Software Update available for Bolero?
I have a skoda slavia 2023 model. I have issues connecting with s23 through android auto.
My current company installed version is 1793, which version should I update it to?
  • Replies 785
  • Views 227.5k
  • There are these updates, but not sure if the higher number will apply to your system.   MEN3_EU_SK370_P0113P_0469 MEN3_EU_SK370_P2135P_0742   MEN3_EU_SK370_P1185L_1760 ME
  • It's on the page you posted, "Service Update button" and a USB stick. I will send you some instruction and links. They have an emergency menu for recovery.. so you would have to have a defe
  • StripleRider03
    StripleRider03
    I just updated to 1800, I have a Skoda Slavia in India with the Bolero system. I can confirm that the issue with S23 Ultra is finally resolved! Attaching images.
sw1800
Edited by andreiro221
On 28/04/2024 at 19:29, saurav said:
Update from 1793 to 1798 first. Then update to 1800 and everything will be okay. Android Auto will work with the S23 Ultra just fine with 1800.
@varooom
dear varooom i saw you know very well about bolero firmware updates. my car is a skoda kamiq of 2022 with MEN3_EU_SK370_P1185L, MU 1760. Can you tell me where to find the latest firmware? send me a private message in my inbox cause you can't receive messages (i tried some times before posting here). thanks in advance and sorry if i bother you!!!
@andreiro221thank you so much. Only a few details to ask. From 1760 do i have to update first to 1790 and then to 1800 or i can update directly to 1800? i also saw in some other sites that update procedure can cause some faults that you erase with obd tools. Is that true? Because i dont want to mesh with faults and obd tools. Thanks in advance!!!
Assuming that 0469 version is currently installed is update path:
0469 -> 0741+0742 -> 1800
allowed or some of 17xx has to be there before 1800 can be installed?
Additional question - I have heard that 1800 looks to be compatible also with Scala/Kamiq MY2019/2020, is that true?
you go direct to 1800
no, if you have 469, 742, there is no OFFICIAL update to 17xx/1800
only at your own risk
@varooom @Rainesh  maybe you can help me
i tried to update my system from version 0741 to 0742 , but the car battery died during the update
now the system doesn't work good , with a lot of restart and i can start the update again as it always reboot
i also get the following (pic)  error displayed ( not all the time )
any suggestions how to upgrade to working system
thanks
thanks
Update to newer version and do it with running engine
first , thank you for helping
the main issue , is that i can't start a new update , as it boot loop when i enter the update menu and choose the update ( it boot loop every few min regardless )
is there a way to force update , or update as BRIK device ?
i said it many times... KEEP ENGINE RUNING OR A CHARGER CONNECTED... but nobody listen....
you must try to flash with 0469 as it is a full flash. 0741 is a partial flash.
can you provide 0469 version files ?
BTW , 0741 was the version the official service center installed on my unit 1 year ago after service ( back them i wasn't aware of this wonderful forum )
if the dealer installed only 0741 , it was wrong and you should go back and see what they say.
  0741 must always be followed by 0742....
Hi, I'm looking for MEN3_EU_SK370_P0113P software. Can someone help me? :)
New Scala owner and not that switched on to software updating. I want to connect to Android auto but won't work. Reading on here looks like I need a software update? Can someone send me the specific steps to follow to undertake this process. Hopefully not too complicated! See pic for c
Spoiler
urrent version
what phone do you have?
why it does not work ?
Samsung S23 which is not included on Skoda's approved list of compatible phones but S23 + is. Seems bizarre !
there is a wll known problem with S23...
update to SW1800
I have been told that trying to do this myself can be tricky and mess up the infotainment system?
only if the battery dies.
Always connect a battery charger or keep engine running, ignition must be ON, And don.t play with buttons or diagnosis. Don.t touch anything after starting update
I am currently on 1790 version. But when I am trying to update to 1800 its stuck at confirmation screen. When I press confirm nothing happens. Do I need to update first to 1798 ?
do you all update software on-air or how do you do it?
from when new (11/2023) my car is on 1790 software and I didnt get on infotainment notification about the update to perform it by myself via infotainment
on my previos car (tiguan my 2022) I did get notifications about the update via air and I have done it twice, but on Scala there is no update on my infotainment
maybe that is why I randomly get "component protection active" message on infotainment (once a week)
Edited by medley
Hey there. I see this topic is quite active. I have a coworker with an s23 phone, her radio firmware is 1310, is there a way to update to 1800 as I've heard 1800 has solved the s23 issue. Thank in advance!
I have no idea but if someone can tell me how to update my software easily and safely then please let me and others know
