New Croatian VRS 236hp 19inches
And final product
centering the clutch
Edited by davojuri
  • Replies 1.2k
  • Views 181.4k
  • Tom from sem motorsport decided to make some more  of his big port passenger side (LHD) intakes for me after seen my build thread. At first he rejected me,and after few days me being desperate and con
  • Pay attention to fine precission tools and protein drink
My final words are:
MIŠKO CAREEEEEEEEEEEEEEE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
POZDRAV CIJELOJ EKIPI IZ CACKA!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Edited by davojuri
Edited by davojuri
Some new goodies are picked up today, and going to be mounted tomorrow:
And here are the promissed videos of my friend Misko Herc who did my gearbox.
He drives silver/red Audi TT Sp1600cc
Also red Golf MKI was his car, championship car, he sold it to the guy on video.
Hope you'll enjoy
he starts at 2.26sec of the video
https://www.youtube.com/watch?v=-UaT9y8leSU&feature=youtu.be&t=2m25s
Edited by davojuri
Guys
I'd like to buy used throtle body
06B133062M, 06B 133 062M
from passat, or A4, I have one but connections are damaged during polishing so I can't do adaptation via comp.
All I found on ebay is UK posting only.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=121215754722
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=171181526698
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=360759524755#shpCntId
Could one of you buy it for me and send to Croatia?
I will send money in front via paypal no problem.
Help appreciated
Bought it. Sent to Matt in liquidmetalrefinements for polishing. Done. On its Way to me.
Edited by davojuri
Polishing is ok but I wont some chrome shine.
www.galma.si
is the place.
80eur for set of
Valve cover
Intake
Alternator
Catch can
Oil filter housing
Just can't Wait.
Will probably do oil sump to.
Hehehe
Hi guys
I just wont to share some of my opinion, and that is that the most online stuff that is being sold for performance and upgrade is simply piece of s..t.
Not 50% but 90% as my friend Misko who did my gearbox says.
At the begining I was like no that's not the truth.
It must be good if they say so.
Just add percentage of power increase they claim, 10, 20, 30% and so on.
But on dyno table it says you the truth no massive gain unles much monney spent.
But there are guys that claim to live from selling performance products, and if that's so I wonder how they manage to do so.
Like for example, my baffled sump from Issam Abed.
I had very bad experience with him, and paypal twice returned me my monney,
but that sump is something that should work, instead he changes oil return outlet direction each time he makes is,
and it should go upward not horisontal,
Mine was like this
and rewelded it like this
3a143ef1-1375-4eae-b78c-5f368e029212_zps
But he did it for other customers like here
SDo even he doesn't know how to put it!!!!
Because if you use aftermarket AN adapters not OE return line like this you will hit the axle, so I had to reweld it
http://www.ebay.co.uk/itm/SEAT-CUPRA-VW-GOLF-MK4-AUDI-A3-1-8T-TURBO-OIL-RETURN-PIPE-06A145735P-/141131118721
otherwise it will hit the axle.
clearance showed here
I had to make custom oil return line
and it looks like here
He should know that and make uniform design. By pointing it upward you can ad as many as you like adapters!!!!!!!!!!!!!!
And of course I didn't pay for rewelding by hand anything but to have finished product.
Anothwer weak thing about this sump is that you loose additional 3 bolts holding gearbox to the sump, and thus making it weaker and on the other side powering up your engine.
NONONONO!!!!
He should copy gearbox side and than to tthe right wheel new sump, so baffled sump and right holding power will be retained:
Next surprise when I first removed the sump, by genious Issam
look at the sump plate and upward oriented incission for oil collection
It hasn't have right clearance so when I started engine my rod hit it!!!!!!!!!!!!!!!!!!!!!!!
Hey man, I should kill him for that
than I enlarged that point to be like here
8fbfeede-40b0-48df-8732-f993a067c40c_zps
But the right thing will be to press downward those incissions not upward and everything solved.
So my plan is to  put baffled inserts into my old OE sump, than to polish it and than to chrome plate it.
