J5's Roomster Scout - **SOLD**
It is interesting because I didn't specify where I wanted it placed, I just assumed it would be in the usual place above my head. So when I got in to programme the Parrot I had to spend a minute or two looking for the microphone. When you think about it, there's no better place. After all I'm looking through the windscreen directly over the dials. Obvious really.
Edited by richardf
  • Replies 341
  • Views 98.9k
  • A few things to bring the thread up to date. Whilst moving some steel rims around in the Roomsters ample load space, I succeeded in fracturing a component part of the seat locking mechanism whilst th
  • Headed down to JKM this morning for a run on their "Heartbreak" rollers...... That is all
  • So having booked Ultimate Dubs, my usual tongue in cheek approach to the heavy 'scene' ensued. Cue the milotec splitter that had been in the garage for a year, and the obligatory windscreen sti
Nice looking Roomster Jonny :thumbup:
But then mine is an Anthracite Scout so I am biased :D
Thanks for taking time to post your guide to cradle installation.
Quick question - does the end-of-dash trim panel just pull off?
I need to take the panel off mine in order to investigate a rattle.
Thank you.
Thanks Robjon. Indeed some gentle persuasion with a trim tool and comes away easily.
Best of luck finding the rattle :thumbup:
Many thanks Jonny5ive.
With the panel removed, the source of the rattle became obvious.
A part of the plastic dashboard was in contact with the steel bulkhead.
A small piece of foam pressed between the two silenced the rattle.
Cheers :thumbup:
Couldn't be @r5eD taking all the trim off again and TBH struggled seeing an obvious way to get the clocks out, I settled for removing the grill from the overhead light unit completely and this seems much better than the mic being behind it :thumbup:
There is no logical reason why one of these from the Ibiza/Fabia 6Y would not fit, but having read that folk could not fit them to 5J fabias I bought one second hand after lining it up as best I could in the engine bay on a cold and wet evening last year.
Save for a few more 'will it, won't it' efforts, it has sat in the garage until this afternoon.
First plan was to cut a notch in one leg of the 'plinth' upon which the vacuum control box sits to facilitate getting the brace to sit properly on top of the suspension turret.
I opted for major amputation of the leg instead B) 4 legs become 3.....
Bolted into place
Vacuum box 'plinth' back in place highlighting the clash of metal that would have been :giggle:
All fitted B) B)
I'll see how it rides for a few weeks, before taking it all off again to paint a more suitable colour :thumbup:
Good to see you got the strut brace and all fitted. :thumbup:
I remember you were after one around the same time as me.
It has taken a while :giggle:
I did try to point a few people in your direction when i saw one come up for sale. ;)
A few bits done today ahead of Castle Combe on Saturday.
Camera mount sorted
Got my stoppers fitted. Thanks Tyler
Set the RARB to stiff :)
At last manged to get pic of the tail pipe that UNIT18 sorted out for my Piper zorst.
hi barry aim having a strut brace made only for show in stainless steel and caps made for the suspension tops in stainlees steel
also fitted standard wheels in black with mk 2 escort hub caps plus trims with 1/4 white walls looks like a retro look
hope you are ok mate are you going to gaydon show
Sure am Pete. Midlands convoy leaving from Tesco Crosspoint - time TBA :thumbup:
  • 8 months later...
Absulutely Stunning Roomie...;)
Discs and pads for the rear on the agenda today. Thanks to j0hn for his assistance and the low profile trolley jack.
Stiffness anyone?
Yes, yes it needs a clean!!
MOT passed today, no advisories and over to see j0hn this arvo to change back to 17" summer rimmage B)
Looks brilliant! Love that last shot :)
Really pleased with how it handles, much better than my MK1 Fabia on Eibachs.
Stiffness anyone?
I think I've just had a slight accident.....
Stunning, J5.  Absolutely stunning.
More weight over the rear giving better balance?
Looks good, always nice to see something unusual on track. :)
I think it is better behaved due to the rear track being wider than the front.
Obviously being lower (circa -80mm) and the RARB help, and yes, thinking about it, not as twitchy at the rear under braking into Quarry as the fabia.
That said there was absolutely feck all in the back of my fabia :giggle:IMAG0153.jpg
I'm noticing that with the Yeti.
Even with the back stripped out it's better balanced than the Fab.
Didn't think about the track width differences.
80mm, that's quite a drop!
Because. Racecar!! A few pics from Spring PCAD at Castle Combe
Fandabydosy :happy:   That's what I call a "statement" B.  :dance:
Yes it is, but it looks much better, handles far, far better and IMHO the ride is no stiffer than my fabia was.
The only real difference I notice in "comfiness" is switching to 16's in winter.
One of a kind Barry B) ,      Keep it up mate :thumbup:
Looks great Barrie :) performs well on circuit too
  • 4 weeks later...
More power
Guest
