Amundsen MIB2 Firmware Update
22 hours ago, pab567 said:
All check your PMs
@pab567 With regards to the file/version you sent me, are you able to say when it was produced/released? Also, is it possible to ascertain what has been changed? Superficially at least, there appears to be only minor cosmetic changes, but I appreciate the update will do a lot more than this.
  • Replies 4.7k
  • Views 927.5k
My Skoda Karoq 2018 has SmarkLink problems and others with similar issue suggested that the software update fixed this for them.
Currently I have this installed:
Installed SW train version: MST2_EU_SK_ZR_P0472T
Installed SW MU version: 0472
Part number: 5Q0035840C
Software version: H29.319.51_STD2Plus_EU
Based on the MIB Data I need: MST2_EU_SK_ZR_P0480T
The mibsolution website is down for me.
@pab567 I see you are the expert here :). I was wondering if you could send me the direct download link. Your help is much appreciated.
Hello,
i just baught a Skoda Kodiaq from 2020
and i was wondering if there is a update for this infotainment system available
i managed to update the maps for the navigation myself today
Part number 565035874
hardware: H41
software: 0478
nav DB 5l0051236DS
2310
ECE AS 2025
Shield: Shield 2016-44 (build 309)
or is the over the air update possible on the model?
i could not find a clear answer for this
Edited by Hightower200
pab567 verykindly sent me the link to the firmware for our 2018 Karoq. We have poor DAB reception and smartlink/carplay connection issues occasionally. I am hoping that the firmware update will help.
I am assuming that having a stock OEM radio with nothign od done to it I am not risking a loss of functionality or anything by running the firmware update.
@pab567 is there a newer vision that 0480 für a MST2_EU_SK_ZR available? I do have issues with my new iPhone/Carplay and bluetooth in general. Thanks in advance.
No - at least I don;t know anou any newer than 0480.
On 26/04/2025 at 10:17, lekamich said:
Thanks @pab567 , everything works perfectly. Just Radio logo disappeared. Nothing important for me ...
This is because logos DB has been updated as well, just re-save stations and logos will appear again
@Hightower200 MIB2 units don't support OTA update.
@Oli pls post model number and current SW version of your unit.
All check your PMs.
Hello @pab567 I contact you in mp for my skoda fabia 2017, have you new firmware ? Can you give me the tutorial for installation ? Thanks
Part number and current SW version?
I don;t have change logs
PM
1. format SD (best max 32GB) under FAT32
2. unpack to root (metainfo2.txt and all the folders must be placed directly on SD, not in any folder)
3. insert SD card into the slot
4. enter Service Menu (long press MENU button)
Part # 565035020A
SW version: the file you sent me i.e. MHI2_ER_SKG13_P4526 (1440)
All check your PMs.
I mentioned it above buddy, but I know you get load of messages on here! 😆
Edited by Oli
1 hour ago, netman82 said:
Part # 565035020A
This is the most recent firmware I have.
@Oli I can't send you PM, drop me mail to [removed]
Edited by Dean
Hi there!
I'd love some advice on upgrading my firmware please... I am currently running MST2_EU_SK_ZR_PO253ST. My bluetooth connection drops out regularly, or the audio goes garbled, and it's very annoying.
A bit of internetting has me believing I could upgrade to MST2_EU_SK_ZR_P0480T. I see that a I'm far from alone now having signed up here!
I'd love some advice on if this would be a helpful upgrade, and if so where I might get it please?
Well that needs a dust.... :)
Very grateful for any assistance, thank you kindly in advance.
@leeroykeys MIB STD2 TOOLBOX is your friend, google for it :)
@Oli I can't send you PM, drop me mail to pab567(at)wp.pl
Hi im looking for the mst2_eu_sk_zr_p0253t uppdate if any one have it on hand. The webpage where it was downloadable from has been down for a long time now 🙁
Best regards// Sebastian
Hi everyone,
I would like to update my MIB firmware for My Skoda Fabia from 2018 because of inconsistent Android Auto connection via USB.
My current MIB version is MST2_EU_SK_ZR_P0468T and I would like to update it to version MST2_EU_SK_ZR_P0480T.
Is there anybody kind enough to share with me a link to download the corresponding file?
Many thanks!
@leeroykeys Hi. If you want to update to 0480, write to me.
Hi i have a Skoda superb 2016 mib-helper says the latest official uppdate for my car is 0453 and possible uppdate is MST2_EU_SK_ZR_P0480T
Do you know if 0480 will work on my car also? I cant pm you yet since i am new member.
Thank you buddy. Ran the update today and dusted off my VCDS setup and MicroCAN cable and could update the 5F module. No errors and all working.
Now to figure out how to get it to recognise the new map SD card.
@Reqit Hi. What software version do you have on your unit now?
@Reqit It supports version 0480, but without knowledge and necessary things you can't do it. The maximum you can update it to version 0253.
