Turbo Swap Choices for EA211 1.2 TSI
After much difficulty trying to research turbo upgrade options for other members, I decided it's probably worth making some sort of list of turbos that can be bolted straight onto the 1.2 TSI.
See the second post for a quick simple installation guide and other suggestions/advice.
Which Turbo do I want?
For some reason, despite them all being pretty much the same power, and all being used in what's effectively the same chassis, there's about 25 different engine codes and just as many different turbo models. It's quite a mess, so i've tried to organise them here.
It's also just been made aparent that there's some variants (seems like any ACT ones) which use a different style of wastegate actuator, they're also made by a different company and have different turbine designs, they should all provide the same final power, but might have slightly differing boost characteristics.
1.2 TSI Turbos - Standard - The original turbo on your car should be one of these, unless your turbo died, there's no point buying these.
04E 145 721 L
04E 145 713 B
04E 145 713 Q
04E 145 704 T
04E 145 704 L
04E 145 704 N
04E 145 703 Q
1.4 TSI Small Turbos - Avoid - Same size as the 1.2 TSI but with different shaped exhaust housing, you won't see any gains with these.
04E 145 721 E
04E 145 721 R
04E 145 713 N
04E 145 704 F
04E 145 704 R
1.4 TSI Large Turbos - Avoid - Has an additional sensor on the exhaust housing, stay away unless someone confirms it's removable and fits.
04E 145 721 C
04E 145 721 G
1.4 TSI Large Turbos - Avoid - These have a different type of Wastegate actuator, stay away unless someone confirms it works.
04E 145 722 G
04E 145 721 P
04E 145 715 B
04E 145 715 D
04E 145 715 E
04E 145 715 F
1.4 TSI Large Turbos - Best Choice - Matching Wastegate and confirmed working by myself and others.
04E 145 721 B
04E 145 721 F
04E 145 704 C
04E 145 704 P
Purchasing Options
New turbos can be bolted straight on the day it arrives in the post, though they're incredibly expensive and will set you back potentially by more than £600.
Remanufactured/Refurbished turbos are a cheaper alternative for an equally safe purchase, and are also good to bolt on the day it arrives, these go for usually around the £350 mark, sometimes some pop up a bit lower though.
Used turbos are by far the cheapest option, but it's advisable to have it rebuilt. A used turbo will set you back around £100-150, having it rebuilt will cost you around the £100-150 mark, total cost roughly £250.
When purchasing a Used Turbo
If possible, collect it in person before commiting to the purchase so you can inspect it to ensure it is the correct part and that there is no damage. A damaged turbo can still be repaired, but a repair will set you back closer to £250-300.
If there's any damage to either intake compressor or exhaust turbine, or if it does not rotate freely (be very gentle when attempting to spin it, it's very fragile), it's not worth your time or money.
Use brake or carb-cleaner to clean out any oily residue (try not to get it in the oil channels, as you do want oil in those, but cleaning the coolant passageways is fine). But again, do not poke anything in the blades, they are easily damaged!
I'd recommend to check a few turbo refurb companies for rebuild prices, then checking how much you can get hold of a turbo for, both used and refurbed, and proceed from there before actually purchasing anything.
Disclaimer should you choose to install a used turbo without having it rebuilt or at least inspected by a professional:
I advise against doing so, and I shall NOT take any responsibility for any damages incurred by YOUR actions.
Turbos spin sometimes upwards of 250,000 RPM, the slightest of imbalance from any kind of damage, can result in catastrophic failure!
This could potentially send metal shards through your engine, completely ruining your engine too! Just get it rebuilt already!!!
Edited by FabiaGonzales
  • Replies 394
  • Views 128.7k
  • FabiaGonzales
    FabiaGonzales
    What kind of gains can i get? The lower power 1.4 TSI (122/125PS models) use the same size turbo as the 1.2 TSI, only the 140/150PS variants use a larger turbo. Given that with no other mods
  • Monkey_Dan
    Monkey_Dan
    Little update with my build, I folded and ordered an rtmg turbo and carbon intake. I fitted the turbo last week and tomorrow I'm taking a trip back to my tuner to get a cuatom map for it. Was at 183bh
  • Everything working perfect, your post on how to do it helped massive amounts. Had a little coolant leak after I fitted it but soon fixed that. Topped it up with water going to get some coolant in the
04E 145 722 G
04E 145 721 P
04E 145 715 B
04E 145 715 D
04E 145 715 E
04E 145 715 F
04E 145 722 G this P/N Fits perfectly, thanks again for your help 👍🏻
Edited by R44YVY
Wastegate working all good?
Everything working perfect, your post on how to do it helped massive amounts. Had a little coolant leak after I fitted it but soon fixed that. Topped it up with water going to get some coolant in the morning and should be good to go but can feel the difference already now just waiting for JBS looking like July/august time before the map can be fitted in.
thanks again, your help on this forum is class.
Could this be done without going under the car?
Also I've been looking for a turbo and so.e of the larger ones are listed for the lower output 1.4 which is very confusing
How much power would it have if my 1.2 is with revo and I put the 1.4 with downpipe and intake?
