New Croatian VRS 236hp 19inches
It ended up like this:
Edited by davojuri
  • Replies 1.2k
  • Views 181.4k
  • Tom from sem motorsport decided to make some more  of his big port passenger side (LHD) intakes for me after seen my build thread. At first he rejected me,and after few days me being desperate and con
  • Pay attention to fine precission tools and protein drink
So all the hoses alre completed-coolant ones, vacum lines, breather ones......
now to the oil cooler lines and connection to the Mocal sandwich thermostatic plate
like this
I rerouted that installation to free space for aftermarket senders and fixed it with adel clamp
Edited by davojuri
Now its tim,e for the fulel lines, fuel rail polished with An6 adapters, and FPR gaude
I polished fuel rail and got some AN6 connections for flare conection and tube connection, and also hose finishers
Height stimulation
front one is ok, rerar one will be to high, that's why I took also that simple hose ends in case that one can't be used
I tried and mounted one quick connection-silver one and simply can't remove it, because it wasobvious that rear one can't be the same and that we decided to go with both same ones-plane finishers.
Tried to remove it and had to break it and than
I decided to open that plastic cover that holds that three tubes and sow that they can be mixed in order two fuel lines and one vacum line, I moved fuel lines in front and moved vacum line in the back so after I get neq qucik conenction I will put there also new ones
finally all the lines as I wanted and even more....
now remaining items:
coils with new powder coated springs, camber plates with new Oring seal , greased with WurthHHS and Mobil!
New right spindle
New brake lines
New clutch braided SS line
New powdercoated dog bone with new poly front bush
powder coated LCA with new Moog ball joints and Superpro castor bushings
New cnc baffled sump and connection to it
UR rear lower stru etc...
See you tomorrow
New USP braided clutch line
Dog Bone upgrade.
I already had yellow rear insert from blackforrestindustries
BFI MK4 Stage 1 Dogbone Insert
http://store.blackforestindustries.com/bfist1doin.html
but I wonted it powdercoated like ecstuning one
http://www.ecstuning.com/Search/Dogbone/ES5669/
or RAImotorsport
http://www.raimotorsport.com/Performance-Dogbone-Mount-p/rai-pdb-0001.htm
but they both have retained OE front bush.
I wonted it to be completelly upgraded so I purchased
Powerflex PFF85-505
IMG_20120705_185646_zpscae106f0.jpg[/size]
So it went like this
after powdercoating
Awesome car and build mate.
Attention to detail is second to none.
I'm glad you and other noticed it. That's main reason why am I putting all this pics here. Wanted to share my passion for details hehehe
Now to subframe, control arms, Superpro castor bushings, Tyrolsport solid subframe bushings, new right spindle and coils with camber plate
Before powdercoating
Subframe bushings pressed out
LCA bushings pressed out
note on rear ones signs of pression because they are flat all the way, no elevated pivot point like new Superpro
After powdercoating here:
http://www.plastifikacija.com/gallery/Auto-moto/index.html
preparing for solid subframe bushing installation
Everything nice and easy BUT when tried to fix left LCA we found out that the inner nut for front bushing has felt of and has to be rewelded-meaning-cutting, welding the nut and than welding the subframe and again powdercoating. It was late in the night last saturday. Ony Sunday we did welding like here:
Points marked
some cutting like here
welding the nut
Closing the oppening
finishing for powdercoating
and early in the morning 7am I went to the powdercoat store to coat it again-many thanks that you took me over the line and removed big customer to make me a favour so I can install it the same day-monday-minimal time loss. Thanks to both Igor!!!!!!!!
Not perfect but corrected with minimal downtime
and now LCA and castor bushings
Here is the schematic diagram how to put it right
But in order to be most precise you need to put subframe on the ground and put both lca in to the positions, because LCA transversal axis is not vertical to its longitudinal ones, tey are little moved tovard freont.So you need to mark middle of the rear oppening in the subframe than mark middle of the rear oppening in the lca's, on both sides, mark middle of the bushings when placed like on schematic drowing and now you have merks for pressing them correctly down to the lca. It was the way I tought most accutrate is.
I also replaced ball joints for Moog ones, but did use new OEM nuts , also all the bolts for subframe and lca were new, but I first installed old ones and while geometry was adjusted on Howk Eye Elite we replaced them
There is also one other possibilities to go for Whiteline ones, but I didn't go this route, because excentric holke is in metal-maybe to ww+eek on one side not in bushing
Edited by davojuri
And now coils and camber plate.
I have D2racing coils mode Track Racing, 13 kg front 9.5kg rear ones and ground Control camber plates.
Springs were black:
so I went for racing red to pair it with neuspeed anti sway bars front and rear
and here are TT or R32 ones-they are two piece design with much less rubber
OE ones are 1 piece with lot of rubber
and here are solid ones
http://www.plastifik...moto/index.html
Edited by davojuri
And now how did I assemble coils and camber plates
D2 reccommends to greas them every 3months to avoid that "Qdoing doing" sound by turning wheels in place. It makes me crazy.
