O3 FL High Beam Assist - VCDS Autoscan
I can confirm this works via OBDeleven as well using the same instructions.
  • Replies 72
  • Views 23.9k
  • I took the car for a drive last night and can confirm that High Beam Assist can be programmed onto an MY18 Octavia 3 as follows:   Requirements: VCDS: 17.10 beta HEX-V2 or HEX-NET in ord
  • themanwithnoaim
    themanwithnoaim
    @Black_Sheep it seems it can be done, well done @wg100
  • Which HEX cable are you talking about?   HEX-USB+CAN - can't HEX-COM+CAN - can't HEX-V2 - can HEX-NET - can   Why? - because VW have made some of the very latest mod
Requirements:
VCDS: 17.10 beta
HEX-V2 or HEX-NET in order to access controller 4B
A5 camera (You already have Lane assist or Traffic Sign Recognition)
Full LED headlights
Procedure:
  • Ensure light switch is off
  • Conduct a soft reset when accepting each change
  • Reset Light menu to factory settings after coding to display new menu option
Controller 09 - Central Electrics
Security Access - 16: 31347
Adaptations  - 10
- Search for Fernlicht to narrow down the options
- Menusteuerung Fernlichtassistent Werkeinstellung: Set to PRESENT
- Menusteuerung Fernlichtassistent: Set to PRESENT
- Erwiterte Fernlichtsteuerung: Set to AFS: FLA: FERNLICHT UEBER AFS
Menu option for "Light Assist" should be available in the Lights section of the Car settings menu (may require a factory reset of Light menu).
If you want HBA to remain active, with light switch in Auto, then code the following
- Fernlichtassistent Reset: Set to NOT ACTIVE
Controller A5 - Front Sensor
Coding (using experimental coding values)
-Byte 19, Bit 0-3 (00 FLA_Additional_High_Beam,no_Additional_High_Beam
-Byte 19, Bit 4-7 (20 FLA_Headinglight_Type,LED)
-Byte 21, Bit 5-7 (20 AFS_coding_Light_Assist,High_Beam_Assist)
Controller 4B - Multifunction Module
-Byte 11, Bit 6 (High Beam Assistance,Enabled)
You may get an error pop up regarding Headlight Range Control. To clear this, go to Controller 4B, Basic Settings.
-Basic Headlamp setting -> Go
-Acknowledge basic setting -> Go
Thanks for this worked great on mine. Error sorting was the final sort i hadn't done from the other link. I think the HBA is better than my last car.
TSR next...
On 27/11/2017 at 09:53, djduese said:
@aki78 I'm glad, that you use my list, but it is not allowed, to post screenshots of it.
In the future, please don't post any screenshots of it
I have removed the screenshots Daniel
Requirements:
VCDS: 17.10 beta
Full LED headlights
Procedure:
Adaptations  - 10
This worked a treat on my 2018 VRS245, thanks for sharing!
I’m happy to accept thanks in unmarked £ notes in a brown envelope...
Edited by wg100
I’m also going to pitch in with a thanks for the above procedure. Got it activated on my FL, although I have since turned
it off as I didn’t like it haha.
Yeah I've gotta add a big thanks to @wg100 for tweaks incl. TSR, HBA, increased traction, fan speed in auto & rear teardrop wipe.
Would anyone like to tweak my O3 VRS FL...? :)
Depends if you want a drive to the Cotswolds... :D
  • 4 months later...
seems to have worked, thanks
  • 2 months later...
Are we saying that the VCDS HEX cable cannot code module 4B, someone is asking if I can do HBA on TROC and I don't want to waste their time if i can't.
Thanks in advance
HEX-USB+CAN - can't
HEX-COM+CAN - can't
HEX-V2 - can
HEX-NET - can
Why? - because VW have made some of the very latest modules use much longer CAN bus messages which the older HEX-USB+CAN and HEX-COM+CAN cables cannot be upgraded to handle, but the current HEX-V2 and HEX-NET can handle OK.
Guys I’m having a problem clearing the Beam calibration error. Using a RT HEX-V2 cable and coded HBA as above but cannot get the 4B module to run basic reset. Just keeps returning the message ‘Not Running’
Anyone else come across and rectified this. The coding seemingly works but the error remains..
I have tried reversing all coding( soft resets at each step and light settings in HU) but error still pops up in the Maxidot. Recoding doesn’t seem to change anything. Command for 4B basic settings will not run :sad:
  • 4 months later...
On 03/02/2018 at 14:02, dkvinyls said:
I'm italian can you help me you can confirm that the procedure works whit ODB Eleven, on Octavia FL year 2019 without errors. The car is equipped with Lane assist. Thanks for your help. Frank
Frank, I activated HBA on my MY19 VRS a few weeks ago as per the instructions above. No problems. Prego!
Thanks for your reply. for this modify, its's correct to purchase the standard ODBEleven 39 Euro from the official vendor,  whit the APK PRO buy from Play Store?
Thansk for all.
Frank
@happy2002 You will need the OBDeleven pro version I believe, whichever one that allows you to use long coding and adaptations.
  • 9 months later...
Hi guys got hba working on my 245 2018 but can't get rid of the headlight range control error! Can anyone shed some light at all? There isn't an option to reset basic headlight settings in 4b!
  • 1 year later...
Hi, all.
Just did the HBA tweak, courtesy of @wg100 fantastic walkthrough.
The only thing different on how to solve the 'Headlight Range Error' is how the setting is labelled.  The version I used was 21.3.0, so some options looked different.  The error was annoying and I thought I had to revert the settings back and must have messed it up.  Ross-Tech's support is amazing.  They responded to me within 24 hours.
It works a treat now and the error has been cleared.  I have also gotten the hang of using VCDS.
Here is the last step update fs you are using a newer version of VCDS (Module 55 Xenon Range is gone) and the Address 4B - 04 Basic Settings options that you need to click will have different labels:
It will still have [*IDE03675-MAS09980*] and [*IDE03676-MAS09980*] beside them but the labels are:
'Headlight adjustment Start 1 [x]' previously 'Basic headlamp setting' click Go! to activate the setting, no need to readjust your headlights, physically, unless you are also after that and Stop, once done.
'Headlight adjustment Stop 2 [x]' previously 'Acknowledge basic setting' click Go! to activate the setting.  The position should now be learned and the error should disappear.
Click 'Done, Go Back' and don't forget to clear any fault codes.
I have attached some photos and videos to help those having trouble.
Hope this helps those still having trouble or using a newer version of VCDS.
The support team of Ross Tech are top notch.  Thanks, Dana.
1 minute ago, gresini15 said:
Hi, all.
Sorry I didn’t manage to get back to you, but good job on figuring it out.
wg100
wg100
No dramas, man.  Your walkthrough was spot on.  I just got confused in the end so I had to contact as many people before proceeding.  It's scary to mess things, up.
Thank you, again!
Hi, all.
Just received an update from Dana from Ross-Tech that it has been updated.  She had sent me a file to update Basic Settings 04 in Controller 4B.
Please see the screenshot.  Hope this helps, all.
Edited by gresini15
