VCDS options on Superb III.FL
Page Not exist
  • Replies 264
  • Views 104.7k
  • Why would you want them off? Auto lights are notorious for people driving around in poor visibility and no rear side lights.   Personally I always code them to be on.
  • https://github.com/olli991/mib-std2-pq-zr-toolbox Here you can find out whether it is suitable for MIB or not
  • Paikesejanku
    Paikesejanku
    Yes, you have to change two values: 09 – Central Electrics - Adaptions Search 'scheinwerferreinigung' (headlight cleaning) Select 'SRA Verzoegerungszeit' and set value to '2000' (don't wor
On 24/12/2025 at 16:22, Szogun said:
But now I changed the steering wheel to the "new" one with capacity sensor.
I coded everything properly, but from the button on steering wheel I can only turn ON/OFF heating. I know there is a possibility to turn on the 3 level of heating option.
Did you install any module for steering wheel?
1 minute ago, Cairus said:
Page Not exist
I belive moderator has to accept the new topic.
Yes - new clock spring with additional power supply
I didn't get you, you wrote:
"From factory the steering wheel was heated."
My question was about module for Steering Wheel buttons? needed for View/Menu etc.
Yesterday I helped to guy with Superb 2020, he had "old" style heated SW and installed new 2025 heated SW. He coded 3v0907044fa and all good - [LO]_Heated_steering_wheel_version: [VO]_LRH_Gen_2_mod
IT is only "Menü" which dont Work without LIN Adapter
Is it possible to code 2 things to work:
  • Changing the steering wheel heat level by the button on the wheel (3-2-1-0)
    And
  • Automatic heating in low temperatures + automatic heating when seats are heated?
New type of steering wheel from the factory. Heated steering wheel retrofitted.
Edited by bobbest
    And
Check what do you have in 08 Climate Control Module cdoing - Heated_steering_wheel_automatic_mode
I have adapter for new steering wheel and LIN signals - the view and menu button works.
    And
Exactly - I want to code it as in first option (3-2-1-0) But now I have only 2-0 (2- according to the graphic on VC)
Heated_steering_wheel_automatic_mode - Not installed
Did it worked as on this video?
3-2-1-0? Or just ON-OFF?
By these settings - autoheating with seats and tempetature works properly. Button on steering wheel does not change 3-2-1-0 but only on/off
19 minutes ago, Szogun said:
yes, only changed Heated_steering_wheel_version
what Lin module do you use? I know that one of them sends extra command when you press button to enable/disable heating
On 07/09/2023 at 08:05, MartiniB said:
23.06.08          ok
17 Dashboard
            Adaptation
            -> Tubes illustration
                        orig.     Version 0
                        ->         Version 1
This is the virtual console theme. 0 is standard on mine....
if I switch to 4 I get this....
Edited by Dave77
Has anyone used on a FL, with success, a Launch C-reader Elite?
