appropriate spots of the connector, if not there won't be. All the CAN wiring in the cabin loom will be 'bound into' the loom in the car body, I expect, but there will be splice points, (the A146, A147) where all the 'Convenience CAN' pairs split off to their respective control units (such as A/C). This is likely to be near to the onboard supply control unit (J519) which also houses the CAN gateway, headquarters of the CAN system. That unit is above accelerator pedal on RHD cars. You will have to run twisted pairs of wires from these points to each car-side A-pillar connector, and fit the appropriate pins, if they aren't already present. Will be a pain, but those whole connector multi-blocks will come out of the A-pillars outward for access. Door removal is dead easy and the job will be near-impossible without this, I think.
- OEM electric windows + mirrors retrofit on a 2001 Fabia Mk1 Classic – wiring / Comfort module questions
Exhaust gas getting into the coolant
Link?
Superb 3V3 tailgate struts - Beware Autodoc
A significant disadvantage of autodoc and its other companies masquerading as UK based with .co.uk addresses. Fine when the right parts are offered and delivered, PITA when not. Part number is very likely to be printed on your current struts. Use that - exactly, suffixes and all - to attempt to find aftermarket matches, autodoc may also be wrong about non-availability.
Throttle Body issue
Have you checked the brake servo vacuum hose for splits or cracks at the junctions of the hard plastic sections?
Throttle Body issue
You just clean what you can without moving the butterfly, which is 98% of it. They don't sit fully closed when unpowered if I remember right. So far I don't know which engine type you have, so it's hard to know specifics.
Throttle Body issue
Buy a secondhand one as they rarely fail. Match the entire part number including letter suffix.
1.5 Tsi Power Cutting Out
Tell them that knock sensors and the ECU hardware and software that interacts with them react in fractions of a second, so their argument is utter tosh.
I haven't had much experience of the earlier, CAN-based set-up, but I can try to help. Not sure if manual window cars will have the CAN wiring pair going to each car-side A-pillar connector, presence/absence of the pins may be visible by phone camera if not by eye. I'm on the road today, but may have some time to look at wiring info later, or you could download it yourself from the available list here: https://www.briskoda.net/forums/files/file/76-mk1-fabia-workshop-manuals/
Disable alarm siren?
Ours did a spurious alarm recently, that we think was actually probably a genuine trigger of the internal monitoring system by one of the roof blinds 'opening itself'. If yours have a tendency to not always stay shut, the same event may have caused yours. Steeply sloping driveway might increase chances of a blind overcoming the little magnetic latches? To disable alarm, I believe the best way may be to remove it from the 'installation list' of modules fitted, using VCDS. No physical changes would then be required. Haven't tried this myself though.
How to find OEM part numbers of front wheel bearings for my Fabia 2
One of the screws isn't possible to get 'square onto' with bearing/hub in place, so a bugger to do anything with once corrosion has taken its toll on the head.
- Rear drum brakes.
Rear drum brakes.
You might be able to free it up if you take that drum off, disconnect cable from that plate then rotate it back and forth to break corrosion. Add a few drops of oil to the pivot/rivet, between the plates. Loosening the cable adjustment in the cabin by quite a lot is a big help when trying to remove drum. Retighten when work is done.
- Rear drum brakes.
P25AB00 Piston Cooling Oil Control Circuit High - Superb
Unfortunately I don't have recent enough circuit diagrams for Superb to cover this engine code.
Check your sills! Paint advice
I had to have a hole welded a couple of years back. Rear of sill is close to mounting of rear beam. This (actually part of front wing) has been slowly worsening for a while. Went through MOT a few weeks back without mention. 🙂
Will try to look for circuit info this evening.
It could also be voltage related. Warm engine implies recent charging, cold engine implies the opposite. There are about four other devices powered from the same fuse I believe, but would need your engine code to check properly. Maybe one of those other devices is pulling too much current, and causing the whole voltage supply from that fuse to dip too low during a cold start, or something like that.
Pete's Rescue Roomster
Car was MOT'd this morning. Passed with no advisories. 😁
How many seconds was there between step 2 and 3? If only a very short time, try repeating test but leave 60 seconds between ignition off and back on again. See if same outcome.
First one, ending E. There have been some superseding numbers but they usually quote all that match on the aftermarket.
Gen2 bearing type that needs special tooling to make sure you don't press on the hub face when installing. Search youtube for demo vids with tooling examples.
Perhaps time for them to try another valve replacement.
