Changing the Second Speedometer to MPH
Had my new Yeti 1.2 SE a week now, is it possible to change the second speedometer in the maxidot display to MPH?
Regards,
Graham
Edited by Guest
spelling
  • Replies 86
  • Views 23.2k
  • Falmouthboy
    Falmouthboy
    Exactly - and clearly over reading is proferable to under reading as owners would be complaining in numbers as they got tickets whilst thinking they were adhering to the limit.   I must say
  • Well, thanks to Nuriyan (Justin) who is one of the selfless individuals listed elsewhere on this site who offer coding help, my car now has an Aussie accent & a nice big MPH display. So anoth
  • Auric Goldfinger
    Auric Goldfinger
    Gizmo is correct, it only needs to be capable of showing MPH or KPH. i.e. tick/untick a box in maxi dot    The key word is CAPABLE
If you go into the Car settings on the Radio there should be a section called Units, I think you can change it in there
Edited by Auric Goldfinger
yes probably, you need someone with vcds kit to change the country to australia
Thanks I'll try it,
Graham
4 minutes ago, Frenchtone said:
yes probably, you need someone with vcds kit to change the country to Australia
Just now, Graham1941 said:
Thanks I'll try it,
Graham
Thanks, What's a vcds kit?
Graham
36 minutes ago, Graham1941 said:
Thanks I'll try it,
Graham
It cannot be done on the Maxidot, it needs the specialised cable that connects to a laptop and the software to make the change, the cable and software can be had for about £225 but most get someone near to do it for them for a bottle or 2 :)
This is it: https://www.gendan.co.uk/vcds-hex-usb-can.php
Thanks Urrell is it worth it, can't understand why Skoda have done that in a mph country, not everyone goes abroad. It would have been nice to be able to choose the units.
graham
Th VCDS software will let you change lots more as well as reading any fault codes and resetting them but for just occasional use it is too expensive.
It would not cost Skoda much at all to provide the option to display both MPH and KMH as it will do if changed with VCDS, it adds a tick box on the Maxidot to select either.
Edited by Urrell
There are a lot of posts on here about the reason for this. Basically the M/F have to have the option the sell their cars in other countries. If you want to read the posts use Google search.
Fred
Fred
I understand that Fred, but what would it cost to give the customer the choice?  I prefer the readout to be digital rather than analogue but I guess I'll get used to it.
I didn't say it can't be done, use the search to see how it's done with VCDS. It involves changing the country to Australia!
Fred
graham
Its the law to have  MPH and KPH as its not on the clocks they put KPH on maxidot
Edited by skoda1982
wrong advice
2 minutes ago, skoda1982 said:
It can fail an MOT Its the law to have  MPH and KPH as its not on the clocks they put KPH on maxidot
Here we go again...
It is not illegal to have just MPH showing, what the law states is that the car MUST BE CAPABLE of showing MPH and KPH, the VCDS coding change means that BOTH are available to be shown, all you need to do is to tick / un-tick a box in the maxidot to toggle between the small KPH and large MPH displays.
Fred
Thanks Fred I understand it can be done with VCDS, all I was saying is, it would have been nice if the user could have selected the appropriate units wherever the car is used.
Graham
Graham
This is now an option on the MQB platform cars (Octavia3 Superb3 etc)
29 minutes ago, Gizmo68 said:
Here we go again...
There is no need to say HERE WE GO AGAIN!!!! still law Capable or not
Not true, us MOT testers CANNOT fail a vehicle for not showing both scales, in fact the speedometer is not a testable item on a car or van, it's only testable on minibuses and coaches that have over 13 passenger seat.
35 minutes ago, Gizmo68 said:
Here we go again...
Under european construction and use regulations all cars and vans, not lorry's and buses must be capable of showing both scales, this is why KPH is shown on the maxidot.
Edited by Ju1ian1001
1 hour ago, Gizmo68 said:
Here we go again...
Let's consult the actual legislation:
http://www.legislation.gov.uk/uksi/1986/1078/regulation/35/made
Quote
35.—(1) Save as provided in paragraphs (2) and (3), every motor vehicle shall be fitted with a speedometer which, if the vehicle is first used on or after 1st April 1984, shall be capable of indicating speed in both miles per hour and kilometres per hour, either simultaneously or, by the operation of a switch, separately.
Pretty clear.  As supplied, the Yeti can do this by virtue of the second display in km/h. When fiddled about with VCDS the Yeti continues to be able to do this but adds the ability to display in mph as well.
Although why they want or need to see mph in Australia who went to km in 1974, who knows?!
I would have thought for the same reasons as the Maxidot showing KPH here.
Not the same at all.  Australia used to use mph but now use kph and have done for decades.  There's nowhere you can drive to from Australia that uses mph.  Here, anywhere we go across the border is in kph; we're one of a very few places left still stuck with miles.
Quote
Wow! Looks like I trod on a Hornets nest!  It looks similar to one we have in motorhome forums about the legalities of towing a car on an A frame behind the motorhome (which I do).  As a newby to the Yeti I just thought it would have been easy for Skoda to allow the driver it choose the mph of kph in settings doesn't seem rocket science to me.  Anyway I guess I will get use to it I wont bother with VCDS unless the dealer will do a freebee (lol).
Thanks for all the input it is much appreciated,
Regards
Graham
Quote
Dealers can't do it - they don't have VCDS.  VCDS can do a lot more in terms of configuration tweaks than the kit dealers have.  (AIUI it can even enable some functionality that is a chargeable option if you order it from the factory.)
+1
contact a knowledgeable VCDS owner.
VCDS owners willing to offer assistance are listed on this thread.
Edited by ejstubbs
