New Croatian VRS 236hp 19inches
Some more pics of new front grille badge on the car as promissed:
  • 4 weeks later...
  • Replies 1.2k
  • Views 181.9k
  • Tom from sem motorsport decided to make some more  of his big port passenger side (LHD) intakes for me after seen my build thread. At first he rejected me,and after few days me being desperate and con
  • Pay attention to fine precission tools and protein drink
After so much expected install final pics are here
detailed build to comr, some more things to come
So itz all started with custom paint job.
We dismantled car completely in my garage-all dors and hoods and bumpers were of.
All prepared and than custom painted. Standox 2K laque and small silver particles changed for large one to reflect light more and Xyralic additive added, several layers.
Than it was sanded with 3M Trizact 3000, and than polished to mirror like surface
3M green, Maguire 105, 3M yellow and blue.
Prepared for painting
Painted and being polished
FINAL RESULTS MIRROR LIKE FINISH HEHEHEHE
SPECIAL EFFECTS ON THE PAINT
Than I started collecting parts for big build. I wanted to complete my delete process, and to completelly delete SAI,N249,EVAP and PCV, to have polished cover, boost pipe, intake, TB, alternator, oil filter housing and catch can. Also wonted to have ss braided hose for breather lines and AN fittings, and all other hoses in blue silicone.
So I bought: INA engineering baffled sump: IMG_20120626_233947.jpg together with PTFE paste OC THREE and stick Slik Tite IMG_20120626_234005.jpg Lots of An fittings, straight, 45 and 90degree from Setrab and Torque.co.uk-besp place for fittings in eu. New air duct 2 ply IMAG2039.jpg to replace old one IMAG2046.jpgIMAG1726.jpgIMAG2085.jpg Bought also Devil eyes headlights and upgraded them with projector bi xenon lenses 6000K and silver chrome indicator bulbs, and Ring xenon ultima H1 and 7 bulbs IMAG0711.jpgIMAG0874-1.jpgDSC01122.jpgDSC01117-kopija.jpgDSC01121.jpg and finally protected them with clear protection film from Global Mishimoto coolant hoses. Mishimotocoolantlines3.jpg 11 in kit, but only 4 are straight forward installation, used rest to make needed ones. Deleted OE oil cooler so I connected those two lines
IMAG2097_zps2523f98c.jpg and made this one to http://s537.beta.pho...ml?sort=3&o=265 IMAG2099_zpsed6c9b24.jpgIMAG2089_zps250a5ad9.jpg Ultra racing rear lower strut IMAG0246_zps2c211ed0.jpgIMAG0247_zpsc8bea529.jpg Powerflex PFF85-505 lower engine mount front bush
Edited by davojuri
Superpro castor increasing rear lower arm bushing SPF3397K to replace Powerflex one
Right powder coated spindle prepared for larger A4 bearings
Tyrolsport solid subframe bushings
New coolant tank to replace old dark yellow one
Edited by davojuri
An fittings, khoul tool, wrenches
USP clutch line USP002C
Setrab 913 oil cooler
Mocal Sp1T sandwich plate
Additional adapter plate for sensor senders
Had to shorten shaft-made new, to eliminate OE cooler and put that two plates together
Planned to be like this
Fuel lines An6 mounted on the fuel rail
Goodrich fire protection sleeve up to 2000F
Motul vpower 5V40
this is seriously modding....love it.
I see your pictures and analize them in detail.Hell of a job!
buuut.....those headlights are poo.
Than I polished valve cover, sump, catch can, oil filter housing, Mocal sandwich plate
alternator
, boost pipe, intake manifold
, TB and TB adaptor plate
, fuel rai, , door latches
, TB bolts, intake manifold bolts
fuel rail
Edited by davojuri
Fluidampr crank pulley
but couldn't mount it due to the fact that I already had ecstuning pulley set with underdrive crank pulley and enlarged PS pulley to compensate that and to be able to run oe belt PK1195mm.
