All gone please delete
Sold please delete.
Edited by mikey200615
What condition is the bonnet in?  Would you be prepared to post it & is so how much all in?
Same but drivers side front wing please :)
Me too, me too...Drivers side door posted please?
All panels above are gone, sorry guys.
Bump parts list updated to whats still available
Do you have the black VRS interior light (the one in front of the mirror)?
Sold, sorry.
Undertray and wheel arch protectors and front grill vrs badge price posted if still available mate?
Pm'd
Drivers seat?
Drivers seat?
Sold sorry
Do you still have the doors?
If so, Im after the drivers electric window motor (code :6Y2959802 SK1).
Along with both of the switch bases (drivers and passenger).
Would you sell the injectors separate? Thanks dan
Still got the MAF sensor? Any problems with it?
Hi folks, I will be stripping my fabia vrs for spares.
Engine is ASZ 127k miles timing belt done roughly 25k ago will put up a video for everyone to hear/see running.
If you need anything p.m me or text 07four76617455. Cheers.
**car located in Dundee
Click the link to see engine running.
http://i220.photobucket.com/albums/dd154/mikey200615/th_20150923_103013_zpsv1pzxlio.mp4
All prices plus post (unless otherwise stated) and welcome to offers. All parts are described as best and honestly as I can but remember its all used condition.
1.9 TDI PD Engine ASZ (injectors etc all still there but no ancillaries) timing belt and water pump been done last 20k with receipt - £300 (oil been drained)collection preferred
6 speed vrs gearbox (HDS GEARBOX CODE) - £200 posted (oil been drained)
Standard turbo very good condition held boost fine etc comes with actuator, oil return pipe etc see pic £130 posted
ABS Pump/unit - £30 posted
Radiator original genuine part -£30
Radiator fans twin -£40 posted
Battery tray -£10 posted
Aircon pump delete set up (comes with bracket that bolts to engine, smaller alternator belt and belt tensioner, DOES NOT COME WITH ALTERNATOR but your standard alternator just bolts on) -£30 posted
Alternator -£30 posted
Headlight washers and pipes -£20 posted
Standard intake pipe from grill to air filter -£10 posted
Standard plastic intake pipe from airfilter to aluminium pipe -£10 posted
Aluminium turbo inlet pipe -£20 posted
Fan control module -£ 10 posted
Bonnet catch -£10 posted
Coolant bottle -£10 posted
MAF sensor -£10 posted
MAP sensor -£10 posted
Window Washer fluid sensor -£ 5 posted
Front/rear window washer pump -£5 posted
Headlight washer pump -£10 posted
Outside temp sensor -£ 5 posted
Window washer reservoir -£16 posted
Front calipers and carriers £40 posted
Driver side driveshaft £40 posted
Turbo oil feed pipe £10 posted
Egr valve (not long been cleaned) £20 posted
Egr valve to manifold metal pipe £5 posted
Standard ecu £20 posted
Front wiper motor £10 posted
Dual horn £10 posted
Engine mount £20 posted
Gearbox mount £20 posted
Vacuum box/ball £10 posted
Crash bar £25[/b]
Edited by Woodlogy0
Maf sensor is sold sorry
Throttle position sensor?
lower centre grill? under reg plate
Hi, will have the dual horn off you - don't suppose you could throw in one or two of the slats from one of the centre blower vents if you have them too?
All of these are sold and gone guys sorry
  • 3 months later...
Is the dash still availablet?? If so is it a late spec one with the dimpled top half?
Do you still have any parts for sale?
Sent from my Hudl 2 using Tapatalk
I still have the dash but unsure what one it is
I still have some parts what is it you are after?
Boost pipes, especially the lower intercooler one. What have you got left?
