Breezy_Pete
Sponsor
Joined
Last visited
Currently
Viewing Topic: Wanted: wiring diagram for blower motor
Door lock barrels.
I agree that it would be interesting. First thing to note Stewart is that they can be buggers to get out even when in the original positions, I had a right struggle with the drivers side one on the missus's car not long back. As far as I know/remember, it had never been removed before so it may be that a bit of corrosion on the outside of the casting interferes with the retaining ring arrangement enough to cause it to not release as designed. One of Hatboy Harvey's vids shows him having a bit of a wrestling match with one from the outside. This page shows handedness, but not sure exactly why: LLLParts This image pinched from the thread you linked earlier Keith shows that at least one of the raw casting parts appear to be ambivalent/ambidextrous before they are assembled (alternate left/right part numbers both on it): Some nice clear photos in this ebay listing of a 6Y0989168E right side one here: Skoda Replacement Door Lock + 2 Keys - 6Y0898168E **Genuine New Skoda OEM Part** | eBay If anyone fancies staring at them for long enough to spot a difference between topside and bottomside view?? I'm not seeing one straight away, but my eyes are old.
Headlight replacement to led
Easy solution; put the correct bulbs back in.
Skoda octavia 1.4 tsi oil pressure low engine off owners manual fault
Oh no, that's annoying. Better than a lot of other outcomes though, I guess.
Door lock barrels.
You'll be able to wrestle them out from inside, I expect, but it'll likely bust bits of the inner handle/lock support framework so be prepared with known good spares I suggest. Big job, luckily not too hampered by rivetted on carriers. I'd cross the bridge if you ever come to it; it would be much easier to open the one locked door from inside with a cunning trick like the one described here: https://www.volkswagenforum.co.uk/threads/9n3-doorlocks.40502/
Higher mileage mk2 reliability
CHFA is a 6-valver, 12-valve is 70bhp in mk2s. Might last some time, might not. It would have to be very cheap to be worth a gamble I reckon.
Door lock barrels.
Harvey has done a few in-depth videos of various aspects of the door locks, but if both are currently in and working, why do you need to remove them? HatBoyHarvey - YouTube
Anyone know their Scoobies?
The car looks like a right chav-wagon; sticker city. The engine looks like a bewildering, unfamiliar mess of stuff crammed in a space not really big enough for it. 😁 Cars are worthless without engines that work. 😋 Youtube seems to have the answers; apparently Subaru recommend lifting the engine up a bit off its mounts, but it's not really necessary with the right tool options.
Dpf pressure sensor query
I'd say they are right, but being too literal, not thinking about it quite enough. Your photo shows two pipes connected to it, as does ETKA: LLLParts Just one of them is short and open-ended.
Problems with ABS sensor
I think if I read this in the morning I'll probably understand it: https://www.tiepie-automotive.com/en/articles/abs-sensor-hall
Still beyond me.
Beyond me, but looks like they maybe generate a voltage?
Pal just bought a 2001 Impreza, drove it a mile and got a flashing emissions warning light. Snapon scanner said misfires cyls 1 and 3 and running rich. EJ205 engine I think. Coilpacks? plugs? Other? Access looks fun if I am to get at either/both. Do they come out with engine where it is? They must, right?
Again! 😁
Yep
The one I read pertaining to your car (well Superbs of that age in general) was bought from erWin a while back, the one that above screenshot is from was wild on the net somewhere as far as I recall.
See what readings you get on a 'diode' range of the DMM?
No idea! Diagram added to previous post by edit btw.
Wiring diagram does show a + and - next to the sensor connections too, now that I look carefully. You're winning me over. Perhaps there's a diode in there, although it's just shown as a blacked out resistor shape in each. Like this one: Active devices usually show a transistor symbol to indicate such?? Please do a post mortem dissection on one if you do end up replacing one.
Fair enough. 🙂
Hmm, I'm unconvinced. What could possibly be responsible for high-resistance readings - no offence intended - is difficulty in getting meter probes reliably onto sensor pins which might be deeply recessed in housings?
Would need 3 connections for an active sensor of any type, I think?
O2 sensor for Octavia 1 1.6L petrol
Engine code would be useful for narrowing down the possibilities. It'll be one of the item 12 selection here, which you will see, are different depending on engine code in the 5th, 'data model' column of the table. View on a computer not a phone to be sure of seeing the full table, view the relevant link in my signature if 'engine code' is a mystery term to you. switch; clutch pedal - Octavia(OCT) [EUROPA 2003 year] (7zap.com)
Door lock barrels.
Repair kits are available cheaply, never tried one though.
Intermittent Cutting Out and Other Electrical Witchcraft
Engine Coolant Temperature Sensor
A little silicone grease helps.
