Amundsen MIB2 Firmware Update
I urgently need help restoring my SKODA Amundsen MIB2.5 (Octavia III) after a failed firmware update.
I installed firmware MST2_EU_SK_ZR_P0480T.
Now I have a completely black screen, no button backlight, and no response at all.
Additional info: My phone can connect via Bluetooth. When I connect it with a cable, it automatically connects to the head unit, and Android Auto starts — I can listen to music.
Mittwoch,23,Juli,2025,00:05:59:00009
VCDS -- Windows-basierter VAG/VAS-Emulator läuft auf Windows 7 x64
VCDS Version: DRV 20.4.2.1
Datenstand: 20201124 DS317.0
www.Ross-Tech.de
Fahrzeug-Ident.-Nr.: xxxxxxxxxxxxxxxxxxxxxxx KFZ-Kennzeichen:
Adresse 5F: Informationselek. I Labeldatei: 3V0-035-MIB-STD2.clb
Steuergerät-Teilenummer: 5Q0 035 874 C HW: 5Q0 035 874 B
Bauteil und/oder Version: MU-S-ND-ER H30 0480
Codierung: 03731201FF00000051111204008802232F0301C401200102CE
Betriebsnummer: WSC 73430 790 00063
ASAM Datensatz: EV_MUStd4CTSAT 001022 (SK37)
ROD: EV_MUStd4CTSAT_VW37.rod
VCID: 3467A9D79F3B6626C6-8060
1 Fehler gefunden:
2562 - Navigationssystem
B126C F0 [009] - Navigationsdatenbank fehlerhaft
bestätigt - geprüft seit letzter Löschung
Umgebungsbedingungen:
Fehlerstatus: 00000001
Fehlerpriorität: 6
Fehlerhäufigkeit: 3
Verlernzähler: 198
Kilometerstand: 78340 km
Datum: 2025.07.23
Zeit: 08:58:38
Spannung Klemme 30: 12.2 V
Mittwoch,23,Juli,2025,00:07:32:00009
www.Ross-Tech.de
  • Replies 4.7k
  • Views 903.8k
Hi @pab567 im looking for firmware update for my VW Sharan 2017, the software details are on the pictures.
Thank you for your help !
Hi all, would anyone kindly help me with an update for this MIB3 in my Skoda Karoq. It misbehaves quite often and I realise it could be down to the out dated firmware as it has never been updated (2021 Karoq). Currently I have version 0302 on it.
Many thanks for any help.
Kind regards
Nath
No warrenty:
Send PM
Edited by Cairus
@pab567 Hi! I can't send you a private message yet.
I’ve bricked my Amundsen (MIB2 STD) head unit after flashing the MST2_EU_SK_ZR_P0480T firmware — now the screen stays black, although Bluetooth and Android Auto are still working.
I’m trying to downgrade to a stable firmware version using ODIS-E and VAS5054A.
Could you please share a working .frf file for one of the following versions?
MST2_EU_SK_ZR_P0471T
MST2_EU_SK_ZR_P0478T
My unit:
Part Number: 5Q0 035 874 C
HW: 5Q0 035 874 B
SW: MST2_EU_SK_ZR_P0480T
H30
Skoda Octavia A7 FL 2018
Any help would be greatly appreciated!
Thanks in advance.
Hi @Cairus I cannot send you PM so far. Thx for the link, but it wants som decryption key from me ... Can you help me with that ? Or have another source for the update ?
Thank you in advance.
@Nemain touch problem is hardware, not firmware - you should have digitizer replaced.
@BranciK I sent you download link to MST2_EU_VW_PQ_P0480T in PM.
@Doraty236 you have MY17 unit, you need firmware 03xx and probably have to go through emergency. I sent you download link to MST2_EU_SK_ZR_P0369T in PM.
Thank you for the link, but I specifically need the firmware in .frf format. I want to flash my Amundsen unit using ODIS-E and a VAS5054A. The file you provided is meant to be installed via SD card.
