Amundsen MIB2 Firmware Update
Please could I have a link for software update? I have a 2016 Octavia :)
  • Replies 4.7k
  • Views 899k
I can send you a link to 0253 via PM in a moment.
On 04/12/2022 at 20:13, varooom said:
Yes, 0369 is available.
Can PM you a link
Link does not work 😔
They only live for 24hrs 😉
Allow me to send a refreshed one now...
Thanks, downloaded yesterday and installed it today during my drive home.
BUT... I've lost Smartlink? It is no longer unlocked.. ☹️
Anyone have experienced this?
Usually you don't loose the activation codes, but it can occur.
It also happens when it's been unlocked with a tool, and then new firmware flashed.
Fixing will depend on how the code was originally enabled.  If from factory, then you will need online connection so factory can re-input the code needed.  If someone used a tool, then you will have to pay Skoda, or hack unit to insert codes needed.
Thanks for the heads-up.
It was indeed unlocked by tool.
Guess I'll have to contact the "unlocker" again then.
Lesson learned 😉
Lesson learned 😉
If you have developer mode still enabled, then odds are you can fix yourself.
Test by holding down your setup/menu key to enter engineering menu, then hold down button again for about 10 seconds and you may see developer menu.
If not you can enable with VCDS for example.
Hi, I have a 2017 Superb, can you guys PM me a link to any software updates?
Can I do that via USB as I do not have a card, both slots are empty.
/cdn-cgi/mirage/782220f56ac0820981fbf9e56bd8af0cd22904a8750d34f8a52256b01f18ace3/1280/https://www.briskoda.net/forums/uploads/monthly_2022_12/IMG_20221213_123203.thumb.jpg.8c60748be95ef724f8c6459483139efd.jpg
You need to find the value called Software Train.
Hold down the Menu/Setup button for about 10 seconds to enter engineering menu.
Thanks!!! I think I got it.
Also, my Smartlink doesn't "pop", the phone just charges when I plug it in, Android Auto doesn't start, tried different cables on two Xiaomi and on Samsung phone.
Thanks guys
Thanks guys
[common]
release = "MHI2_ER_SKG11_K3343"
MUVersion = "1433"
{ SNIP }
SupportedTrains = "MHI2_ER_SKG11_P2104*,MHI2_ER_SKG11_S2104*,MHI2_ER_SKG11_K2129*,MHI2_ER_SKG11_S2129*,MHI2_ER_SKG11_P3260*,MHI2_ER_SKG11_P3304*,MHI2_ER_SKG11_P3325*,MHI2_ER_SKG11_K3330*,MHI2_ER_SKG11_K3333*,MHI2_ER_SKG11_K3343*"
I can send you a private message now with this correct update, at the top is new values for Software Train and MUVersion, bottom is SupportedTrains, of which yours is.
I ask to see the value, so that it shows you the correct update location also.
[common]
MUVersion = "1433"
{ SNIP }
That would be awesome, thanks a lot!
Just been sent, I may need you to reply with your Country if it does not download.
Best of luck.
p.s. the Android Auto might need a dealer/independant garage to enter an activation code to enable this, post a picture of message you get on the screen to show if possible (translate if needed please)
I'll take a closer look over the weekend.
If developer menu is active, what needs to be done?
We will cross that bridge once you find answer.
Device part number: 5Q0035874C
Hardware: H41
Software: 0456.
Can someone PM the updated link plz.
5 minutes ago, automass said:
Hardware: H41
Software: 0456.
If you can verify your Software Train then I can send it along happily.
Scroll up a few posts for a picture.
Got it. MST2_EU_SK_ZR_P0456T
Edited by automass
You will have PM in 3 mins or so.
Plz PM me the latest version 🙂 Thank you in advance!
Hi guys i found this page and i see there is a "king" helping us guy's.
I live in Sweden and have a Skoda Kodiaq and need the latest update if you can provide it for me. The dealership are ignoring me, 🙄
We have a few King's helping here.
Can you get into your engineering menu (press your Menu/Setup key for 10 seconds) and look for Software Train.
Odds are I know what you have, but it also shows you where to update.
