Edited by Breezy_Pete
  • Replies 204
  • Views 61k
  • Pete's service is highly recommended!   Our 2007 Roomster suffered from intermittent windows for approx. 2 years. Dealers could not find the problem. It's not easy to diagnose the fault
  • If anyone is being put off the idea of using this service due to the 'downtime' or inconvenience of having to visit the car twice, once to remove the module, once a few days later to refit the repaire
  • belvedere72
    belvedere72
    I would just like to add my comments and recommendation to Pete’s window motor repair service offer. I am a new member on this Forum and was surprised and delighted by the incredibly fast response I r
hi not shure sorry
Edited by starfire
wrong info
Breezy Pete
thanks for the response. Mine was first registered in November 2007 Temic label on the faulty unit is 440775G/401350A9. 16.07.14 HW002 SW:03xx. Does this help?
Dave
Hi Dave, yes that's a standard repair, I'll message you with contact details/address to send etc.
Already been replaced once judging by the 2014 date code.
Pete, how long would the repair take? I live in Towcester and could drop it off, not a problem for me. I have been quoted over £200 for a 2nd hand one!!!
Dave
(I am not expecting you to do it while I wait)
Have you seen the Private Message I sent through? I'll answer in there if so.
  • 5 weeks later...
Hi Pete
sent you a message. None of my windows are working. Changed loom in drivers door and  master switch with no joy. Would a faulty drivers door motor stop all the other windows from working?
thanks
Stephen
HI  STEPHEN I DONT REPAIR MOTORS I HAD MINE DONE BY PETE WHO IS ON THE FORUM THANKS
3 hours ago, stephenmccahil said:
Hi Pete
thanks
Stephen
Got your message, and will reply in a sec.
The answer is yes, driver's side fault does take out all the others, on the LIN-based versions -  6Y1959801/6Y2959802 and 6Q1959801F/G/H/J
Hi Pete
Sticker is a bit damaged, looks like 6Q1959801G
Stephen
My missus' VRS has stopped working and the PD100 i'm fixing has also just stopped working. My old PD100 used to have 'seasonal electric windows' - i.e. only worked in summer after a dry spell. Is the failing linked to water at all?
Edited by Sheffy
Think it's more related to temperature than moisture.
Thanks for sorting my Window Motor out Pete and for putting up with all my questions.
if you’re motor needs repaired can’t recommend Pete enough!
@stephenmccahil, I enjoyed our chats. :)
Hello are still offering this repair? My windows are playing up fuse removed but only driver side work but the 1 touch isn't
Hello, what year is your Mk1 Fabia, please?
2006 55 plate
OK so that should be a 6Y2959802 part on driver's side (assuming a RHD vehicle). Is it the original motor module there, as far as you know? Please could you describe what is and isn't working.
The usual problem causes both windows to stop working completely, or intermittently for a while first; but it sounds like you may have something different?
Doesn't happen all the time, from the drivers side... when they both stop working I pull the fuse out, put back in the drivers works but not the 1 touch and passenger doesn't work on the driver side but does from the passenger side
I'll message you at lunchtime with some options.
hi its breezy pete on the forum who doese the repairs thanks
@starfire It looks like you may be 'following' this thread and getting notifications when anyone posts in it? Those notifications don't imply anyone is asking you about motors. Try to cancel your 'follow' of it, or just ignore such notifications,  please.
Scroll down to near the bottom of the page, if you're on a phone to change this setting. Near the top of the page if you're looking on a big screen.
Hi Pete,
just found this thread as searching for a replacement 6Y1959801 window motor and module for my daughters 57 plate 5 door polo.
Symptoms are as follows.
1. windows non functioning
2. central locking not working off of drivers door lock ( no remote fob withis model)
Also central locking does work from interior button on door card.
Is this combination of symptoms pointing to the motor/module from the drivers door and is it something you can repair.
thanks in advance.
Hello, yes, that's all consistent with needing a repair to driver's side module. I will send you a private message shortly with some options. :thumbup:
