Coding more features
Hi all. Does anyone have codes in order to add new features through obd? I don't have obd11 and not keen on buying it :D
OBD2 functionality is limited to reading standard drivetrain error codes i.e. engine and gearbox. It can't do anything beyond that. If you want to do any coding or adaptation on any module in the car you will need a diagnostic tool that can support VAG diagnostic protocols.
@chimaera I think cockatoo mentioned obd eleven which gives you more access than regular obd 2 scanner dongle. It has long coding etc. @Cockatoo where are you? I do have obd 11 and more than happy to let you use it.
