Amundsen MIB2 Firmware Update
  1. Enable developer mode in adaptation sof 5F unit with VCDS, OBD Eleven, ODIS, VCTool or any other tool.
  2. Install MIB STD2 Toolbox (be careful, you have firmware 02xx, there is some extra action you have to make, read toolbox manual for details).
  3. Patch swdownload from MIB STD2 Toolbox
  4. Modify metainfo2.txt file - change value of "RequiredVersion" rows to "0"
  5. Insert SD crad with 0480 firmware and modified metainfo2.txt
  6. Enter Service Mode - long press MENU button
  7. Select Manual SWDL
  8. Select all
  9. Deselect "Emergency" in both "cpu" and "main"
  10. Start uphgrade
  • Replies 4.7k
  • Views 881.8k
The firmware upgrade is also possible without Toolbox and developer menu.
As a note and addition, the left and right channels will be swapped in the 0480 update.
Just simply straight away? From 0253 version?
No,
5 step Update solution with the SD Card. But No ToolBox and No Diagnostic Tool you need
Here's the solution. As already mentioned, the audio signal is reversed left and right. This is due to the HW 02.
https://mega.nz/file/w6MhzRTB#HuI0JKhHFbcuP60AyPIux8qmBcZ7eyhHIzoTJsXO7uY
The zip file with password.
And as written
  8. Select all
  10. Start uphgrade
I need to pass 1-4 steps and do from 5th, with original 0480?
@Cairus
No, this has nothing to do with the instructions from my colleague. Only I can open this zip folder with the password via remote access. I copy the contents to the SD card as needed and then delete everything again.
Thanks, but I would like to do by myself 😉
Then good luck.
@asterixas I sent you link to zipped MST2_EU_SK_ZR_P0480T in PM, no password required to unzip.
Edited by pab567
2 hours ago, pab567 said:
@asterixasIch habe Ihnen per PM einen Link zur gezippten Datei MST2_EU_SK_ZR_P0480T geschickt; zum Entpacken ist kein Passwort erforderlich.
This wasn't about the image, though. It was about files used to make firmware jumps without Toolbox or developer mode.
Going from 02xx or 03xx to 04xx without patching the unit first is NOT possible.
I say, you dont need ToolBox and the Green Menü.
It seems you've reached your limit. I never said I wouldn't patch it. But it can be done differently.
Of course it can be done differently, you don't have to use MIB STD2 Toolbox (I don't use it at all) - but it MUST be patched to go from 02xx or 03xx to 04xx, and for most of people, who are not familiar with QNX and software reverse engineering, MIB STD2 Toolbox is a great solution.
I Dont use qnx
This solution is only SD Card Update's
Easy for everybody.
No ToolBox, No obd Tool, only SD Card
Edited by Cairus
8 hours ago, Cairus said:
I Dont use qnx
I suggest you two take this discussion offline, it doesn't help those less skilled than yourselves to read this debate.
Hello,
I just bought a 2018 Skoda Octavia L&K.
I checked the MIB2 software and it is version 468. From what I read on this topic, my model should have version 480 as the latest update.
The situation is this: Android Auto works since I bought the car. It disconnected twice, but it works. Apple CarPlay does not work (I tested with a friend’s iPhone and the screen shows that the function must be activated at a Skoda dealership) but this does not affect me because I do not use an iPhone. I mention this because, according to the forum, the Installed SW Train Version field is blank. It is possible that the previous owner hacked the unit and activated only Android Auto.
My question is.. If I update the system to version 480, will Android Auto still work?
Thank you in advance!
No
On 13/03/2022 at 16:09, cicad said:
Hi pab567,
could you please provide the latest software update available for my device?
Device Part Number: 5Q0035864C
Hardware: H41
Software: 0472
Media codec: 4101.0.0.0
Bluetooth version: C300
SmartLink: 4101.438.1.5
Radio database version: 1.9.4
USB surfstick version: 4101.438.1.4
In case that I need to delete any errors afterwards please let me know how to proceed.
Thanks.
Octavia MKIII
If is possible to provide me latest software update for
Device part number: 5Q0035864C
Hardware:H41
Software: 0480
Hello... Please...Have a new SF and HW update for my skoda?Thank you...
No New Update
Hi!
Any new sw or hw updates available for me?
Hi there,
can anybody tell me, if it's possible to downgrade the firmware on an Amundsen Mib2?
If have done an upgrade and replaced the touchscreen. Everything works fine except
the clock on the display seems to be stuck on 0:00 and the DAB radio reception is worse than before the update.
Actual the MST2_EU_SK_PQ_P0359T is installed
I want to go back to MST2_EU_SK_PQ_P353T
Can anybody please sent me the firmware.
Thanks Nemain
You use the New Firmware without Bug?
