Got my ABS sensor fixed. I had to do it twice because I got the wrong part first time.
Beware anyone attempting, make sure you find out the original part number and find a compatible one via autodoc or get it via Skoda.
  • Replies 5.5k
  • Views 725.1k
  • Well this was something else....   Not bad for 14 hours work.
  • rob_g_clarkson
    rob_g_clarkson
    Had the wheels refurb'd... and new centre caps and new tyres all round. Much much nicerer. Before and after
  • BriskodaJeff
    BriskodaJeff
    Chucked a bucket of water over it. Three hours later this is the result.         Happy with that
Bought myself a steel wheel.
Flat Bottom, Perforated, Heated, View Button, DSG Paddles.
3V0419091AF BGW
3V0419091AF BGW
Nice. I can highly
Recommend the paddle extensions listed on the Gandalf project by @JR RS
Today I spent half an hour faffing trying to swap and the tailgate lights on my Combi but for the life of me I couldn't get the supplied adapters from this listing to fit at either end. Not sure if it's wrong or just poor quality. But as is always the case, I got carried away ordering stuff from aliexpress. Todays order consists of; a fire extinguisher trunk storage bag (carrying one is something I really want to do, would love to figure out how to install oem style), a replacement brolly because the SKODA one that came with the car is broken, glued together and bent so it doesn't actually open... and I read the oem ones aren't particularly reliable. So we're trying an aliexpress special for now, but compact umbrellas can only get you so far, I also picked up an umbrella holder in case anyone ever gets me the fancy umbrella I put on my wishlist. Some wheel nut covers as I seem to be missing a few and it would be nice to put on a new set when she gets some nice shoes. The centre caps were also looking a bit naff, probably a long shot and not full of confidence but some centre cap covers too. I've had a dashcam and some trim removal tools for coming upto a year now but been too afraid to attempt the install especially given it's a two channel dashcam, but to potentially assist with that task I picked up some cloth tape and some cable rods and cable puller gubbins, lord knows, I'm terrified! And do you want to know what started off this whole order, I've been meaning to find a way to better organise the stuff I haul around in my boot as I've just been using two bags for life, so I got some magic tape and some mesh organizers with netting to hopefully just secure things out of the way. And naturally when you start doing this you see something like add two items and get £x off so we also picked up something called a car wiper repairer tool? and a washer fluid funnel type lid.
So, in summary, today I did nothing to my Skoda...
wow you really gor carried away in a junk shopping expedition! 😁
I am really interesting to hear how the "wiper blade repair tool" works!
I've done the fire extinghuisher thing, see towards the bottom of this page:
Sounds very much like my aliexpress shopping technique!
With those lights you have to open up the hole in the plastic trim slightly for them to fit. I just used a Stanley knife and it only takes maybe 2-3mm to be removed one end of the slot for them to clip in. The left side seems to have quite a lot of wiring behind the hole so just be mindful of that when wielding the knife!
For dashcam wiring, the front one you can just tuck wiring under the front edge of roof lining then down A pillar to the end of the dash. A pillar trim pulls off with two strong clips towards the centre of the windscreen from the top of the pillar then pulls up vertically out of the dash. The end panel of the dash prys open easily. Just make sure your wiring runs with the OEM loom and doesn’t cross in front of the airbag. For rear camera it’s a bit more tricky but most of the way you can just release plastic trim from the door seals and tuck under the trim. I would run low level past the doors, trickiest bit is past the pillar. Then tuck up the side of the leather trim by the rear bench. In the trunk the top edge plastic removes with a few Torx bolts hidden under hooks. Getting cable through tailgate to mount on the glass is really tricky. But I have seen on here somewhere that someone made a small bracket that tucks under the headliner so the camera is mounted to the back edge of the ceiling rather than on the glass of the tailgate which saves running the wires though the tailgate.
If you don’t have one already I can also highly recommend the Ali express plug and play reversing cameras. Cable route is pretty much the same as where you would run them for rear dashcam so could run them in at the same time! I’ve got links to all the AliExpress treats I’ve bought in my project thread. https://www.briskoda.net/forums/topic/537947-superb-mk3-estate-190ps-tdi-dsg-my2015-se-l-executive-moon-white/
Well today I removed the up shift paddle extension in quite a dramatic fashion.
