O3 FL High Beam Assist - VCDS Autoscan
Does anyone with an Octavia 3 Facelift MY18 vehicle have High Beam Assist specced from the factory? If so, and you've got or could get access to VCDS, would you be able to do an autoscan and adaptation channel map? I'm trying to enable HBA on my Scout, but the long coding is not editable as yet, it's just zeros.
  • Replies 72
  • Views 25.7k
  • I took the car for a drive last night and can confirm that High Beam Assist can be programmed onto an MY18 Octavia 3 as follows:   Requirements: VCDS: 17.10 beta HEX-V2 or HEX-NET in ord
  • themanwithnoaim
    themanwithnoaim
    @Black_Sheep it seems it can be done, well done @wg100
  • Which HEX cable are you talking about?   HEX-USB+CAN - can't HEX-COM+CAN - can't HEX-V2 - can HEX-NET - can   Why? - because VW have made some of the very latest mod
@wg100, it might be worth posting an autoscan for your vehicle too :)
I should have thought of that when I saw @andyvee this afternoon. Am thinking of getting VCDS for myself, so may be able to do so soon.
I had a look with VCDS and VCP and the long coding on 09 is just zero's apart from 1 byte.
Looks like they have 'masked' the coding
I don't think the coding is masked, instead it looks like VAG might be changing from lcode to adaption channels - at least based on this thread: http://forums.ross-tech.com/showthread.php?10616-Modules-reporting-zero-code-string
Andy, did you get an adaption map for 09? Might be worth posting it up on rosstechs forum as there are few people on there that might be able to help :)
No I didn't, the laptop battery wouldn't have lasted the half hour or so it takes to pull the adaptation map from 09!
Interesting though, this is the first FL O3 I have seen so haven't got anything to compare it with :(
I might try scanning my own Kodiaq and seeing how that is set up - I haven't had time!
I have an admap of my 1.5 SE L TSi DSG taken the day after delivery to me so it's fresh from the factory. I also  have autoscan which shows a couple of faults found.
Please PM me if you would like a copy.
Edited by YMe
Making sense.
Did you have high beam assist from the factory?
Yes.
2 hours ago, YMe said:
Yes.
Will get in touch when I'm back from a work trip in a couple of weeks.
These channels are interesting in YMe's map (with HBA):
ENG141650-MAS13782-Fernlicht_assistent-Will Beam assistant: responsivity adjustable via BAP    present
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung    AFS: FLA: Fernlicht ueber AFS
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset    active
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent    present
ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung    present
This is from another O3 FL (probably with no HBA):
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung    AFS: Fernlicht ueber AFS
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent    Not Present
ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung    Not Present
I would change the 3 red marked channels for a start. Probably the camera module still needs coding afterwards.
It seems that these are new channels in the FL.
Edited by aki78
Yep that seems to be the problem I'm having too
Dito :
 Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 084 CG    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H34 0236
   Serial number: 02001709503163
   Coding: 000000000000000000000000000000000000000000000000000000000000
   Shop #: WSC 73430 790 00000
   ASAM Dataset: EV_BCMMQB 017001
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7F077CDAE63159D2C53-802A
Too many of us enabling chargeable options :blink:
I think HBA is around £150 and cornering fogs around £300.
** Other chargable options and prices are available **
Edited by Auric Goldfinger
Doh - just read the thread properly and checked out that Ross-Tech Forum Thread - that would explain why my coding is all Zeros. So time to do an Adaption Log to see what settings I have before playing.
29 minutes ago, Gti Jazz Blue said:
Dito :
Oh joy - following the thread suggestion I sent an An Auto-Scan through for my May 2017 FL vRS and have just had this response back (with a thanks):
P.S. Your car has a few control modules (stuff like rear LED lighting modules) that are not able to communicate with your HEX+CAN interface so we would recommend trading it toward a HEX-NET using this page:
So it looks like it is upgrade time, the only thing that I don't like is the limited licence they introduced, I've help others out in the past and my cable has probably been through about 30 VINs, if I make the switch I'm going to have to be selfish and not assist anyone any more with a limit of 10 VINs - I'll need to keep them for myself / mates with Group Cars.
Alright bezzie Mate...........:hi:
VCDS 3 VIN HEX-V2 cable ordered from Gendan, WiFi HEX is very nice but just more to go wrong at extra cost so I went for the USB version.
Went for an outright purchase so I can keep the current cable for unlimited use on older group cars - like my My Mum's Citygo and Daughters Altea.
Looks like you'll having all the FL 230 and the 245 boys wanting to lick your boots................
Am planning to get the Hex-V2 cable  when I'm back from my work trip in a couple of weeks. I'd be interested in hearing how you get on.
Just got VCDS delivered this morning. Have done an autoscan and an admap of controller 09. What now...? Anyone able to shed light on next steps?
Changing the highlighted channels has enable the light assist option in the light settings, however "fault: light assist" appears on the MFD when the high beam is engaged, so there is still some coding to be done.
I’m sure someone posted an elaborate sequence of ignition on/off which clears the error. I forget who or in which thread though. It assumes you’ve coded correctly of course.
Have you reset the lights in HU after coding?