Unfortunately, I cannot use the SD card method because my display no longer works — it's completely black, and the physical buttons have also stopped responding.
This happened after I tried updating my Amundsen via SD card.
As I mentioned earlier, my phone connects via Bluetooth, and I can listen to music through Android Auto without any issues. However, I can only control the volume using the steering wheel buttons.
Is there any other way to install firmware on my Amundsen without needing the display?
Infotainment unit can't be falshed this way, sorry. Display will work in emergency mode.
Hi all, I'm new here and a new owner to Skoda Superb mk3, so everything is new for me and I'm curious about what's to come :) So I wanted to start with updating my infotainment system. After searching how to do it I've been navigated to this forum and especially You @pab567 :) Can you help me please updating my system?
I sent you link to MST2_EU_SK_ZR_P0369T i PM. Just a reminder:
1. format SD (best max 32GB) under FAT32
2. unpack to root (metainfo2.txt and all the folders must be placed directly on SD, not in any folder)
3. insert SD card into the slot
4. enter Service Menu (long press MENU button)
Thank you 😊
Please @pab567 could you help me out with Latest Firmware update? And up to date Maps update?
I’m hoping to activate android auto and apple CarPlay? Is the firmware update necessary before toolbox activation etc? Thanks, kind regards, Callum
@CallumRS
253T Firmware
MEGA
No image preview
MEGA
MEGA provides free cloud storage with convenient and powerful always-on privacy. Claim your free 20GB now
253T Firmware Patch FeC all, CID Off,
https://mega.nz/#P!AgFWp3BVsBBOrQgR6yh3ZhxJoM4hE40gKohXo8hUn8JJBr1LuH406sp-Xy8TdKI9LBmYtIxwBMB4Uhii6fUL1HD2dBl3i3YM8kOpADmMRwRp7yJgCSnMwOxpHv_lRcEVn0gFr_CTJ2A
Edited by Cairus
Maps:
https://infotainment-cdn.skoda-auto.com/base/maps/STD2_2510_EU_AS_202525.zip
14 minutes ago, Cairus said:
@CallumRS
253T Firmware
MEGA
No image preview
MEGA
thank you very much .
Password PM
sorry don't think I'm able to send PM yet.
Hello guys, I´m new to this forum, and looking for advice :)
I´m the happy owner of the Superb III (2017), and last week, my subscription to Care Connect - Remote Access expired. I´ve renewed it after 24 hours; however, after being renewed, MyŠkoda APP is unable to wake up the car and receive actual data (it was working flawlessly until the expiration of the subscription). The data are updated only after the vehicle is unlocked or driven. I´ve contacted the Škoda connect support, and they advised to get the infotainment software "repaired" (updated) at the dealer.
My current version of software is 468, and the latest version available is 480. I´ve already found the tutorial on how to perform the update and downloaded the firmware, but there were warnings that this firmware could permanently damage the display/touchscreen.
Could somebody validate this info, or is it only a rumour?
Thank you.
It can only damage your system if the update files are either corrupted or the updates borks mid-upgrade. In most cases, the system will revert out of the update. I've never heard of any system being physically damaged.
Hello, I have a Seat Leon infotainment with hardware H30, SW 0359, train MST2_EU_SE_ZR_P0359T.
Could someone please share the MST2_EU_SE_ZR_P0479T firmware package (.7z) with me?
Thank you!
You can Not Install 0479 direkt
@harsh249
If you want an update, I can do it. Write to me.
Edited by Joco776
16 minutes ago, Joco776 said:
@harsh249
I cannot message you as I am new to this forum website - is there any other way I can contact you?
The Last Firmware in Firmware Train 4 is 0480
https://mega.nz/#P!AgGWtzUFoIPQqD6Qv8A-2I2d5XjuwDaK12fCuicLu8RAR3mRnTKXituarno4wcOvrRpcAAy3FgW3K4mjmEnGP-kFyJ61Pm_FPJBIxqi3HuslJs8BK-cZgzCt6IkRG4Rzf_BZxqYXR30