So I will probably need to replace that PS pulley from the set
ECS 1016C
http://www.ecstuning.com/Volkswagen-Golf_IV--1.8T/Engine/Pulleys/ES420/
for the standard smaller one ECS1066
http://www.ecstuning.com/Volkswagen-Golf_IV--1.8T/Engine/Pulleys/ES8928/
Also did install Gates racing timing belt T306RB
with new tensioner roller and idle roller
Edited by davojuri
Remowed lot of stuf and sent it to powdercoat
subframe glossy black
lowe control arms glossy black
dog bone VW racing blue
Springs Racing red
Front bumper mesh x 3 glossy black
Bought S4 TB 70mm
one and also adapter plate 70MM THROUGH
and had it polished to
and had intake manifold port matched from 60 to 70mm to have real 70mm upgrade
new throttle body hose with DV relocation connection
63mm alu joiner and 63-76mm silicone coupler
Edited by davojuri
42Draft Design modular 3"down pipe was sent for new ceramic coating by
www.kavsmotorsport.com
it was coated with black Satin inside and out,
and had to do it again becausde ceramic coatging I bought with was Jet Hot from USA silver one and was peeling down
with some new gaskets
in place
with OE egt probe tightened with Resbond thread locker resistant to 2000F
Edited by davojuri
Did brake boost mode
and eliminated that "Y"
and also this metal hoses for full lenght silicone ones:
Both metal parts were replaced with full lenght silicone ones. Firest one is air line, so I remowed oe one from the TIP and used its heat reflection sheat to protect it and routed it up rto that plastic canister and over the intake mani and fixed it there with two adel clamps
all the way to the plastic canister
and other one coolant one was run from that "Y"fplastic piece in big coolant line below intake mnanifold toward coolant ttank, also fixerd for intake with adel clamp and used barbed connector to connect small first piece from Mishimoto with straight silicone 8mm
did also replace that tube behind coolant tank
than I went back to the remained black rubber tube going from the N75 to the wastegate from the middle, took it out, replaced it with 4mm vacum silicone one and used oe heat reflection sleve to
and brake boost mode all the way from the cabin-replaced all black rubber
Edited by davojuri
Much more to come tomorrow
Much more Wow !!! Excellent work.
Awesome work beautiful car
But make sure you run the fluid damper as the other pulley you ran will end up destroying your engine as it takes away your harmonic balancing one of the biggest killers of engines !!!
That is some epic engine bay bling!
Shiny B)
Where did your strut brace come from - custom ?
Shiny B)
genuine APR real carbon one. Out of production, but did some modification:it was mentioned for golf 4 and bar was to high so I cnc made lover connections-vertical one at the ends. And that rings arround shock were not circular-had to make them Because original one were placed wrong by installation-oppening facing inside instead outside-uou cant rotate them because of drilled holes-so I simply finished circle and added two more joles hehe. Will show you pics to
Edited by davojuri
Fantastic looking car you have there, real quality work, well done, cant wait to see next installment. :thumbup:
Show your level of skill as a surgeon I expect no less
Amazing work and attention to detail to die for I would have you working for me in a heartbeat !!
Guys thanks for support. Yes my passion is in details hehehe.
I just hope my surgery is at the same level as my work on the car hehehe.
To be onest spending a night in garage reliefs me of stress completelly related to work, for example yesterday was 24 hour duty for me.
So to continue with my installation: catch cand and breather lines-braided ones with An 10 connections
I used my 034motorsport wortex can and had AN10 welded on, than I polished it together with other parts, due to the pact that that wortex principle wasn't working well-spilled oil from time to time through that breather filter I enlarged that diameter fopr oil return. Originally it was 2mm made by Javad, and I assumed it is to small so we manufactured larger one with 5mm ID anbd made also same connection to be put in An10 to An10 male adapter with 1/8siude NPT port
than I routed it toward connection on my new sump, and all thet after shaft was reinstalled together with that plastic protection.
Due to the hight surrounding temp i used Goodridge heat protection sleve to protect it from temp damage.
the tube was routed to the 1/8NPT connection above bracket that holds turbo from below on the engine block, in order to avoid any accidental contact with shaft, so I drilled hole in that bracket
did fix it with zip tie fixed in that hole
Now its timke to put together breathing system
I ordered weld bung An10 and welded it to catch can
than 90degree An10 toward "T" distribution between valve cover and oil filter housing-block breather.
Bought An10 adapter for pressing into the valve cover after OE removal
Valve cover adapter was freom Integrated engineering ands block breather adapter is from 034motorsport
Edited by davojuri
