S3 owners - electric tailgate / hatch closing from inside
Would you pay for the rear hatch / tailgate to close from the button inside the car? 133 members have voted
  1. 1. Would you pay for the rear hatch / tailgate to close from the button inside the car?
    • Yes, I live in Kent and would be happy to travel to Folkestone and pay for this to be enabled
      18%
    • I don’t live in Kent but would still be happy to travel to Folkestone and pay for this to be enabled
      72%
    • No, I live in Kent but this doesn’t interest me
      9%
  2. 2. How much would you be prepared to pay for this?
Please sign in or register to vote in this poll.
2 minutes ago, Tom1214u said:
Can you please elaborate
Long coding (changing the bits and bytes) is carried out to tell the vehicle what equipment is installed generally. For the tailgate opening and closing this requires modification of the datasets installed on the control module for the tailgate itself. Soft and hard reset restarts the control module (I am not sure of the difference) to ensure the new dataset is being used.
VCP historically was the only tool available to edit datasets on control modules. However sometimes CarScanner can do it as detailed in the linked post above. BUT I have seen it where for an unkown reason CarScanner can not communicate with the control module. I am not sure why and I think it is dependent on hardware/software combination of the control module. As per the CarScanner FAQ:
4) In the current state of the coding, it says “Coding is not supported or faulty ELM327 device”, although other codings are applied normally. Should I change my adapter?
No. You are shown two possible reasons: either the coding is not supported, or the problem is in the adapter. If the adapter allows you to use other encodings, then it is logical to conclude that the problem is not in it. By the method of exclusion, we discard one of the reasons and we are left with one reason: the coding is simply not supported by your car.
The coding of tailgate opening /closing on key and internal button is very variable and some people have encounter major issues with the control module from just trying it.
  • Replies 225
  • Views 110.7k
  • seriousness aside -  a number of supercars deploy rear wing spoilers at high speeds for increased downforce/stability. bugatti, amongst others also use the rear spoilers as air-brakes too.
  • I've done 450 miles this week so far with another 330 to do tomorrow. Happy to drive to you. Happy to pay for it. Will bring you a pork pie and a decent bottle of melton red ale as a cultural exchange
  • As a disabled driver, I would happily pay a reasonable amount for this.  The non availability drives me bloody mad.  Who in their right mind would design a facility to open the tailgate from inside, o
