Amundsen MIB2 Firmware Update
Hi, looking for update for my infotainment please
  • Replies 4.6k
  • Views 774k
Hello, i am still on 478 and waiting for a long time for a successor of 480 to skip 480. But currently my unit hangs sometime and I want to try 480. Please do me a favor and send me a link. Thanks in advance.
PS: Once i fixed a "problem" with my unit by replacing the iPhone cable 🙂. I got random disconnects. So if someone has problems try easier things first.
I wonder if there will ever be never than 0480 in this sw train. It has been quite a while since the last release, maybe a year already..? :)
@Jochen You have PM
@DanielMikel Still 0480, nothing new seen
Hello,
Not updated Skoda firmware before so please let me know if further info is required, but I would like to know if there is a more up-to-date firmware version available for my unit, and if so would anyone be able to help me out with a copy, please?
19 hours ago, varooom said:
0369 is current version for your Software Train
I know, but the latest was there to download at mibsolution.one was 0367.
Do you know where I can find 0369?
Yes, me or Pab567 via PM.
I will send you this now.
@varooom I was not able to update based on the instructions you provided. Can you help me out?
Hi, I was wondering if any update is available.
Part Number 5Q0035874C
Hardware H41
Software 0468
Shield 2016-44 (build309)
Yes send me images of what you see on your screen, and also if you can, what contents your SD Card contain (picture)
You can do this by Private Message.
Hardware H41
Software 0468
Yes I can send you 0480 version
I would kindly ask if possible for newer update, and question is possible to enable smartlink without going to dealer.
5Q0035840A
H24
0245
H25.14.78_STD2Plus_EU
MST2_EU_SK_ZR_P0245T
Thank you!!!
Hi Everyone,
Is there any update for my device? :
MST2_EU_SK_ZR_P0359T
ref 5Q0035864B
SW version : H28.28.133_STD2Nav_EU
Thanks !
1 hour ago, varooom said:
@Djadjo78 @katanasan0 Check your PM's
A big thank Varooom.
4 hours ago, Djadjo78 said:
5Q0035840A
H24
0245
Thank you!!!
enable smartlink without going to dealer interesting me also. If someone have a solution..... thank you !!!
Thanks varooom! update flawless 😎
Also @Djadjo78 same message...
Yes you can activate for "free" but you need to have VCDS or similar tool to enable "Developer" mode on radio.
If you have access to these tools, I can talk you through process by PM.
I can borrow the vcds tool from a friend. If the manipulation is not too complicated I can try the process if you can explain to me
I shall PM some instructions to assist.
Thanks Varooom 🙂
I sent a PM, no response. I can't get the link to work, tried several browsers. Anybody else had this issue before?
Hey all, I'm having issues with Bluetooth dropout on my Octavia 2017, could anyone send me a link to newest software version please? Current version below. Cheers.
I will send you 0480 version
So I finally got the update to work, now I lost Smartlink/Apple CarPlay. Any advise?
Yes reach out by private message
