3 hours ago, JR RS said:
That looks very different to what is OEM for the liftback/sedan.
Nonetheless, good luck with the project.
This is how they look.....
Yeah they’re the brackets I got that didn’t fit!
It’s not claiming to be an OEM copy. It’s very much an aftermarket universal kit.
But I bought OEM brackets in the hope of using them as a mounting point for the aftermarket sensors so I could drill into the plastic of the bracket rather than the metal of the car.
Managed to drill out the bracket from the kit to mount on one of the studs on the car so no drilling of car required.
  • Replies 5.6k
  • Views 750.6k
  • Well this was something else....   Not bad for 14 hours work.
  • rob_g_clarkson
    rob_g_clarkson
    Had the wheels refurb'd... and new centre caps and new tyres all round. Much much nicerer. Before and after
  • BriskodaJeff
    BriskodaJeff
    Chucked a bucket of water over it. Three hours later this is the result.         Happy with that
Superb did a great job being loaded up for camping.
However I am thinking the rear springs and shocks could do with a refresh as it was looking very low whilst loaded up.
When loaded with 3 kids and luggages for a whole week in the boot, my ex Superb Estate Mk3 rear axle also lowered by 1 to 1.5´´. DCC doesn’t change this…
That was no passengers - only a full boot and roofbox.
Got the blind spot project to 95% complete this afternoon. All wires run in and loomed up to protect them.
Boot trim came out to run cables and all power and indicator lights connected up and all working well.
Not the most elegant finish just yet but this is proof of concept stage.
Final bits to finish this bit is to tap in to the rear light feeds so the BSD indicators flash at you if you are indicating whilst something is in your blind spot. Just waiting on some posi taps to come for the connection points.
Then if I’m happy with how it operates , next step is some experiments with the multimeter to check how the standard LEDs operate and then see if they will run the OEM BSD indicator LEDs. If they do then wires will be run in to the doors and OEM LEDs installed in the mirror housings so that it looks standard.
So I've had the car four weeks now. Replaced the leather sides of the DSG knob as they were worn with some Ali Express specials. Sorry no photos but they fitted fine.
Also replaced the door puddle lights with some LED units, bit chavy but hey-ho. Had to take the passenger door card off as someone had previously been there before and the cable was way too short. Sorted now though.
I have these and really like them. Be warned. AliExpress is an addictive drug!
20 hours ago, jeffl said:
Außerdem wurden die Pfützenlichter an den Türen durch einige LED-Einheiten ersetzt, etwas protzig, aber hey-ho.
Unfortunately, they were a bit twisted back then, but that has since been corrected. But this is also very nice. 🤩
Final connections made on the aftermarket blind spot detection kit this evening. All working well as intended. Next step is to experiment with OEM LEDs to see if I can make them work.
Nice, do these replace the standard lights??? do you have a link for them please
Yes, they were replaced one-for-one.
They aren't available anymore. Back then, there was a group buy in Germany for this type of logo.
@Lutz_91 damn … I’m always late to the party … I’d does look sweet
@Binx1310 yep I’ve seen the stick on ones but would prefer to have subtle changes that could be “factory options “ so sometime I may get round to buying both types and seeing if I can cobble the L&K lens onto the regular puddle lights
This evenings task was to get out the cardboard spray booth again. This time painting parking sensors for the front sensor retrofit project.
I used the punch for the bumper to cut holes in a small cardboard box and taped them in place as an easier way of masking up the sensors.
The loom has also arrived but is missing the 18 pin plug and is for LHD so some wires also need extending.
Don't, just ordered a reversing camera 😆
Bit moist today, but changed the PCV valve as the original one had a blow on it. Whilst I was there and had two coil packs out I figured I may as well replace them all as they're the original ones from 2018 and the plugs at the same time as I think they were last done 30-40k ago.
Aftermarket coil packs as they were cheaper than OEM and being red they'll easily add 10hp each 😂
  • Sponsor
You will keep the original coilpacks as spares, right?
Seems wrong to throw away functional items.
For a while, just in case any of the new ones decide to fail.
12 volt battery replaced today. Decided to go for an AGM over the existing FLB battery as it was only a couple of quid more expensive. Recoded with new technology type and increased Ah.
Stop start now works which is nice.
Edited by jeffl
Whilst I wait for the blind spot LEDs to be flown in from china, I started on the front parking sensor retrofit today.
I’ll write it up in more detail with parts etc once it’s all in and working. but once again it’s a bumper off job!
Holes cut and sensors all installed.
They aren’t quite sitting flush but the mount brackets are a different part number to the correct Skoda ones. But they don’t look too bad once all back together though!
Next came removing air box, battery and battery tray to try to access the main bulkhead grommet from the engine side. Then glovebox and fuse box to get at it from car side.
It’s impossible. I could just about get one finger to it and the current bundle of wires are so tight there’s no way I’m getting anything more through there.
Found the grommet for where the clutch would be right near the PDC controller so the plan is to go through that. But as it’s right behind the hot side of the engine I’ve ordered some heat shield conduit for the cables to run through as they cross the top of the bulkhead just in case.
So for now it’s all buttoned back up, and as I had some spare time I also installed the new button by the gearstick and the beeper that are required for 8k PDC, including pinning them into the plugs ready for the change over of the PDC controller.
Edited by Binx1310
I Love my LHD Car
4 minutes ago, Cairus said:
I Love my LHD Car
Do you not have the fuse box crammed up above the pedals? Have you ever got cables through the main grommet? Are there any others to go through other than the clutch one?
Es gibt unter der Haupt Durchführung noch eine mit der Gummi Tülle sogar welche sogar verschlossen ist.
Sicherungskasten ist bei mir Höhe BCM aber davor. Hölle was nachpinnen.
There's another one under the main cable gland, this one even has a rubber grommet and it's sealed.
My fuse box is at the level of the BCM, but in front of it. What a pain to repin!
I suppose that’s the clutch hole for lhd. I’ll have a look and see if I have it too as I’d rather go behind the dash than through engine bay
Edit: I can feel it through a gap in the carpet but engine bay side would have to take battery etc out again and I’m not sure I can be bothered!
Edited by Binx1310