So I will have OE rigidity and BLING BLING look.
Just need to push John from  Forge motorsport to sell it to me. He thinks I will stole his design and I simply wont be throwing away monney for sump that I dont need. They sell sump with their inserts. Will be selling a lot more if selling only the inserts in my opinion.
Another brilliant stuff from 034motorsport.com
They sell what they call vortex breather kit.
It helps oil to separate from vapour and returns to the engine block through block adapter plate under oil return line and only gas is supposed to go out.
AAAAAAAAAAAAAAAAAAA
Wrong
my cactch can, abs, and up to the subframe is dirty from oil that condensates arround or directly goes out.
And do not forget that I have enlarged his funny 2-3mm port to 10mm one so anything will be left in can:
and it is still ****ting arround.
I like my chrome breather filter but **** it I have polished my can several times. NONONOMNO
So I decided to do something completely duifferent.
I will reroute that gas to the underside of the car beside subframe.
I will be using
Blue SFS 180° Fluoro-lined Elbow 25mm (breather filter outlet OD)
http://www.ruderacing.co.uk/Fluoro-lined_Silicone_Hoses-180%C2%B0_Fluoro-lined_Elbows/c3612_3617/p345215/Blue_SFS_180%C2%B0_Fluoro-lined_Elbow/product_info.html
to get vertical direction toward subframe, and than barbed reducer from 25 to 19 or 16mm depends on available space (will test it today) and fix that tube somewhere behind the subframe to go away while driving, and not causing any dirt in my clean engine bay.
Of course fluorolined  19mm or 16mm hoses will be used to
http://www.ebay.co.uk/itm/Blue-Silicon-Fluoro-Lined-Hose-1-Metre-19mm-/170654550093?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item27bbcdc84d
http://www.ebay.co.uk/itm/Blue-Silicon-Fluoro-Lined-Hose-1-Metre-16mm-/170654550087?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item27bbcdc847
I also bought TTRS brake vents, and there is no chance you can mount it on my car due to the big brakes, and size of LCA.
They also sell it like plug and play : bull****.
Planing to chrome plate
valve cover
intake
catch can
alternator housing
oil filter housing
TB
TB and filter hoiusing completely dissasembled.
Will be done at Glama radomlje slovenija http://www.galma.si/
Can't wait for it.
BLING BLING
Edited by davojuri
So in conclusion isn't it funny that I as a stupid surgeon has to redesign almost everything I buy!?
But it makes me happy and relaxes me from everyday stress at work. Best spent night is spent in garage for me.
Telling that I just came from 24 hour duty in hospital, and planing to go to the garage to see for clearance of 19 or 16mm  hose to the subframe for catch can hehehehe
I fill be fired at home hahaha :love:  :dance:  :strong:  :moon:  :thumbup:
Edited by davojuri
  • 4 weeks later...
I love so much Tom from SEM motorsport!
Reasons to come hehehe
Edited by davojuri
While waitin gor SEM Motorsport intake with TB on passenger side (for LHD cars) 80mm TB oppening and 60mm adapter for the beggining (latter on 70mm one for S4 or GRAMs TB) like here:
034Motorsport_18T_DBW_Throttle_Body_Upgr
I like it because it is smooth and can easily be chrome plated. Because OE one is hard to polish in all recesses and than chrome plating isn't so good.
I bought some nice things:
Coil Pack Wiring Harness Conduit
http://www.ecstuning.com/Search/06F_971_824_C/ES281285/
for those who likes red (I already have blue hoses)
http://www.ecstuning.com/Audi-TT_MKII-FWD-2.0T/Engine/Electrical/ES1261181/
Should fit nicely like here:
Also decided to upgrade front mask badge from OII to OIII but not for the front like this one:
625537_482041645197050_204279663_n_zpsbe
with black plastik from behind and not so clean look like this one for backside:
with this one for clean look
Due to the some problems I have running last month or two I decided to empty and clean my tank, to change fuel filter for
also checked the spark plugh IK 24 that were pregapped to  0,024" from 0,032", because for each 40hp one number colder and gap smaller for 0,004"
They were oppened a little so I pressed them back to  app 0,6mm.
