Yeti Tyre and Rim Guide
Thanks Pinkpanther.
Obviously some people didn't read your posting at #94, however..................
It does seem not to tally with what Tim has found in the past!
Confused?
No more than normal!!
I think I'll stick to 17"
  • Replies 199
  • Views 164.6k
  • Rainworth certainly came up trumps, in my view. Spoke to Johnathan in Parts and secured the following deal: a set of 7Jx16 steel rims with a set of Yokohama Geolanders a/ts 215/65 r16 98H fitted, bala
  • Please ignore the above advice! 15" wheels have NEVER been a fitment on Skoda Yeti's at ANY time and have NEVER been approved for them. Post reported.
  • Hi John, my insurer was OK with me putting 205/55 R16 steel rim'd tyres on my Yeti as A) winter tyres were not on their list of modifications and B ) I stated I was following the manufactures handboo
Thanks everyone - we are "talking this subject to death" - but maybe that's how it should be as the information in this thread is really comprehensive and gives all the options and advice needed - it is worth re reading from end to end
Another great job TP
Edited by BillN_33
Called in to Cost-co yesterday and had my old Michelin Alpin's refitted to a spare set of Alloys, ready to go on the MK1 Octavia 4x4. Whilst waiting I noticed they were now stocking "Yeti sized" 225/50/17 Michelin Alpins. These came in at just under £700 for a set of 4!!
Cost-co do run a "25% off"(3 for the price of 4) tyre promotion from time to time, but I'd be surprised if this came up during "winter tyre season".
I left pleased I'd gone for the 16" option from my local dealer (x4 steel rims @ £140 & x4 Hankook W310 205/55/16 94V @ £280).
Just need to locate a set of suitable wheel trims now!
Confused?
I've experienced this kind of thing from Skoda / Skoda UK before Graham
I purchased an "approved used" Mk 1 Octavia vRS several years ago. Several weeks after buying the car I heard about the "4 year cambelt change" from a friend with a 1.8T Passat. I spoke to Skoda UK, who confirmed I needed a cambelt change at 4 years. My local dealer told me they'd never seen a failed cambelt on a 1.8T and considered the 4 year change limit to be "guidance" only. They refused to change the cambelt, although did tell me they would cover "any and all" costs, should the belt fail.
I then took it upon myself to contact the Skoda factory directly (by email / google translate) and they replied the belt change was due at ~120 0000 KM, with no stipulation on a time limit.
I was left somewhat confused by this and following several heated exchanges with the service manager, eventually negotiated a new cambelt at the cost of the parts only (~£70 from memory).
Several months later I received a circular from my local dealer stating that my cambelt was due to be changed at 4 years - O'h how I laughed :rofl:
just to add a little more confusion, and as TP indicated, - there are only two tyre sizes mentioned on my "diesel" filler cap,
One for the 17" wheels
and 215/60/16 for 16" wheels
(no mention of 205/55/16 )
Edited by BillN_33
To add a little more confusion, there's been no mention of 215/65 R 16s - according to the Russian Yeti Forum, some 21% (100 of their members) are using this tyre size for winters - https://docs.google....ZYTE5N0FLeUE6MQ
Around 6% more ground clearance, and a wider choice of A/T tyres (eg General Grabbers) sounds tempting. :think:
What about 215/60 R17?
More ground clearance and what Delta 4x4 fit to their raised Yeti.
Yet another 'unapproved' tyre size.
I expect some insurance companies will cover the increased wheel size.
I wonder how easy is it to recalibrate the the speedo and odometer.
As the speedo/odometer is electrical, you won't be able to. Type Approval won't allow it.
^^^ No so sure about that, as it is an option on various Audi's.
Right then. Got the new Yeti. Got the steel wheels on it, with winter continental tyres. Bought a tyre tree to store the wheels/tyres.
How do I get that centre cap out of the alloys without damaging it? Can't put them on the tree without removing it,
Simply push them out from the inside of the wheel.
Yes they just push out; held in place round the edge of the cap by a metallic spring clip. If their being a bit stubborn rest a piece of wood against the back of them and give it a gentle tap.
TP
"I wonder how easy is it to recalibrate the the speedo and odometer?"
