New Croatian VRS 236hp 19inches
Dude when you look in the encyclopedia under the words Attention To Detail there must surely be pics of your car.
It's a big compliment.
I feel onored right now :-)
  • Replies 1.2k
  • Views 181.4k
  • Tom from sem motorsport decided to make some more  of his big port passenger side (LHD) intakes for me after seen my build thread. At first he rejected me,and after few days me being desperate and con
  • Pay attention to fine precission tools and protein drink
pa gdje je kraj? :rock:
dobar ti je taj ispušni ventil od tvog Octy.a :giggle:
Good luck on ..
 below works
Good luck on ..
 below works
Never ending story ;-)
First few layers of black glossy paint are sprayed over
Clear glossy laque left for the glossy finish
Edited by davojuri
Glossy black is back hehehe
will put it back later afternoon
pics to follow
When I finally decided to buy sem motorsport intake passenger side (LHD) sale was off and no more PS ones. Inwas so mad. I contacted SEM and they initially rejected my demand for another PS big port intake. I contacted even Arnold from pag and when he said he will be able to get one Tom from sem motorsport that he will do one for me because he liked my build thread!!!!!! Man was I happy or what hehehehehe. He made one like here:
Hi my trusty follower
I've been doing some nice things yesterday....
so lets see
First I installed
Coil Pack Wiring Harness Conduit
If you use AGN valve cover coil on the 4cylinder can't sit straight paralele to other three because that oil tower at that side.
So some ginding of the coil was made:
and here is the result
But to complete installation we had to deal with to short ground wire
first I copied an idea seen elsevhere on forum_ drille hole in that cover
but it still was to short and holded cover under tnesion
so I decided to lenghten it with original piece left in garage from some Polo
ofcourse it has to be thermo protected so we used this beauties
fire source from Wegner for swiss army hehehe
bout ends were protected and than second thermal sleeve from added part was used as second barrier to protect soldering point (did I wrote this right??)
neat and clean
Edited by davojuri
And further progress was made:
in place with cover
we added additional nut under it to raise it and move away from cover as much as we can:
closed it with inox nut with cap
and final result is here. nice and clean:
almost factory like hehehehe
Due to the fact my car was running like with cold, when I press throttle fast it doesn't react as before, no vag com errors, coils were new, TB adaptation done. I checked my IK 24 preggaped to 0,024" (0,6mm) and they were oppened to 0,8mm, we  reduced the gap but still not taking throttle like my car did before.
Ordered some new ones, but this time no tax for foole (pregapped), we gapped them by ourself!!!
HAven't finished car so I still don't know if that was the problem
I finally had  time and had that hood holding bar powder coated black glossy
So it's finally time for that oil ****ing 034motorsport Vortex catch can.
I decided to use some fluorolined hoses and to reroute that vapor and oil mixture underneath the car.
Idea was to remove that air filter on top, and to use some
180 degree hose:
SFS was perfect choice, 25mm
it has green inner fluorolining
25 to 19mm adapter is going to be ussed to connect it to 19 mm hose planned to gou under the car behind the subframe.
I simulated it with an old 19mm hose and sow that 45 degree hose is needed
ASH was the choice for 45 and straight one. Unfortunatelly they don't do 180 degree one
Just hate those blue barbed connectors. Couldn't find black ones 19mm.
If anyone on forum can give me a link to black ones I will appreciate it.
ASH has red inner fluorolining
remowed the air filter
shortened one leg of that 180degree elbow for tight fit under the hood and as much as possibble stealth look
to be continued......
Edited by davojuri
Great work as always!
Do you ever drive your car, or are you too busy making it into a work of art?
hahaha thanks..... yes I drive it and how...that's why I'm sad right now...hope to solve it with sparks....
tomorow will finish catch can rerouting, replace one Mishimoto with Forge coolant hose-due to the leaks, and shorten some silicone hoses i've put for servo pump, and will put large underengine plastic cover, like for diesel ones....
Edited by davojuri
Unbeleivable...i only just bought mine a month ago but seeing some of the projects on here, i feel like going into hiding...
in place with cover
nice buddy, looking great ..
I also trimmed mine both the 2 front plastic lugs and the rear section that is near cam belt side
I finished yesterday may catch can rerouting installation
I did cut that elbow as much as possibble to have clean look
conected it thorugh 25 to 19mm barbed conector to 19mm hose
routed it behind subframe
20140321_214105_zps5e4a4ab3.jpg]
fixed it with 2 adel clamps
and did cut excess horisontal to the floor
final result
Edited by davojuri
Did also replace that low quality Mishimoto radiator hose for Forge one:
it was to lose on both ends and did leak regardles of tightened clamps
did also shorten that horisontal hose with ASH sign on servo pump because it was rubbing on that plastic lateral cover
That's all for now
Edited by davojuri
And yes car runs like crazy again....
new sparks solved the problem heheheh
  • 3 months later...
While imping my CRV with some red fender washers like here: 20140623_205849_zpsaez0utlf.jpg 20140623_205853_zpsbtpnrd27.jpg 20140623_205856_zpstrqfhfqc.jpg 20140623_205902_zps7rrbey6s.jpg I came to an idea of ussing them om my SKODILAC baby. So I bought a 60pack of them, additional 20 red for CVR, 20 black and 20 silver to see which will suit better 20140623_202717_zps3ytygwup.jpg 20140623_202722_zpsjcrx2r4n.jpg Installed black on one side 20140623_205721_zpsbp17zyeh.jpg 20140623_205728_zpsloagrbbn.jpg and silver on another
20140623_205802_zps0wc4qhz2.jpg Which ones do you like more??????
Edited by davojuri
  • 2 months later...
Finally got the time to complete rear btakes upgrade.
Bought Zimmermann drilled 330mm vented rear discs from www.ultimot.de together with centering ring,bracket and bolts
New EBC NDX bluestuff
New rear left caliper
Some Mintex racing juice
Installation in progress
Final result
Old ones
My babe
Edited by davojuri
final result
So you are venting the catch can to atmosphere. Is that a good idea on these cars. I heard you need a least 25mm outlet to avoid crankcase pressure build up. Also a lot of oil mist will be spilling out on the road which might not be best idea.?
Yes above correct it req the pipe to be plumed back to intake
To atmosphere req min of 25 mm and Atleast 2 outlets
Without this you will increase the crank case pressure causing oil blow by and premature ring damage
Ok. I can always put filter back on catch can with 25mm ID connection. But when it was so it was spiting oil out of can and making me crazzy even it is so called "vortex" system from 034motorsport and no oil is supposed to come out except evaporations. Now there is no oil mess underneath the car. Or I might go 25mm all the way down instead of 19mm. Both ways it was drained to atmosphere but manny thanks for pointing out that 25mm issue!!!! I will for sure reconsider it and either put filter back or 25mn all the way down.
Edited by davojuri
