Turbo Swap Choices for EA211 1.2 TSI
4 hours ago, Eladshaul said:
Hey , recently got this rtmg ea211 1.4tsi hybrid turbo for my fabia , it came without a wastegate actuator so i wanted to ask if i could attach the one from the stock turbo or should i get a new none oem one?
Nice! I saw you had the standard 1.4 turbo on your car before. I'd put that actuator on it. Be interested to see how you get on
  • Replies 394
  • Views 123.1k
  • FabiaGonzales
    FabiaGonzales
    What kind of gains can i get? The lower power 1.4 TSI (122/125PS models) use the same size turbo as the 1.2 TSI, only the 140/150PS variants use a larger turbo. Given that with no other mods
  • Monkey_Dan
    Monkey_Dan
    Little update with my build, I folded and ordered an rtmg turbo and carbon intake. I fitted the turbo last week and tomorrow I'm taking a trip back to my tuner to get a cuatom map for it. Was at 183bh
  • Everything working perfect, your post on how to do it helped massive amounts. Had a little coolant leak after I fitted it but soon fixed that. Topped it up with water going to get some coolant in the
Did anyone got any update?
I've started an Instagram page for my car to track my work. Nothing new turbo for me, hoping to get a turbo-back exhaust system with sports cat ASAP but working on other bits. Feel free to give it a follow, I'm no photographer though and my car is almost always dirty.
TurboFabNJ
https://instagram.com/turbofabnj?igshid=mxrgjn0s4xy6
TurboFabNJ
Thanks i'll take a shot!
Anyway, I've currently running Revo stage 1 on My 1.2 TSI (CJZC Engine) and I want to Swap 1.4 Turbocharger.
BTW @FabiaGonzalesYou did a really great work! 💪
Waiting for your updates guys
Are all the downpipes the same for a ea211 engine ? I only can find for 1.4 tsi ea211 ..
i want to have a 2.5 inch catless downpipe for my 1.2 golf .. i allready have the bigger 1.4 turbo and a armaspeed airintake on the way
can someone please help me ?
im in need for speed 😎
@FabiaGonzalesCheck the DIY at first page of the topic 😉
Doesnt look like its required
Sorry I wanted to tag @VAG-G7
Why reply if you dont wanna answer the question. A simple no or yes is more than enough
Too lazy to read the whole topic?
@ClauTSI thats not what your momma thinks. You should ask about me 👊🏾
You're cute
New downpipe is not required for the turbo swap but the stock exhaust does present as a limiting factor, especially the cat.
I got fed up of trying to find an off the shelf option (Friedrich Motorsport) is the only one that actually lists the Fabia. Other Ea211 options may either fit, fit but need reworking or not fit at all so I'm booked for a custom job. Going to be cheaper than the Friedrich and it'll be fitted for me and my tastes.
Okay, thnx for sharing 👍🏾
Fox exhausts also list the fabia.. im currently waiting for mine to arrive.
 Only cat-back though aren't they?
Honestly didn’t check ..
Hey guys, I’ve got a 16 plate Ibiza fr so not a Skoda😂 but I’ve got the same engine as you lot, 1.2tsi 90hp
got the turbo swap done yesterday and tuned, although a conservative tune as we are going to do more power once I have my downpipe and induction kit fitted, atm I’m stock internals other than the turbo....
We never ran into any issues of boost cut and actually had a really smooth graph, so don’t think the map sensor is the issue for you guys.
hope this helps!
hope this helps!
I see the main difference between yours and ours with the cut is that ours peak close to 300nm of torque, where yours sits quite happily at that 225nm area as power climbs.
Do you know what peak boost they were running and what was it like toward redline?
And also what gear were they running it in?
I’ve emailed the tuner there and asked him all those questions so will let you know ASAP!
Be great to see how you get on when you up the tune, that is a nice and flat torque curve and nice power curve
hope this helps!
Which turbo have you installed?
*Info for anyone interested in upgrading to a hybrid turbo*
So after getting the 1.4 hybrid turbo i faced a problem with the wastegate physically not fitting the turbo , the 04E 145 713 N turbo that is used as a base for the hybrid turbo comes with a different wastegate than the 04E 145 721 B
the 04E 145 721 B wastegate- 530423E6-1949-4549-A886-EBC9698B3A0B.jpeg.0f19dddae8ed833fc6c13de918ba982e.jpeg
the 04E 145 713 N wastegate-3F136CEB-4B4F-4278-887B-E59C9F564299.jpeg.2915e9f2ee3ba5d476ad5dbfef6dedfb.jpeg
the 04E 145 713 N based hybrid turboB3678C2F-03AD-42F8-A9EA-82240B360AC6.jpeg.ad36aab44a7230bedcfe66e43f87de46.jpeg
Which part of the actuator won't fit, the mounting point or arm onto the wastegate?
Do you have both actuators?
The arm , i currently have the top actuator and trying to get my hands on the bottom one
