Fabia 07 MK1 VRS O/S door mirror.
Ping me your VIN in a private message and I can look it up for you.
- Screen wash wiring issues?
Intermittent fault with fuel guage readout
A dry/cracked solder joint at the instrument cluster connector might give similar symptoms too, I guess?
I had something like this on a Vauxhall once. Turned out that the mechanical arrangement of the sender unit in the tank had become a bit misaligned or bent so that the wiper contact(s) were losing their pressure against the carbon track(s) of the potentiometer in the tank. A bit of gentle bending of a metal rod to improve the contact pressure sorted it. No idea if the physical arrangements were similar enough to what you have for this to be a plausible explanation in this case. Did you take any photos while the pump/gauge sender were outside the tank?
- Egr adaptation error
Front drivers seat belt frayed
Message me with your VIN and I will check for you. I think you're right to be concerned though, the third character in the part number being a 1 rather than a 2 makes me suspect LHD.
SOHC to DOHC CBZB swap?
All CBZB are SOHC, so I don't understand your question.
My car's doing 74 mpg !!
Is the indicated mpg anywhere near true? Ours wasn't, it was about 30mpg optimistic
Well worth a look. Access better from beneath, but in my experience, you can get enough space to remove undertray and get enough access to investigate with just one side (UK nearside) of the front of the car jacked up and supported safely on an axle stand. One could possibly improvise by parking with nearside wheels up on a kerb instead.
Let me know how much you'd want for it, if you do decide to offload it.
Had similar on our Roomster with same engine. Gave a different fault code as well though. After a lot of faffing about replacing things that didn't help, it turned out to be oil contamination in the wiring/connectors of the loom for the pre-cat sensor. I'd seen it when changing sensor, but dismissed it as unlikely to cause issues (unlike water in there),;but I was dead wrong. It's a thing, have a look: Sensor-oil-contamination-ver2.pdf
Water in front passenger footwell
I haven't looked at ours up close, but I was more thinking about the bottom edge.
Which o2 sensor for bank 1 ?
5 wires is correct. It's a so-called wideband sensor that allows for finer control of fuelling than standard 4-wire versions If there's lots of oil about and you find it on the pins of the mating loom connector, make sure it's all cleaned off before fitting new sensor, or it may not work at all, or not for long.
- First time poster - MOT Fail and could do with some advice...
Possibly the sealing between windscreen and bodywork?
- warm starting issue
Skoda fabia coolant fan issue
Fuse 9 or 11 on battery fuseholder, depending on exact build date. The 5 Amp blade fuse with a thin red/violet wire coming off it. Try removing that the next time you see unexpected fan running.
In that case it has a fan control module hanging off the nearside chassis leg, close to where the bottom hose attaches to the radiator. Your symptoms suggest that a relay within this is sometimes sticking on instead of clicking on and off according to radiator thermoswitch control input. You could prove that this is what's happening by disconnecting the smaller of the two plugs going to it while the fan is running. If fan keeps running, module is faulty. Access isn't super easy though, much better from below with undertray removed. There's a fuse you could remove to demonstrate the same thing, one of the blade fuses in the battery fuseholder. I'll try to find which one. Those blade fuses hide under a plastic cover, to the right of the strip fuses as you look from in front of car. One of the 5 amp ones, from memory.
Does this car have air conditioning?