Coils were changed by Porsche interauto dealer few months ago as action So after cleaning tank and changing filter I will probably go for new sparks.
My tuner www.rsrmotorsport.com says they are to cold. But car was dynomapped for 10 hours and run 2 years perfectly until now. I wonder what can it be.
No engine errors readed, but when I push gas pedal hard in 4-6th gear it doesnt goes smoothly.
makes me crazy because I can't enjoj fully my new custom gearing 75 115 159 190 230 270 kmh.
Any suggestions folks???
Also bought OE G17 aditive.
Will see.
Another thing I forgot.
I looked for baffled inserts for OE sump.
http://www.forgemotorsport.com/content.asp?inc=product&cat=260301&product=FMBSMP18T
Contacted John from Forge motorsport because he was always friendly oriented.
He said good prices and I wonted to buy them because fiunal work on them and look is great., When I asked him for technical drawing-meaning where to weld them, he rejected me and didn't wont to sell any more meaning I am some kind of criminal who will steal his and resell it. No matter how much I tried to convince him that I do not resell anything, and that I tune my car for stress relief of my work he didn't even respond any more to my mails. Completely dissapointed.
Than I found Sambo guy on clubgti forum
http://www.clubgti.com/showthread.php?253113-06A-1-8T-20v-Alloy-Sump-Baffle-Kit&highlight=sambo
and it turned that he is one of our guys here from Bosnia and Hercegocina and he will send me the drawings for the same inserts. Isn't that a shame for Forge motorsport???!!!ž
I also asked for price for only block brwather adapter without one for valve cover and he didn't even respond to that one.
http://www.forgemotorsport.co.uk/content.asp?inc=product&cat=260301&product=FM18TCBB
Why John???!!!
Not the way to treat returning customer like I am!!!!!
:thumbdown:  :thumbdown:  :thumbdown:  :thumbdown:  :thumbdown:
Ahhhhhh did he p....d me of.....Forge!!!!!!
Edited by davojuri
Not to mention that I have bought almost everything Forge does for 1.8T20V engine!!!!!!!!!!
If I will be dealing like that with my patients, which are more than 80% loco loco, I will have no surgery pllaned at all
are you a doctor?thought you more like a mob man
Doctor,mechanic-all the same ;-).
And money and bitches are equal in terms of my affection
Octy II sign is now remowed from the font grille but I am not sure If I will be putting Octy 3 ones, because I like how it looks clean now and New Skoda logo is more visible now.
Just have to paint black and spray with shiny clear laque over the place of old badge because while cleaning the glue with nitro some of old paint is removed:
evolution here
first both old signs
than new skoda logo
than removed that green colour to match it to the Octy 3 VRS amblems
amnd finally front grille without VRS badge
looks great to me:
just need to paint with these
place where badge was sitting
Edited by davojuri
And the guy (John) from Forge acussed me for  someone else post on the forum advertising selling of DIY sump inserts likeI did it.
Is he crazy or what??!!
John you should be more carefull about acussing anyone without any rock solid argument.
Just simply look at the ussername.
My is
davojuri
what is shortening of
Davor Jurisic
what is my first and last name
I have nothing to hide.
So to many drugs and alcohol makes us write s..t like that!!!
Or simply read carefully and try to understand before answering anything like that.
it's ok man noone here is acusing you of nothing...
You see when someone like us is from a country like Croatia,or Romania (me) or Bulgaria ,or Serbia tent to think of us like we are some thiefs or cheaters,is called discrimination
I just wonted to buy his  (Forge inserts) because of perfect final work and asked for a price, and he gave it to me.
No sump needed, and for sure they do sell aftermarket one not OE, because it will be way more expensive than 200gbp. So why to trade oe sump for aftermarket replacement one which is lower in quality.
And after giving me the price 37gbt I think they refused to sell it to me.
That really p....s me of!!!!
Dude when you look in the encyclopedia under the words Attention To Detail there must surely be pics of your car.
