VCDS options on Superb III.FL
On 07/09/2023 at 08:05, MartiniB said:
my apologises about starting this new thread, few reasons to keep it separate:
1. Mk3 coding's thread is grown hugely and isn't easy search something in it.
2. FL codings has several differences.
3. coding procedure has been also changed -
 before do coding, must be opened bonnet and activated handbrake
what have been tested on Mk3.FL MY23 280ps L&K
*** add Tolerance for Predictive Adaptive Cruise Control
13 Adaptive Cruise Control
            Long coding
                        32055FD25DFFC728949C812481400680000000000000000076
            ->         32055FD25DFFC728949D812481400680000000000000000076
            ->         32055FD25DFFC728979D812481400680000000000000000076
            ->         32055FD25DFFC728979D812481400680000000000010000076
or         -> Tempolimitassistent_CarMenu:
                        Not activated  ->         activated
or         -> zul_Regelabweichung_CarMenu:
                        orig.     Off
                                    Small     (nothing)
                                    Medium (nothing)
                        ->         Large     (off; low; medium; high)
or         -> pACC_Learning_drivers_offset:
                        Deactivated     ->         activated
Hi there. I have a 2023 L&K with Travel Assist and pACC. I've tried the change to 'add tolerance for Predictive Adaptive Cruise Control' but nothing seems to have worked. Are you supposed to get any changes in the menu for ACC system.
Edited by mitchec
  • Replies 264
  • Views 105.3k
  • Why would you want them off? Auto lights are notorious for people driving around in poor visibility and no rear side lights.   Personally I always code them to be on.
  • https://github.com/olli991/mib-std2-pq-zr-toolbox Here you can find out whether it is suitable for MIB or not
  • Paikesejanku
    Paikesejanku
    Yes, you have to change two values: 09 – Central Electrics - Adaptions Search 'scheinwerferreinigung' (headlight cleaning) Select 'SRA Verzoegerungszeit' and set value to '2000' (don't wor
@mitchec
new options came in infotainment asistents menu
marked red choices don't work
I had Lane Assist coded on to my Superb (it wasn't on from new, apparently) back in 2021 and had been working okay up until four weeks back, when the car was in for a pre NCT (MOT) check at a Skoda dealership, whilst there, they also updated the front camera software, which has wiped the coded Lane Assist. The dealership had an attempt at retrieving the coding, but without success and have now just given up on it.
Does any do this coding, or know of someone that does, in Ireland, Munster region, or, any where in the SW of England / East Anglia, where I do visit a couple of times a year?
Edited by Eirhead
Has anyone been able to code lane assist in FL Superb? I have 2020 SE L and followed guy in this video Skoda Superb MK3 FL Lane Assist coding (he's Polish but so am I so hadn't any issues following his steps). I've done each step like him using OBDeleven PRO and only managed to get option shown on radio screen and maxidiot but with exlamation mark and unable to actually enable it 😭
What part number does your big camera have?
Where do I check it using OBDeleven?
Control unit A5 under Info.
But if you don't know that, I wouldn't code anything.
Here you go
2Q0
There are instructions for that and it will work. Then you either didn't code everything or did something wrong.
I've followed steps of this video included, I know it's in Polish but all commands in the wideo are in English
I didn't watch the video because there are other instructions in text form. There's no need for a video.
Hi @Lutz_91 I see your car is pre-facelift so there's plenty info about this but I couldn't find much to go for with FL models like mine.
Just because I have a vFL, I still have some idea about an FL model.
You have a PM
I allowed locking a car while engine on via VCDS. But it works with remote key only. Is there any way to lock running car with kessy?
@brsk
have you coded both?
On 07/09/2023 at 10:05, MartiniB said:
*** Enable Fob with Car Running
09 Central Electronics
            Access Code 31347
            Adaptation
            -> ZV allgemein(Access control)
            ---> Funk bei Klemm 15 ein:
                        not active        ->         Active
*** Enable passive lock/unlock via door handle sensors (KESSY) with ignition on
B7 - Access Startsystem Interface
            Long Coding
                        0F20000723
            ->         1F20000723
or         -> Terminal 15 characteristics of passive entry exit function
                        orig. value:      Function only allowed for terminal 15 off
                        new value:       Function only allowed for terminal 15 on or off
for me it's working also from door handles, key fob in pocket, outside of car
Edited by MartiniB
@MartiniB thank you. In VCDS I can't find B7 - Access Startsystem Interface? Where can I found it please?
Do you even have Kessy then? The B7 should appear in the installation list.
Lock the car and wait 30 minutes -> bus rest.
As an idea
@Lutz_91 ok. It’s locked now so will try it in 30-60 min
Edited by brsk
Ok after 1 hour still cant lock vehicle with kessy while ignition on.
Then the coding is wrong. Or your Kessy STG has the wrong SW version.
Someone who gets it would have to show their SW version of the Kessy STG.
@MartiniB
Show the software version of your Kessy STG or part number
28 minutes ago, Lutz_91 said:
@MartiniB
    Control unit: B7 Start System Interface
    System description: VWKESSYMQB
    Software number: 3Q0959435Q
    Software version: 1400
    Hardware number: 3Q0959435Q
    Hardware version: 037
    Serial number: 061244xxxx
    ODX name: EV_KessyHellaMQBAB
    ODX version: 004055
    Backup name: Start System Interface
    Long coding:
        1F20000723
So what can I do guys?
First show your data for the B7 so that you can compare. Or is it exactly the same as MartiniB?
I’m working as system administrator but I’m totally newbie in VCDS. Where can I find sw info please?
Edited by Gizmo
Links removed by brsk’s request