It would appear that the windscreen wiper stalk when pulled to wash the windows is closer to the wheel that the top of the paddle extension. So if you wash the windows during a right turn, the paddle extension hooks behind the stalk and you can’t turn left or stop washing the windscreen! Luckily it was down a relatively wide and quiet country lane. And the 3M tape gave way just at the moment I had realised what had happened. Unfortunately the wife was in the car so I got somewhat of an ear bashing and a few “I told you so” about buying cheap parts from AliExpress!
Safe to say the other extension will be removed in due course and I shall return to OEM paddles only!
Today I gave the upgraded LED lights for the trunk a go again after using way more force than I thought was reasonable to connect the adapter to the LED unit. However I didn't feel quite as confident in doing the same with my wiring harness, so it's in 'good enough' and then a whole load of force to get it into the hole and it's in. Significantly brighter! Lights up the whole of the inside of the boot, and if it's not aimed good enough, just drop the hatch down a bit. However went to replace the glovebox light (just that and the torch left now I think) and learned it's a different unit, so another aliexpress order placed and some little emblems to replace the missing one on my key to get it over the free shipping threshold!
I shall take note of this 😂
Yeah! I noticed the top of the paddle would kiss the stalk sometimes but didn’t expect quite such a situation! I loved how they looked and if I could confidently get ones slightly shorter then I probably would. But I definitely don’t want to repeat that occurrence!
Changed front discs (ate) and pads (ate ceramic) on my 2016 with just over 50k miles, not low but fed up of cleaning brake dust
Outside disc wasn’t too bad
But the inner…
The inner pad has a big indentation which explains why all of the disc wasn’t used, looks worse with actual eyes
Both sides very similar so glad I’ve got shot of them
Just need to bed in nicely for the next 130miles or so
Edited by Danoid
This is a sign of not very good braking ... did you use the opportunity to check the condition and eventually grease the caliper pins? Perhaps they were not really free to run and then not allowing the pad to fully contact the disc?
Are these pins the ones that required special grease and not the usual
Copper grease? I’m planning on changing my front discs and pads shortly so just gathering the relevant equipment together.
I did check them and moved in and out nicely and also spun the slider screw and all good, I guess just typical rubbish OE Skoda discs, my rears a few years ago were terrible like many others but I didn’t personally change the rears
Edited by Danoid
Definitely not copper grease as it’s got an outer rubber boot, just brake silicone grease.
Think your car is around 2016? So if it’s like mine it should be good but literally your mileage may vary
Edited by Danoid
Mines 130k miles! Definitely needs new brakes. But have bought the proper high temp ate grease so I can check the pistons and pins.
One thing you may struggle with like I did is torquing the caliper bracket it’s 200nm, eventually I gave up, well my body did!
Depends how you’re doing it though, if it was like me just jacking it up you might struggle, if it’s on a 4 post lifter you’ll be fine.
No idea what it’s torqued to but it’s going to be very close just not 200nm
Yes i will be on the floor on jack stands. Worst case I will do it up as much as I can and then run to a friends garage with 4 post and torque them up there.
If the slider pins were fine, and I guess you also check the piston did not have a seal damaged, which would make it not come out properly ... guess all steps were covered.
I would watch it again in a couple k miles, to see how the new pads are "marking" the brake disc.
Quick wash today so took the opportunity for some updated photos in the sunshine. More pics in the main picture thread.
i haven't washed Gandalf for almost 3 months now!! 😢
thank goodness i have color that hides the dirt well.
White isn’t too bad so long as it’s not been too dusty. The worst is when it’s dusty and a bit wet and you get streaks above from windows from the airflow over the car.
Turns out magnetic brown isn't quite as good.
A house down the street is getting a load of building work done and they managed to cover all the cars on the road with a load of dust.
Buys 'magnetic' brown. Complains when things are attracted to it 😄
Ditto but mines Black so it shows everything. We had two rounds of Sahara sand in the last few weeks. All but gone now after some rain so just road grime & other debris to sort. After washing & paint correction in the next few days I'm going to attempt some Graphene protection. Failing that I might treat the old girl to a paid detail clean & ceramic coating to make keeping her clean at home easier.