Yeah, have to check the individual part number rather than going off eBay listings and stuff. I'd always advise collecting in person because ive seen a few listings where the pictures are of something different to the part number they quote.
160 with no mods, so id guess like 170? but you'll ideally need it mapping again to take advantage of it, otherwise you won't gain much if anything
Well well well, look who's here 😁
I'm very interested after the mapping! Please keep us posted!
I certainly will, unfortunately i'm a bit strapped for cash at the moment, unexpected £800 household repair (oven exploded and damaged much of the kitchen including a TV - just glad it wasn't a gas oven!).
I'm interested to hear myself from anyone else too, then i'll know what to look forward to :D
Oh damn, thats a bummer. Glad you guys are ok.
Just keep us posted 😛
I currently have a 04E 145 715 F turbo, I haven't tried fitting it yet as I'm waiting to start my new modified insurance with Brentacre in July.  I'll let you know how it goes when I get round to it as I'll be doing a full service at the same time and I'll try to document the installation as much as possible.
I’ve had my mk3 1.2 tsi remapped to 135bhp with a Forge induction kit. I now want a bigger turbo, so will I have to have a new map.
To take full advantage of the bigger turbo you'd need a custom remap. Was your current map a custom job or a generic stage 1 map?
Yes to take advantage of it, i'd be wary about putting it on without mapping it though, stock 90/110 boost is that low it isn't a problem running the bigger turbo without mapping, but i don't know how itd handle when remapped to begin with.
Pretty sure it was a generic map
ADEdmundson will fit the turbo and custom tune it for you, they quoted me £400 for the tuning alone (i already fitted my turbo, but i'm not mapped or anything so it's all good), i'd send them a message (they're on Facebook) and see what they can offer you.
I'm having the turbo from the 1 4 fitted Monday and mapped Tuesday. I'm also having my DSG reprogrammed too. Can't wait!
I can't wait to hear your results!! 😁
So you fitted the larger turbo on your car but the ECU map is the stock one, the 90 HP version? And you drive the car everyday with no problems, no errors no limp mode or anything like this?
I'm asking because in my country (Romania) I found a new turbo (04E 145 721 B) for around 200 euros and I haven't decide it yet which upgrade path to follow.
I have a 2016 Fabia 1.2 TSi 90HP and I want the maximum power and torque I can get without other major changes to the car like stronger clutch or brakes, extra cooling, fuel injectors, induction kit etc. I know the turbo swap is considered a major change, but since I can do it with 200 euros plus 100 labor, and the turbo is brand new ....it's pretty tempting for me...
So if I want around 130 HP is better to remap with the current stock turbo or the remap with the larger turbo is a better choice? I assume that the smaller turbo will be pushed to the max for the same power that the larger turbo will obtain at half of its potential, so it will last longer before it brakes.
Do you think I can drive my car a few months with the larger turbo without remap? After a while when my budget will allow it,  I can make a custom map (400 euros)  especially for better boost at lower rpms.
What do you think!
What do you think!
I've had the larger turbo in for i think nearly 2 months now and still on stock 90bhp map. No limp mode, no problems, all been good.
The only thing you'll notice at first is you'll lose a bit of low down torque (turbo seems to come in closer to ~1800 rpm instead of ~1400 rpm) and there's a little more lag, but that's to be expected from a larger turbo
Can expect to see 170bhp from that turbo, the turbo is safely capable of 185-190bhp on the 1.4tsi engine, it can go further still given a bigger exhaust and intake too.
It's your choice, ~130bhp without turbo swap, or ~170bhp with turbo swap, no other changes are required. Torque doesn't increase much from just a remap, it just holds that torque to much higher rpms as the turbo can hold the boost longer. The stock clutch can take the torque fine as long as you don't go doing redline clutch dump lauches and hard shifts everywhere, but that's the same whether it's stock or mapped. Next time i have a clutch done, i'll probably put in a uprated clutch, but its not necessary.
Thank you very much for your fast reply.  I will probably start by remaping with stock turbo and if the turbo fails someday I will replace it with a larger one.
The main factor that led me to this decision is the low rpm lack of boost of the larger turbo. What I like the most to my 1.2 tsi engine is that it has enough torque from very low rmp and is so fun and easy to drive in the city. I don't. Want this to change.
One weird thing I saw these days during my search for info about the larger turbo is regarding the wastegate actuator; the rod doesn.t have any adjustments, is just one stiff piece of metal.
What were you referring when you said "Adaptation is advised but not necessarily required for the wastegate (I didn't do it on mine and it's been fine)." ?
You mean adaptation with vcds? But it seems no mechanical adjustment is possible for the wastegate actuator rod......
Adaptation is via VCDS, i didn't do it on mine and i've never had a problem.
The low down torque may improve once its mapped, but i cant say yet unfortunately, looking at 2 months from now before we'll find out.
There is still decent torque low down from the 1400rpm but it takes much longer for it to come in. I find 1800rpm is where it comes in more readily. Another thing i have noticed is i now get a nice slight induction noise when on boost between 2000-3000 rpm, its still there beyond that but the engine noise drowns that out a bit, i'll assume thatll get louder once it's mapped, and maybe a tad more still once i get a new intake hose made up :D
