- Car won't start after timing chain renewal
Central locking and boot issue
Yeah, not sure about the boot opening, but if the central convenience unit is coded to think it's in a 2/3 door car, and is possibly also from a car without remote central locking, that might explain most of what's occurring. Not sure why vcds lite won't talk to it though, not sure having full version will change that.
Don't suppose you have a VCDS autoscan for the car? Sounds like someone may have replaced a faulty module with one from e.g. a two door Polo?
Is this normal?
Injector problems aren't unheard of in the 1.6 diesels, but I don't know how you'd go about diagnosing such a problem. A fella called @Crasher has considerable professional experience that he might be kind enough to share.
Is this normal?
Unlikely I think. What engine type is it?
Is this normal?
No. The flexible, convoluted section under that braid has developed a leak.
Regen. Yae or Nae
Ad blu doesn't have anything to do with regeneration even in diesels that use it.
what to check for brake fluid leak?
Yes, thanks. Now edited to 8.
Engine Number Location
Yes, I believe it is. Should match what's on your V5c too.
Citigo AC Condenser pipe - A Kings Ransom..
Share the reg number or VIN with me and I can look it up for you. From experience of a different model, surely a leak at a junction between a pipe and a component is most likely to simply require a replacement o-ring?
Electric window dropped
Dunno mate, there are repair kits you can buy, but never tried one.
- Gearbox code fabia 1.2 htp 2006
Gearbox code is GSB, clutch is 190mm.- Gearbox code fabia 1.2 htp 2006
Eating for a bit, back soon.- Gearbox code fabia 1.2 htp 2006
ViN or reg number please.- Engine light
Mk2 Fabias are equipped with a lot of different engine types, which does yours have, please?- Safelock not working
I'll PM you the car data, stand by.- Safelock not working
From your car data: 4I2 Central locking w/ radio remote control, interior controls, without SAFELOCK- Safelock not working
What's the VIN?- Coolant level when hot
Good decision. The HTP engines are sweet when running well, but not designed to have major work carried out straightforwardly.- For sale
No such thing as a 6Y2 engine. BLT engine code, I think. 6-speed manual transmission. But yeah, most people looking for a Mk1 vRS would know what it is.- Full Size Spare Wheel is limited to 80kph
@Dennis3 What size are the tyres on the four alloys? And on the steel spare?- O2 sensor
I'm not seeing a lambda probe listed in either parts catalogue or wiring diagrams for this car. Any chance you meant air mass meter/MAF sensor?- O2 sensor
I don't think it will have one, if you mean the type of oxygen sensor found in exhaust pipework? VIN or reg number may help me confirm. Why do you ask? - Gearbox code fabia 1.2 htp 2006