For the metal and plastic rings above and belove springs I ussed Wurth HHS as reccommended by dealer in Croatia
and for camber plate Mobil 1 grease I got specs from Forge Motorsport UK
I ussed additional metal ring above plasric one on the top of the spring bellow camber plate (in D2 drowing there is noine)
like here it was before
parts here
Edited by davojuri
Coil assembly
Firts metal ring
than plastic ring
second metal ring
Springs and above it again metal/plastic/metal ring (I added that last one)
otherwise like here:metal ring, plastic ring and camber plate on top
and camber plate sitting on metal ring instead on plastic one like pictured above
Camber plate parts in order to install
Had to replace that O ring on one side
Final result
>few words regarding camber plates.
I did quite a research and up to me Ground control ones are the best
http://www.ground-co...tion.php?II=653
KW makes them also in Clubsport 2 way adjustment one (from Seat Leon Cupra R) but verry little feedback on them
There are also H2sport ones
http://www.h2sport.c...s/sport-camber/
http://www.flickr.co...157629956523671
Mujst say temptiong one to try
compared to their first version
http://forums.vwvort...ead.php?4440039
http://forums.fourti...ead.php?4871294
Have also their sport spindles, before I went for TT ones.
Here is nice comparing thread among GC and H2S
http://forums.vwvort...t-Camber-Plates
Had also Kmac stage 2 camber plates- b..l s..t
Edited by davojuri
Now some customization of GC plates
Like first they offer it in few diameters for springs:
1. stock spring ID
2. 2 1/4"
3. 2 1/2"
4. 60mm
due to the fact that my springs have 62MM ID I went for smaller diameter so I can upgrade to a bigger one very ease-I cnc-ed few 1mm rings and I got exact 62mm diameter like here:
much easier than to mill it for smaller dimenssion
There is also another upgrade of mine.
They reccomendded using this nut:
and I found it not good enough by limitting bigger castor/camber increase.
So I went for Golf 2 one likke on the picture bellow- first below to the rings
That is the tiniest nut with biggest adjustment range.
By geometry adjustment together with TT lca I can easilly get -3 camber!!!!!!!
THAST'S ALL FOR TODAY, HOPE YOU LIKED IT GUYS :rofl: :rofl:
:rofl:
:rofl:
:rofl:
:rofl:
:rofl:
:rofl:
:rofl:
Edited by davojuri
Any idea how many km's you got out of the old superpro's ?
I think my gen1 castor correctors are in similar state to your old rear bushes after < 10,000mi/16,000km
I hear these introduce bump steer
Looking forward to seeing details of GC fitment to turret :thumbup:
These are Powerflex which I tought are the best before I sow other doing the same or better job.
They must had 30000km, but up to me it doesn't matter, because Powerflex are flat all the way on top and bottom, and Super pro have small elevatet conical rings that allows free LCA pivoting, what can be clearly seen on my pics-that is the main difference.
KMac deformed very quickly on ra<cetrack near my home where I used to drive (after this install and paint job no more-cheaper is to rent Grandfe punto or clio sport and no worry).
And they were not precise as they should in alignement and fixation the desired position. Special bump steer didn't notice
Edited by davojuri
gen 1 superpro were flat
The extra bit of molding was a design change about 1yr ago due to excessive wear issues with the gen1
That's has sense-great upgrade and not only by conical rings but the hole for metal shaft is conical to on both side so the shaft touches it only in the middle and can pivot with its end sides as seen here
Edited by davojuri
Did replace right spindle to.
I compared it to old one on the car
http://s537.beta.photobucket.com/user/davojuri/media/IMAG1433_zps8f94e028.jpg.html?sort=3&o=913
and we measured 4mm differences in positions what has been recorded before while wheel alignement.
o I bought spare one and did prepare it for bigger A4 bearings which have double inside measure like here:
that way it can sustain greater axial load, especially on the track
O fourse wheel hub has to be addapted to
bearing beeing pressed out
damaged after
old vs new powder coated one
new bearing pressed in
and wheel hub to
Did replace also old brake hoses because they were to short and had to run them inside coil strut-was rubbing against spindle. Had it rubber protected but was anxious all the time.
So 10 y ago I have put ones we made in Zagreb in Croatia in VEP Hidraulika but they didn't have that small slide for secure clip on connection to the fender as seen here
Than I replaced it with ones made by
Brake Hose Production from Itally.
Great service and quality, but first ones were to short so I ordered longer one-all can be custom done there (set of 4 was 75eur)
http://www.brakehose.it/eng_news.htm
older short ones
new longer ones
right connections
Bleeded with Mintex racxing fluid
Wheel alignement was done on the most accurate device Hawk Eye Elite
All new bolts for front and rear subframe and LCA ptoperly torqued (70 and 100Nm plus 90 degree turn)
and while I was there we did instal this beauty to:
Edited by davojuri
had to made some space on rear left side
