Software Update available for Bolero?
4 hours ago, andreiro221 said:
poti face update la 469 >741+742
dar trebuie si tester capabil sa ruleze functia de Replace pt unitatea media.
trebuie vazut si erorile legate de OCU, cel mai adesea trebuie inlocuita antena din unitatea de OCU, daca ai eroarea B200049 in unitatea OCU
also 469 > 741+742
but you also need diagnosis to run Replace function for the media unit.
 multumesc pentru hinturi...acu trebuie sa gasesc un 469....iar daca stric ceva, mai bine caut o unitate similara pe la dezmembrari:))
  • Replies 769
  • Views 200.6k
  • StripleRider03
    StripleRider03
    I just updated to 1800, I have a Skoda Slavia in India with the Bolero system. I can confirm that the issue with S23 Ultra is finally resolved! Attaching images.
  • radoszczak
    radoszczak
    Cześć, poniżej link do strony z opisem możliwych FW U Ciebie powinno pójść do wersji 742. https://www.drive2.ru/l/650934799095051499/
  • There are these updates, but not sure if the higher number will apply to your system.   MEN3_EU_SK370_P0113P_0469 MEN3_EU_SK370_P2135P_0742   MEN3_EU_SK370_P1185L_1760 ME
@varooom @Rainesh do you have this version - 469, MEN3_EU_SK370_P0113P? thanks
also 469 > 741+742
I couldn't understand you. I need the 469 version file. Did you mean there is a hardware obstacle?
no
you need 469 because you cannot update directly to 741+742
then 741+742, as this is the latest sw available for this unit.
Edited by andreiro221
1 hour ago, andreiro221 said:
no
I understand.  Where can I find the 469 version?  Is there a link, please?
Hello, I have read all topic, and I need confirm that what I will try to do is correct way to update my mib3. So I have skoda scala from 2021 with bolero on fw 1310. I have known s23 issue with AA. I need to to an update. Simple question: should I update first to 1790, and then to 1800, or I need to try all chronological verisions in a row update like 1760, 1790, 1798, and finnaly 1800 ? I have download 1790 and 1800 form mib-helper. Thank you in advance.
just sw1800
i will try to upload
13 hours ago, andreiro221 said:
just sw1800
Thanks for answer. Is charger nessecery to do an update ? Is engine running isn't enough to power up battery and keep right voltage in car ?
factory does not recommend keeping the engine running while doing updates
They recommend a charger.
8 hours ago, radoszczak said:
All here as far I know.
https://disk.yandex.ru/d/1V1uBTc8ssc3zA
only 741+742, ther is no 469 there
True. I miss that 469 is missing. Please tell me more what is native usb stick ? I'm using a usb-c adapter to micro-sd card. Is it will be ok to use it to update firmware, or better way will be use an adaptor usb-c to normal usb and put an ordinary usb stick to it ?
native usb C stick
no adapter
Is there known issues with firmware update from 1310 directly to 1800 ? I have all for now - fw on usb c native stick, and power suply charger. I'm planning to update car this weekend. Any advices ?
Edited by radoszczak
M car had zero problems, although the dealer did the update, as the car was/is still under (extended) warranty (5 years).
no problem.
but need ignition on ( engine running or power supply )
Hello I wonder if the file for version p0113p sw 0469 was found!
Hey @varooomand @Rainesh
could you advise me on an update for
MEN3_EU_SK370_P9305P
MU SW: 0463
I understood you can send firmware file links via PM.
Thanks in advance!
I can not connect AA with my new Android phone. After some search I found this thread about updating and did everything to start but my Software version is 0463 (Hardware 033) and it seems I have to update to 0469 first.
I can not find this update, the download links are expired. Can somebody please share 0469 with me?
I have read here about wireless smartlink on MIB3 with 1800 SW, someone wrote that is a way to activate it with skoda pack that can be purchase via online store.
Does anyone has completed this with success ? (I own skoda scala 2021 with wired smartlink that works, I don't have wifi/WLAN options on menu). Thank you in advance.
Read up. It was me, and you have to buy it from a dealer who can install it only on 1800 version of Bolero infotainment. Aferward, you get WiFi (via FEC), which can be used only for wireless AA/CP.
Thank you. I'll ask my dealer in PL about it.
@radoszczak please let us know if you find out anything from the dealer
On 11.06.2023 at 12:35, varooom said:
Başkalarına da bahsedildiği gibi özel mesaj.
@varooom
Hello, if you have the P0113P 0469 firmware file, I would appreciate it if you could send it.
How do I establish what version of s/w I have on my 2019 Scala SE L TSI please.
TIA.
