Amundsen MIB2 Firmware Update
Yes, I think so
  • Replies 4.6k
  • Views 811k
I have recently done retrofit from MIB1 to MIB2 but I have there pretty old SW installed..
Can I update it to something newer?
Right away I want to ask if I do update with SD card is there a chance that it will broke something like component protection or smartlink activation?
Hello folks
Happy to be here
Just new , hopped recently onto this MIB crazy journey D
Please tell me what's the best i can get from my MIB2 Amundsen
Partnumber 5L0035680E
HW Part H32
SW Train - (i guess it's) MST2_EU_SK_PQ_P0363T
I have three questions
What's the latest i can install?
Can i install 480T somehow, is there such a guide to do safely so?
I've seen MIB2 PQ running 480T, that's why i'm asking
And lastly - what kind of rear view camera does this MIB2 support?
My car is Octavia 2 Facelift, so i'd like a rear view camera in the trunk handle, if possible
Thank you & really grateful to be here
I have a 2019 Octavia vRS.
It is currently running the software version below.
Is an update available?
Thanks.
Yes 0480T
Hey
I Need the FW for my Golf GTD with VW Discover Pro.
MHIG EU VW K0344 1 MU0200
Can you help me?
Edited by carstatt24
can anyone advice please if any updates are available.
hmi version: H28.28.210_HIGH2_EU
GUIDE MODEL 28.28.82
SOFTWARE BASE: H28.28.210-201809271437.
THANKS
THANKS
@pab567 CAN YOU HELP PLEASE
On 24/04/2022 at 20:27, StariBluzer said:
Hello Pab,
please could you check if there is update for my 2019 Superb Amundsen Firmware?
THank you very much!!!
Hello Pab, please is there an update to this firmware version?
BR
Firmware 0480T
G11 latest 1447 what i have @caraushv
Edited by Cairus
@Cairus could you please help sharing it . Thanks
Hello,
I recently bought a 2017. Octavia MK3, and after reading a lot of threads on this forum I decided to upgrade an Amundsen firmware. Original FW was MST2_EU_SK_ZR_P0363T, which I succesfully upgraded to MST2_EU_SK_ZR_P0369T and everything was fine.
According to this thread and mib-helper page, it is possible to upgrade it to MST2_EU_SK_ZR_P0480T, so why not?
I did it from toolbox, SWDL menu and the upgrade started fine. But after third reboot the unit bricked and screen doesn't power up any more. I tried to hold power and menu buttons for a longer time than 20 sec. but nothing.
VCDS can see the unit, but the screen doesn't show up.
Any help will be very appreciated, because I'm running out of ideas....
7 minutes ago, matekhr said:
Hello,
Well important question did you modified metainfo and changed the CPUID? If not that is the reason why it is bricked.
You also update emergency I assume you did not uncheck this part of update?
No, I didn't. Can you give me some more info?
Is there a way to restore the unit?
Because you also updated emergency you are now not able to do emergency restore to older firmware. Now the only option to restore the unit is to find someone who can directly connect to the PCB to memory chip and reflash it.
I'm not sure, but you are probably right.
Is there any "manual" and needed files around, I have some soldering and programming skills....
Do not have experience with this. I never brick any unit because I know what not to do 😃 and I install lot of them to 480
Thanks for your help. This time I was careless, but I'll do my best to recover the unit.
So, my question is still open, if anyone can help, it will be very appreciated.
BTW, can you give me the needed info to 480 upgrade (from3xx)?
You need a modified meta file. Then run Swdl manually. First, select everything and manually deselect Emergency Main and CPU. Perform the update. That should all work, then reinstall the full firmware. Emergency Main and CPU should then also run. You can also perform a firmware Train JUMP upgrade without Toolbox.
Now you need QNX...
I developed my own contact method,see Picture With black frame.
If the emergency menu appears, you can still try using a pin clamp and PuTTY.
Edited by Cairus
Thank you Cairus, your message is a game changer for me )
But I still have some doubts:
1. Can I use QNX virtual machine?
Even in that case I have to study how to flash the unit, because my QNX knowledge is basic level only.
2.Regarding modified metafile, is it only needed to set all "RequiredVersion" lines to zero (when it has a different value) or something more?
It's probably explained on the forum, but there are really many pages to read.
Beitrag im Thema '[HOW TO DO] (pdf) VM + QNX + Toolbox + eMMC Installation - MST2 Technisat/Preh Unit - update'
https://www.digital-eliteboard.com/threads/how-to-do-pdf-vm-qnx-toolbox-emmc-installation-mst2-technisat-preh-unit-update.531049/post-4465646
Edited by Cairus
@Cairus Can you share a working eMMC image of MST2_EU_SK_ZR_P0369T or MST2_EU_SK_ZR_P0480T please?
I tried byte17/skin0 and Emeargency update, but nothing...
I Upload To my Server
Hello everybody !
No problem firmware MST2_EU_SK_ZR_P0480T (octavia 3 -2019) downloaded from private server here.
Still have SD card
Any update for it ?
device: 5Q0035840C
HW: H41
SW: 0480
I went to official service and now cannot watch videos or mirroring screen like before 😵‍💫
Anyway very grateful after 4 years using it with cable and no issues.
Not using any dongle wireless for android auto.Cable rocks !
Best regards
Manuel
