S3 owners - electric tailgate / hatch closing from inside
Would you pay for the rear hatch / tailgate to close from the button inside the car? 130 members have voted
  1. 1. Would you pay for the rear hatch / tailgate to close from the button inside the car?
    • Yes, I live in Kent and would be happy to travel to Folkestone and pay for this to be enabled
      17%
    • I don’t live in Kent but would still be happy to travel to Folkestone and pay for this to be enabled
      72%
    • No, I live in Kent but this doesn’t interest me
      9%
  2. 2. How much would you be prepared to pay for this?
Please sign in or register to vote in this poll.
Is it possible to just move the button to one of the blanked spaces?
I haven't got to the point of trying to pull out the centre consol for any reason yet but I am just guessing that the none button spaces are just blanks.
Moving it to the too corner is a good idea.
  • Replies 216
  • Views 107.7k
  • seriousness aside -  a number of supercars deploy rear wing spoilers at high speeds for increased downforce/stability. bugatti, amongst others also use the rear spoilers as air-brakes too.
  • I've done 450 miles this week so far with another 330 to do tomorrow. Happy to drive to you. Happy to pay for it. Will bring you a pork pie and a decent bottle of melton red ale as a cultural exchange
  • As a disabled driver, I would happily pay a reasonable amount for this.  The non availability drives me bloody mad.  Who in their right mind would design a facility to open the tailgate from inside, o
Has anyone tried the Passat parametry rear_lid_passat_5q0959107L.zdc for "L" block?
  • 7 months later...
I have a booking for Wednesday morning with a local VW/Audi/Skoda indie (Staffordshire) to hopefully get this done, if all goes to plan I'll reveal all the details and a video of it working.
Eagerly awaiting..............!
Sorry to say my local indie was unable to code this function, he could find access the files to see where he needed to add a code but he doesn't have the code, 😕
  • 4 weeks later...
Has any progress been made with which controllers can be activated to close the boot from the console button?
  • 4 weeks later...
Anyone did that with VCDS?
Has anyone closer to Oxford (you're a bit too far for me Gizmo) with VCP been able to code the boot shut from the interior button?
Also, I've tried numerous times inside and outside, front and back of the car to try close the boot with the key fob (holding, double press and hold, double press, etc) and cannot get it to work from the key fob.  Anyone have any ideas?
Not possible with VCDS
  • 6 months later...
Can this be done? Anywhere near Southern Birmingham?
I would pay in Madrid ...:D
Can anyone leave steps here to code tailgate closing from both the button and the remote, please? I have vcp. I find correct zdc. But what should I select in the right bottom corner? There are a lot of options in the list. Should I select all of them?! Thank you guys...
I mean in the right bottom corner when I go to upload file. Selected 6D controller, but idk what to select in the list under the list of controllers. I think it is what data should be uploaded...
Did anyone ever get this working on a MY2018 car?
Hi friends,
what is actually doing dataset decklid_superb_5Q0959107J_model2017.zdc for Skoda Superb III? It is original setting? Has anyone tested already?
Thank you
Regards
Jaro
  • 2 months later...
OK, so I just found this on a coding site, a folder of xml files for the superb 3 6d bootlid module marked 'remotekeyclose'
probably need odis to send them to the car.
since I have odis.. will test hopefully tomorrow. they were alongside bootlid paramaters for version L of the bootlid module, so since I also have version L, I'm hoping this will all be goodremotekeyclose.zip
Did you have any joy?
I was conflating two different things - this thread was meant to be about closing the hatch from the button next to the driver's seat, but these paramater files are for closing using the keyfob
I got this working myself today.
it's not coding, it's not adaptation, it's paramaters, for which you need vcp with the correct zdc file , or odis-e with the correct xml paramater set.
I have odis-e, and got my hands on the correct paramaters.
You need a vas5054a and a copy of odis-e installed to use these paramaters
they are marked for software version 261 hardware  H13, my module (late 2016) was 'J' revision and had this software and hardware
you can see your hardware and software versions near the top of a vcds scan of module 6d
VCP try and catch these paramater sets during communication between VAG group and copies of ODIS-E, they try and grab them and save them, then encrypt them in their zdc format to stop them being freely shared around, but if you have the xml paramaters (i.e. native ODIS-E) , you can share them,
if you have VCP and want the right .zdc for this, you can probably use a converter to convert these to .zdc
Again, I used ODIS-E ( via my aliexpress sources vas5054a adapter)  and this worked a charm
superb close boot from inside.7z
Edited by AlVal
  • 4 weeks later...
I wonder if this is something that can be done on all controllers, or just that specific “J” controller?
Hi, I live in Kent around an hour away (TN17) would certainly come down to get it done for the £20. I have just added a 2018 SEL Executive to my small fleet so was going to ask about doing it with VCDS as I do have that but if as you say you cannot then sure just for the convenience and if it can be done on the key as well, like my Alhambra all the better.
Hi mate,
could you describe how did you uploaded it with ODIS-E, please? :)
On 22/07/2021 at 16:50, joolsik said:
Hi mate,
Select the right module for the bootlid controller (6d), on the list on the right it's 'data transfer', and send the parent xml file (the one called "arbeits"), it will send any children files also
Would you be open to the idea of doing mines?  I'd happily pay for service! :)
No need for money, if you're local (I'm inbetween Milton keynes/bedford/Northampton) I can try and do yours