So long as the error is within 10%, you don't need to. As has been mentioned here somewhere else, the 215/60/16 winters I am running have a slightly bigger diameter than the summer 225/50/17, but everytime I go past one of those speed indication active display thingys at the roadside, the speedo is over-reading with either set of wheels fitted -by roughly the same amount - at least 10%! This tolerance gives manufacturers the ability to offer different wheel/tyre combinations without recalibrating the speedo, but it also allows them to use different tyre manufacturers for tyres of the same size because if you have ever stood 2 tyres that are the "same size" by 2 different manufacturers alongside each other, they are nearly always different. Everything has a tolerance. As to what the "type approved" sizes for a particular car are (& hence insurance affecting) that's a whole different ballgame even if the apparent overall rolling radius is within the 10%. My petrol cap also quotes my 215/60/16 as an alternative to the 225/50/17s. Vrederstein Wintrac extremes here. Brilliant! Would like to try the new Conti TS850 too though sometime, but it's yet another tyre they don't make in "Yeti size", just like G/year assymetric s2 F1s, Vred Sportrac 5, etc etc. Frustrating really!!
Speedo reading is factory set and I don't think the dealers can adjust it from enquiries I made in 09. My Monster is factory fitted with 215/60 R16 tyres and she's very close to the reading given by our Garmin sat nav and these street signs (no more than 4mph out at 70 + speeds).
TP
Measured mile is the only way to check accuracy with any certainty.
The only problem is they are usually found on motorway hard shoulders. :(
  • 2 months later...
Very confused by all the tyre gobbledegook in this thread (I am female and this is man talk!)
So can I just ask, I currently have 215 55 17 winter tyres on my car. If I buy a Yeti 1.2 tsi elegance can I put these tyres on for winter?
Yes these tyres will fit the standard alloy rims on a Yeti Elegance, although be aware that at 60mph you will be doing 61.1mph, therefore a 50 profile would be better. Additionally I would advise checking with your insurer that they would be happy with you fitting a non Skoda recommended tyre size for the Yeti.
Recommended sizes
225/50 R17
205/50 R17 (winter pattern)
Regards,
TP
Ah ok thanks TP.
I'll keep the winter tyres when I change car then decide before next winter comes whether to use them or not.
I promise I've read every post here to search for an answer, but I apologise if I've still missed any mention of it (it was a 'man-look' after all).
There is plenty of discussion for different diameter wheels here, but I was wondering if anyone had tried, or knew what the results would be, of putting a 17 x 7.5 wheel on the Yeti? In particular, the R-type VW wheels in this photo:
According to the description on eBay, they are the same offset as the Spitzbergs - 45mm. According to the tyre calculator linked to throughout this thread, the 225/50 17 tyres I'm running (they're the Dunlops from memory) will work on up to a 7.5in wide rim. Given the offset is the same, I'm guessing this means the wheels will stick out an extra half inch from the baseplate (rather than a quarter inch either side) - is that right?
So, does anyone think or know if there will be any rubbing issues, or speedo issues? For the latter my guess is no, since I didn't think I'd be affecting the overall diameter or circumference. But I wanted to ask here to be sure.
Thanks in advance.
Thanks in advance.
225/50 17 will fit on 7.5J rims with the sidewalls being a little bit straighter / splayed.
However wheels will be quarter inch wider on both side (not half inch on the outside) so be careful of clearance inboard.
Ideally, if you are going from 7J to 7.5J you should aim to take ET45 down to ET39; the inner edge of the wheels will then be in the same position and the outer edge will be further out. For comparision I run 7.5J ET35 very successfully with 225 tyres as 'summer wheels'.
But you failed to mention they are 18" rims, so have better clearance anyway.
:lol:
Sent using whatever device I'm using at the time.
:lol:
It's true, Mike, that my summer wheeels (still firmly in the garage by the way) are 18" ....
......... but surely for the purpose of the discussion whether we're on 17" or 18" rims is of no importance as we are discussing tyre width and offset.
Guy
Err not sure the 18's are taller and further away from the strut......
I suppose they would be if the strut is inclined inwards.
Which it was when I last looked!!!!
